Old 01-10-2011, 10:05 AM   #16
supershaft
Oddometer: 9,110
Originally Posted by bmwrench View Post
Unless you need to pull the crankshaft for bearing inspection and/or replacement, I would simply get the rods and pistons balanced. This almost always results in less vibration. Install some lightweight wristpins while you're at it.
Balancing the flywheel and clutch-particularly in '81 on motors is also worthwhile.
I am curious to why you say that about late model setups. I have balanced about five or seven of them and they were all spot on as is.
Old 01-10-2011, 07:50 PM   #17
bmwrench
Oddometer: 2,061
I've never seen any (that I checked) that were correctly balanced. Go figger.
bmwrench is offline   Reply With Quote
Old 01-10-2011, 09:07 PM   #18
supershaft
Oddometer: 9,110
Sometimes I think we are on a different planet.
All five or seven of mine were perfect no matter how you lined up the paint marks not that you get any of them even close to 120 degrees apart.
Old 01-11-2011, 06:19 AM   #19
Martian OP
Oddometer: 1,105
Now that we've moved on to flywheel/clutch unit balancing, I do have some experience. When changing all the clutch parts on the GSPD, I ran a rope thru the center of the flywheel, stacked the clutch parts, and hung them from the rope. It took a few tries, but eventually, I got them arranged where they hung perfectly level. The bike seemed smoother than before, but I don't have any way to prove it .
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Times are GMT -7.   It's 06:16 PM.
