Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 01-10-2011, 11:19 AM   #1
NorCal.matt OP
Oddometer: 27
Eek Garmin Nuvi 500 Crashes
Hi all,
I recently got a GPS (first one I've owned) and am trying to get it to make a custom route for a coastal trip. The problem happens when I go to "My Data", "Import Route from File", and select the files to import. The Unit goes blank at this point. I have given it a lot of time to do it's voodoo, but it appears that it just shuts down. I should note that I am using Garmin BaseCamp for Mac. Also, I do NOT have any additional memory in the Unit itself, which is what I assume the problem is... just wanted to make sure. Thanks for any help!
NorCal.matt is offline   Reply With Quote
Old 07-04-2011, 02:02 PM   #2
kelly1
Oddometer: 16
Does anyone know of this issue. I just got one of these and I'm having the same issue and can't find anything about it online ??
kelly1 is offline   Reply With Quote
Old 07-04-2011, 02:49 PM   #3
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 16,064
Originally Posted by NorCal.matt View Post
Hi all,
The Nuvi 500 takes up to 250 via points. Do you have more than that in the route? If so, split the route up into a couple of routes not exceeding 250 via points. The Nuvi 500 can only store 10 routes, so check that as well. If you have 10 or more export some to your pc or mac via mapsource.
You if these ideas don't pan out you may have to do a hard reset. To do this:
Hard Reset Procedure: (All except the 8x0/8x5/37xx series units):
1. Power the unit off.
2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
4. Press "yes" and the unit will reboot.
Reset all your location settings and user preferences. Also restore your favorites using the method outlined at the end of this post.
Note*** Doing this will likely delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites) * Note that this procedure will clear all user selected settings under Tools>Settings like map view mode, navigational settings, selected vehicle, selected voice, etc. These settings will need to be re-configured afterwards. It will also clear out your Recent Finds so make sure you save these as favorites or archive them in another way. Maps, vehicles, voices and user-loaded custom POI's stored on the unit will not be
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is online now   Reply With Quote
Old 07-04-2011, 08:27 PM   #4
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
mine was also crashing but at a different time
http://www.advrider.com/forums/showthread.php?t=701373
hard reset and then i used webupdater and redid the latest firmware and now no problems.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 07-04-2011, 08:29 PM   #5
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
is that 10 routes when you copy over a .gpx directly to the unit?
if i use mapsource to import one, i create i get 1 only at a time that comes in.
Alaska
Old 07-04-2011, 09:47 PM   #6
TRZ Charlie
That's MR. Asshole
Oddometer: 16,064
No, it only holds ten max. They transfer one at a time to the unit.
Old 07-04-2011, 10:02 PM   #7
kelly1
Oddometer: 16
I created three different routes in Base Camp pc version, all with less then 80 via points. Did the hard reset and it still crashes after I try to "Import Route fro File" ?????
Old 07-05-2011, 07:26 AM   #8
TRZ Charlie
That's MR. Asshole
Oddometer: 16,064
Have you updated the unit lately on Garmins site?
Old 07-05-2011, 07:32 AM   #9
kelly1
Oddometer: 16
The sight tells me that it has the latest software..
Old 07-05-2011, 07:40 AM   #10
TRZ Charlie
That's MR. Asshole
Oddometer: 16,064
I'm thinking it's time to spend some quality time with the Garmin Support folks, googling around I find nothing that will help you (you've done what you should have done), I think its time to call Garmin.
Old 07-05-2011, 11:29 AM   #11
xymotic
xymotic's Avatar
Oddometer: 8,367
Sounds like an issue I had and they told me that you could not route road data in basecamp.
I've had twenty people tell me this is resolved/non-issue. (I got rid of the 500 because it ticked me off so bad) Try exporting your route, import it into RoadTrip and then use Roadtrip to export it to the Nuvi and it should work.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 07-05-2011, 12:19 PM   #12
GlenInk
GlenInk's Avatar
Oddometer: 84
Thumb I have a solution for you !
All you need are two basic tools and follow instructions and you Zumo500 will never ever give you another problem !
The pic below is the tools needed, and the faulty Zumo500 the before fix !
Put brain into gear before opening mouth !
GlenInk is offline   Reply With Quote
Old 07-05-2011, 12:21 PM   #13
GlenInk
GlenInk's Avatar
Oddometer: 84
Laugh I have a solution for you !
Below is the after the fix pic. I promise your Zumo500 will never give you another days trouble !
Old 07-05-2011, 01:07 PM   #14
xymotic
xymotic's Avatar
Oddometer: 8,367
Nuvi 500, not a zumo! Lol, that's seriously crazy. Do you often use 20's to light your BBQ and hundreds to wipe?
Albert Einstein
6:10 to Yuma
Old 07-05-2011, 08:54 PM   #15
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
choose the option to redo it.
Alaska
HTML code is Off
Times are GMT -7.   It's 11:10 AM.
