Old 01-10-2011, 07:33 AM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
Weird carby deal on my R60/5
Ok, it's a 1970 first sold in 1971 and has the older silde type bings with the tickler. The one on one side works perfectly and the left one keeps dribbling a tad after I tickle it and let the plunger go. It stops as soon as the bike starts and never leaks or dribbles until I use it again.....whats the deal? I can and do still ride it since it doesn't leak while riding or even after it fires up.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X screwed with this post 01-10-2011 at 07:50 AM
Sniper X is offline   Reply With Quote
Old 01-10-2011, 10:01 AM   #2
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,822
I would guess that the tickler is hanging up a tad, and that, once started and/or riding, the vibration lets it seat properly.
You might try working it a bunch, up and down, as there may be a bit of crud somewhere.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-10-2011, 10:49 AM   #3
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I tried that to no avail. I have not looked close, are they removable without carby disassembly?
Old 01-10-2011, 11:38 PM   #4
OLD GREEN
OLD GREEN's Avatar
Oddometer: 569
I've got the same thing happening on mine and I've already torn it apart once to clean the carbs when I got the bike but it still does it. It'll just slowly dribble out the left side for about a minute or so after I tickle it . Then it clears up, so I've decided to live with it.
I'm pretty sure that you need to disassemble the carbs to take the tickler apart. If I remember correctly they are held together with a cotter pin on the inside. Good Luck.
OLD GREEN is online now   Reply With Quote
Old 01-11-2011, 02:46 AM   #5
PaulRS
Dutch fool
Oddometer: 808
Check the floatvalve.
Iirc, the tickler pushes the float down to open the valve, when releasing the valve should close again.
On the older carb's, the seat of that valve is brass and the valve itself is a steel, tapered needle, they wear.
Paul.
Geht net, gibbet net.
PaulRS is offline   Reply With Quote
Old 01-11-2011, 04:33 AM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,876
It's part of the charm of these old bikes. On mine, the left tickler starts to overflow after the count of three and the right tickler takes five. Thr float levels, fuel levels and overflow tube heights are identical, but it still does it. I gave up wondering about it 30 years ago.
'73 R60/5 Toaster
Old 01-11-2011, 10:01 AM   #7
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I won't worry about it then! It doesn't effect the way the bike runs or starts at all.
Times are GMT -7.   It's 09:22 PM.
