Old 01-09-2011, 12:04 AM   #1
alpo996 OP
Oddometer: 86
Adventure Lighting Project
Winter project was to get some proper lighting on the 990 without hanging a bunch of aux lamps on. Was gonna go with the euro reflector setup but decided to look around a bit to see what else could be done. Found a great source of Hella lamps and parts at Susquehanna MotorSports: http://www.rallylights.com/SearchResult.aspx?CategoryID=359 . Ordered a 99802 Bi-halogen H9 hi/low projector and a 68152 H7 high beam with a city light, both 90mm in diameter. They also have genuine Hella xenons (HID) but they are pricey! Here are the new lights and the stock US lamp before the surgery began:
Bi-halogen and bi-xenon lights are low beam projectors with a shutter for the beam cutoff that raises out of the way when high beam is selected. Great idea, especially when using HID because there is no delay or bulb warmup when you hit the brights. Here you can see the bi-halogen lamp on the right and the high on the left.
Stock headlight bucket after removing the cover and reflector and starting to open up the hole at the back:
Shaving down some extraneous metal on the low beam lamp:
Cutting extraneous metal ears from the high beam:
The top of the stock bucket only needed a little bit of dremeling to allow the high beam lamp to go in with an interference fit:
The trim ring needed some extra clearance:
Made some angle brackets and attached them to the mounting ring (58001) that I ordered with the light:
Didn't use the aluminum ones; tapped holes in the steel brackets then positioned the mount in the bucket, securing it with 3 bolts from the outside. Ignore the "top" designation:
Here's a top view with hi beam in and the low beam bracket in place:
Side view with both lamps in:
Front view with bracket painted:
View from behind:
Wired up with a relay for high beam (I'll post wiring diagram later):
On the bike, without windshield. You have to make a little room for the back of the light by moving some wire bundles a bit.
All done:
Finally had enough snow and ice to clear so I could go for a ride tonight, although it was 19 degrees. How do they work? Pretty darn good! Low beam is wide with a nice cutoff; HID pattern seems a bit short front to back but it might be the cheap HID bulb. Didn't try the stock H9 bulb but it's supposed to be good. High beam is fantastic. Shutter raises on HID and halogen high fills in nicely.....very good coverage near and far.
Now for the down side: adjustment is difficult. Start by aiming the high beam by shimming the whole bucket. I needed one washer on each top corner to aim the light down some. Then I adjusted the low using the adjusters that came with it. Heavy load in the back will require rear preload to compensate because you'll blind everyone unless your beam cutoff is set right. I'm thinking about drilling holes in the lens cover to get to the adjusters after you RTV the cover over the new lights. Could put a rubber plug in them.
Wiring the lights up to do what I wanted wasn't too hard, and I'll post a diagram later. Gotta keep the low on when the high is selected. Don't know how this compares to a euro light; I've never seen one. I'm happy with this setup though, and it didn't cost a grand from TT.
alpo996 is offline   Reply With Quote
Old 01-09-2011, 01:58 AM   #2
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 280
Wow nice setup. Please post pics of the light pattern if you can.
Pics and vids
种. is offline   Reply With Quote
Old 01-09-2011, 11:20 AM   #3
BrassAss
Lost, but not forgotten
BrassAss's Avatar
Oddometer: 184
Nice Job!!!!
It looks like you went to a lot of work there. Way to think out side the norm.
KTM 990 Adventure
BMW 1200GSW
www.tmadvgear.com
www.backcoutrydiscoveryroutes.com
www.butlermotorcyclemaps.com
BrassAss is offline   Reply With Quote
Old 01-09-2011, 01:56 PM   #4
Roughidle
Super Star Destroyer....
Roughidle's Avatar
Oddometer: 1,494
Thats awesome man.
Burninating the peasants.
Roughidle is offline   Reply With Quote
Old 01-09-2011, 03:50 PM   #5
Aquanout
Hooliganantic
Aquanout's Avatar
Oddometer: 748
Bahahahaha!!!!
I totally clicked this link thinking you were going to "Lighter" your whole bike, trying to shave weight here and there! Bahahahaha!!
Yer setup looks pus, I'd totally do it but I'm so bloody blind I cant see past my low beams anyway.
I put a 55watt bulb in the top spot in the light bucket, "That which burns twice as bright burns half as long", hell of a smoke show when the reflector started on fire!! So regardless of my blindness I still may use you brightness.
Aquanout is offline   Reply With Quote
Old 01-09-2011, 05:31 PM   #6
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,275
Thanks for being the pioneer!! I bought those exact 2 lights last winter with the same idea in mind and just haven't gotten around to fitting them up yet. One issue that was in the back of my mind was rear clearance. Did you have to modify the support bracket at all??
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 01-10-2011, 02:22 AM   #7
nemesi
nemesi's Avatar
Oddometer: 23
Nice set-up! I am just a bit concerned about heat dissipation, probably the 2 hella lights do not cool down enough during long rides. maybe a small hole or window in the front original glass will let some air in!
KTM 990 S Adventure - Going east
KTM 990 Adventure ABS 73 000 km
Ducati Multistrada 1000 S 42000 Km
Yamaha XT 600 Z Tenere 52000 Km
nemesi is offline   Reply With Quote
Old 01-10-2011, 02:55 AM   #8
Salzig
Salzig's Avatar
Oddometer: 253
On euro light, when selecting high beam, both bulbs are on.
Nice job
Actual rides:
'10 Husqvarna TE310 - '07 KTM 990 Adventure ABS (S'd) - '04 Husqvarna SM450R - '99 YAMAHA R6
"A donkey! A donkey! My kingdom for a donkey!"
Salzig is offline   Reply With Quote
Old 01-11-2011, 10:24 PM   #9
alpo996 OP
Oddometer: 86
Thanks, Salzig. What I meant about the euro light comparison was, I don't know how my overall light output/beam pattern compares to the euro. My low is pretty good now, and the high is awesome.
Boatman, no mod to the support bracket necessary, but I did have to cut the zip ties on some of the harnesses and move them out of the way. With the length of this light, it was a tight fit!
What I did in order to put an on/off switch in for the headlight was to put a small pushbutton in the left switch housing, interrupting power to the center feed wire. Then, to keep the low beam on when high is selected, I jumped the feed wire (after the switch) to the low wire so it stays on. Used a relay on the high lamp to keep current low in the stock wiring.
Old 01-12-2011, 05:26 AM   #10
Salzig
Salzig's Avatar
Oddometer: 253
Uhm... I'd better work out my english comprehension.
Actual rides:
Old 01-12-2011, 04:19 PM   #11
HWSNBN
HWSNBN's Avatar
Oddometer: 2,895
Little known trick... You can pop the low beam + wire crimp out of the molex that plugs the light harness into the panel. Put it in the upper left hand corner, previously unused portion of the 6 place plug, and viola, you will have the low on with the high. This is how the Euro light harness comes. Only in the US is low beam switched off with the high. Its then possible to still use the low beam switched + middle right position to trigger a relay for driving lights iffin that was something you might wanna do for extra credit.
The green wire. This is a spare harness I made a while back so the wire colors don't jibe. Upper left though is what you want.
Nice mod ! Cheers
HWSNBN is offline   Reply With Quote
Old 01-12-2011, 07:19 PM   #12
alpo996 OP
Oddometer: 86
Thumb
Aha! That's definitely the easy way to get low on high. Thanks for sharing that. Alpo
Old 01-24-2011, 05:49 PM   #13
gixxersteph
gixxersteph's Avatar
Oddometer: 623
I have two questions if I may
1) how did you remove the lens? It seems that there are the clear tabs and the that pesty glue. Hints would be appreciated
2) did you consider the basic H9 version ? By measure of lumens they should work darn well
Thanks,
Steph
gixxersteph is offline   Reply With Quote
Old 01-24-2011, 06:59 PM   #14
tomdubz
getting there
tomdubz's Avatar
Oddometer: 510
I knew there had to be a way. Anyone do a step by step for us electrically challenged folks? Where is this low beam + wire crimp out of the molex that plugs the light harness into the panel that you speak of?
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 01-30-2011, 05:43 PM   #15
gixxersteph
Oddometer: 623
I figured out how to take the the headlight apart. Hint oven about. 240 degrees and be willing to use some force, measured of course. Now I will order the lights.
I will use the H9 loe beam and high beam. Simpler and hopefully just as effective. I might even take pictures of the install
Thanks Alpo for the inspiration
Times are GMT -7.   It's 02:36 AM.
