Old 03-20-2011, 05:07 PM   #106
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Originally Posted by scorpion View Post
I used a little trick to get those pesky bolts lined up for the install. Used a bit of foam scrap as a shim, worked great.
I seem to have my battery in and out quite a lot for whatever reason so I put a headless bolt on each terminal, secured by a nut on each side of the terminal face and a final nut to secure all the connectors. Saves faffing. Need to do the same with the crash bars when I get a minute....
jamesbrown is offline   Reply With Quote
Old 03-26-2011, 07:03 PM   #107
Orangecicle
Orangecicle's Avatar
Oddometer: 1,195
Dang! Just when I have almost everything squared away on my bike, my battery dies, and nobody has Shorai stock anywhere.
"Do not follow where the path may lead. Go, instead, where there is no path and leave a trail." -- Ralph Waldo Emerson
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 03-26-2011, 07:16 PM   #108
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Some inmates to check:
http://www.cjdesignsllc.com/shorai.html
http://www.advmachines.com/
http://www.blackdogcw.com/
Probably forgetting some....
Old 03-26-2011, 07:26 PM   #109
Orangecicle
Oddometer: 1,195
Originally Posted by jamesbrown View Post
Dry holes. Already checked, but thanks.
Old 05-14-2011, 07:20 PM   #110
cyborg OP
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 4,406
Added 2.4Ghz Wireless Spread Spectrum Battery Telemetry to my Shorai LiFePO4 battery, just because it can and I could.
Less than 2oz of extra stuff, RC tech:
Key off:
Key on, bike not running, with HID's running:
Works up to 1/2 mile away. Monitors each of the 4 cells in the battery, Amps 10mA up to 100A (150A burst), Ambient Air Temp -4 to 176F (-20 to +80C)
cyborg is offline   Reply With Quote
Old 05-14-2011, 07:32 PM   #111
KTM450SX
Oddometer: 263
Haha thats cool!
2008 KTM 250XC
2007 KTM 950 SE
2005 YZ 125 the mini braaaaaaap
KTM450SX is offline   Reply With Quote
Old 05-14-2011, 07:58 PM   #112
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,569
installed mine under the seat. Cranks over like a bastage!
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2 mk3 auto, 1999 Intruder 1500, 05 Ruckus, 90 DRBIG 800, 79 GS850My last location and updates-Ride Reports
FINNDIAN is offline   Reply With Quote
Old 05-14-2011, 08:15 PM   #113
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Dayum, you can check your battery from the campsite shitter. I've always wanted to do that That's awesome.
Old 05-14-2011, 09:47 PM   #114
summitdog
It's an Azawakh
summitdog's Avatar
Oddometer: 187
I ordered a Shorai battery and the distributor told me that the battery was on back order. Anyone else experiencing delays?
Scotty
General Disclaimer: Nothing in the above posting is intended as, nor should it be construed as, legal advice.
Every situation has a particular nuance that needs to be considered individually.
If you believe you need legal advice, please seek out an attorney.
Scotty Storey, Attorneys at Law
800-264-4379
info@twowheellaw.com
AFM #733
summitdog is offline   Reply With Quote
Old 05-14-2011, 09:54 PM   #115
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,100
Butt, is that 70ma of draw with the key off? Whatcha got goin' on? Blender makin' pina coladas?
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 05-14-2011, 09:58 PM   #116
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
That's all the sensors
Old 05-14-2011, 10:07 PM   #117
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,100
-cp
Old 05-14-2011, 10:24 PM   #118
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,100
Very cool. I'll bet you have everything on hand to make it remote start with just a little more effort.
-cp
Old 05-14-2011, 10:29 PM   #119
cyborg OP
cyborg's Avatar
Oddometer: 4,406
Oopsie, reposting, nuked by accident. Added a bit.
The sense package is not monitored for it's own draw, but it draws about 8 mA at the 4 samples/sec xmit rate.
This Quanum system is cheap, so not quite NASA grade accuracy. On the low end due to whatever weirdness it can indicate anywhere from 0.0 to 0.2 since the AMP sensor is so wide-range, and doesn't always reset to 0.0 from negative current draw, maybe it doesn't like that. The AMP sensor is uni-directional on this sensor so once the bike starts, the AMP reading drop to zero because the alternator is backfeeding current. RC applications are one-way, just drawing.
The real indicator is the battery voltages, which are spot-on. If they aren't dropping much, I don't worry about it. I have different AMP meters for the really small draws, for troubleshooting. The inexpensive AMP sensor was bundled with the Temp sensor, so I hooked it up, what the heck. My 990S indicates about 108Amps while cranking cold, about 80-90 amps when warm. It can peak up to almost 135Amps on first crank, as captured by a recording AMP meter:
The gadgets used were this and this and this if you are so inclined.
and these to mod to connect to the 4S balance port
Old 05-14-2011, 10:34 PM   #120
cyborg OP
cyborg's Avatar
Oddometer: 4,406
Nah, I could... but no.
Since these LFX batts are so new, and have the ability to monitor individual cells, the geek engineer in me just had to know. I found something way cheaper for that than trying to DIY from scratch.... and I can watch it from my desk at home or work.
Times are GMT -7.   It's 07:20 PM.
