01-10-2011, 06:34 PM
#1 |
Oddometer: 140
Shorai Lithium Iron battery install in my R1200R
I just bought A Shorai LFX18A1-BS12 for $186.95 plus $8.26 shipping.
Here is what it looks like packed in the foam pieces that you must trim to make it match your original battery: ![]() Here it is compared to my 2009 R1200R's original battery: ![]() ![]() ![]() Here it is with the foam cut to shim the battery: ![]() ![]() The battery is 7 pounds lighter than the original. It is so light that it makes you wonder how it can generate any power. The battery was a PITA to install because the nut to which the terminal screw attaches falls away and out of reach if you have an accessory wire attached to the battery in addition to the main cable. I had to stick a piece of the foam under the nut in order to keep it in place and within reach of the screw. Here is a comparison of my original battery's pretty robust terminal and the Shorai's terminal: ![]() It would be nice if the nut was taller and the terminal itself was flush with the top of the battery. The way it is now, the leads of my battery cables are angled down to meet the terminal and probably don't have as good of a contact area as it would if the terminal was flush. Further, the foam pads that shim the battery are exposed to water spray. I don't know how they will hold up or if they will retain water like a sponge. If I had known that I had to cut foam to make this battery fit and shim the terminal nuts to make them work, I wouldn't have bought this battery. The weight savings isn't that important to me. I think an Odyssey battery would have served my purposes just fine. |
01-10-2011, 08:17 PM
#2 |
What could go wrong?
Oddometer: 4,960
Other than weight what other advantages are there... as that's a lot of dosh.
Mines just about toast and I should think about what I am going to buy as a replacement.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd anonny screwed with this post 01-10-2011 at 08:22 PM |
01-11-2011, 10:43 AM
#3 |
Oddometer: 8,168
A big one is not losing the battery if it sits. I have some vehicles that don't get driven enough (an RV) and get sick and tired of worrying about it's two large batteries. These would be a godsend and in the long run, save me money.
01-11-2011, 11:52 AM
#4 | |
Oddometer: 140
Some advantages of the Lithium Ion Phosphate batteries are listed below for reference:
01-11-2011, 01:05 PM
#5 |
Oddometer: 1,155
thinking about an upgrade for my bikes as well
This would make more sense on my wr250r, but every bit of weight is less for me to pick up off the ground when the bike slides out from under me in the snow.
2008 WR250R(Anywhere) 2009 Versys |
01-11-2011, 10:01 PM
#6 | |
Oddometer: 2,012
Tim in Burien, WA '05 R1200GS (Sleeping in Germany) '03 F650GS '03 Wing '01 ST1100 |
01-11-2011, 10:23 PM
#7 |
Oddometer: 1,309
Put one in my R1200GSA and after the same aggrevation as mentioned I ended up adding a couple washers to each side to so the main wiring harness end would be flush. I have 2 other connections to each side and the recess made it that much more difficult. I bought the battery for the lightness/extra CCAs but it would make this much easier if the terminals were flush with the top. I'd sent my issues to Shorai
so maybe in later batteries they'll make a change.
"Not all those who wander are lost" J.R.R. Tolkien |
01-12-2011, 12:30 PM
#8 |
Oddometer: 549
A tip to help with the nut sitting too low to catch- find some small plastic tubing like that used for battery breathers, cut off around 1/4" or 3/8" section, and slide that under the nut. It will work like a little spring and will hold the nut up against the underside of the terminal.
01-14-2011, 12:53 PM
#9 |
Ridin'
Oddometer: 749
![]() couldnt you shim the top of the battery to lower the cog? |
01-16-2011, 06:19 AM
#10 |
Oddometer: 140
01-16-2011, 08:07 PM
#11 |
Minister Funny Walks
Oddometer: 1,016
Just put the LFX18-BS12 Shorai into my 2005 12GS. Looks like a similar package to your "R".
Great battery and it's incredibly light! I'm surprised how robustly it cranks the bike. For a few years now I've had to be careful about leaving the high beam or the heated grips on for cold start. On colder mornings it would have to catch on the first few turns or it was time for the jumper cables. This is with two different high quality "gel" replacement batteries that quoted higher CCA than stock, plus constant maintenance with a battery tender! Now, fuggedaboudit. No worries about what accessories may be on, and I won't go to bed paranoid about whether or not I hooked up the tender. This is the best farkle I've bought in a long time. ![]() And no, my alternator charges just fine. Checked it out...
"Son, I thought by now you would have run out of stupid." |
01-17-2011, 06:56 AM
#12 |
Even my posing is virtual
Oddometer: 2,513
Foam
It looks like closed cell foam which doesn't absorb water.
[QUOTE=Dauntless;14907966] snip Further, the foam pads that shim the battery are exposed to water spray. I don't know how they will hold up or if they will retain water like a sponge.
04 Toyota Sienna, new wipers for 2011!! Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!! Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway, Website - http://www.apormc.com/ Vids - http://www.youtube.com/user/Motoriley?feature=mhum |
01-17-2011, 07:04 AM
#13 |
Just Me...
Oddometer: 3,597
![]() I'm getting one for my Suzuki GS1100 AND the KLR. The shorai equiv for my GS is supposedly 16.91 lbs lighter, but I'm thinking it is 6.91 lbs lighter. Still, that's a good bit of weight savings.
Txt msg with Dan right after he was paralyzed: Me: Hey Dan-O. Just wanted to say howdy and Love ya! Dan: Howdy and Love you too. Doin' good and feeling good. Me: Give 'em hell, little Bro! Dan: Roger that. East Coast Rider screwed with this post 01-18-2011 at 05:25 AM |
01-19-2011, 11:30 AM
#14 |
Oddometer: 50
Go on a diet, its cheaper than a new battery :-)
01-19-2011, 12:10 PM
#15 | |
I have little to say
My RV chassis batteries are 800 CCA size in parallel, the house batteries are four 6 volt deep cycle batteries in series-parallel... All the RV batteries are OE (11 years old) and still provide more than enough current to fire up the Cat diesel engine on a cold morning. Any battery needs maintenance...both mechanical and chemistry maintenance to provide good service. Get a smart charger and keep your batteries charged and sulfate free...they'll last years longer if you do. |
