01-10-2011, 07:33 PM
#1 |
ADV rider wannabe
Oddometer: 734
Malfunctioning F800GS
We are currently in Trujillo, Peru having trouble with both of our F800GSs. We were driving on the highway and both our bikes felt underpowered. There was also a weird ticking noise on hard throttle openings (like passing a truck). We had recently filled up with gas in a small town so we thought that maybe the gas was bad. We were in the middle of the desert so we put our spare (presumably good) gas into the tanks to try and dilute the bad gas. This seemed to improve the situation a bit but it did not fix it. We got the bikes to a safe location where we are currently staying.
the bikes sound terrible and now stall or have troubles starting. We checked the air filter and in the compartment there was a bit of oil. We cleaned that up and replaced the air filter. the bikes still sound terrible and the oil has returned after taking the bike for a short spin. As far as we know there is no BMW dealer in Peru and we are worried about driving our bikes anywhere and doing further damage. We are also worried about letting some random mechanic here start stripping the bikes if the problem runs deep. No warning lights are on and both bikes are acting up in similar ways. Any ideas? Summary of issues: Underpowered Oil in air box difficult to start stalling Generally sounding like sh*t
ADVrider Canada to Argentina 2010 RR | BLOG Bella Coola and Beyond 2012 RR WABDR 2012 RR |
01-10-2011, 07:39 PM
#2 |
MoveAlongNothingHere
Shitty fuel.
~MK~ F800GS AMA-262640 |
01-10-2011, 07:53 PM
#3 |
Oddometer: 544
yes, sounds like bad fuel. Seeing as its both bikes........
before you have anyone pull the bikes apart, drain the tanks and put in fresh fuel. Will most likely solve your problems |
01-10-2011, 08:02 PM
#4 |
Broken Roadie
Oddometer: 2,787
If this is happening exactly the same to two separate bikes, then I agree - bad gas. Drain the tank completely and replace gas from different source would be a guess.
The odds of two bikes having the same failure without outside influence are slim.... I'm sure you know that. what's your altitude? I'm going to a good BMW dealer first thing AM anyways, and will show a tech your post... will see what they say and let you know. |
01-10-2011, 08:04 PM
#5 |
Oddometer: 263
Also, try to find a fuel injection system cleaner such as Seafoam or Techron. If Trujillo is a big enough city, you ought to be able to find something.
01-10-2011, 08:05 PM
#6 |
Not so nOOb
Oddometer: 307
Sounds like fuel two bikes at the same time. I agree with everyone drain the fuel tanks and put in good gas.
Our famous last words "It doesn't look too bad". 08 KTM 450 EXCR 2010 BMW F800GS Rick |
01-10-2011, 08:09 PM
#7 |
In a parallel world
Oddometer: 800
I'm not one to attribute every mechanical malady to bad gas, but it sure sounds like you got a batch if it happened soon after a fill-up and both bikes have similar symptoms. The culprit could be water or low octane fuel (pinging might be what you're hearing on hard throttle) or something other than gasoline came along in your last fill-up. My guess is that your 'fuel' was diluted/contaminated with something cheaper. Since you're near sea level the bikes will want high-octane fuel to prevent pinging.
Your best bet is to empty the tanks and re-fill with the best available fuel. I'd do one bike at a time in case the local gas is worse, but you're in a large city, so good gas shouldn't be hard to find. I can't explain the oil in the air filter, unless it's been regurgitated from the crankcase by the poor running engines. I don't know the GS8 configuration that well, but my former KLRs and my DR-Z pass oil fumes into the airbox to be burned, and if something's amiss I've found oil in there. Next, find all the auto parts stores you can and look for Seafoam. Their website doesn't list dealers in South America, but Pep Boys, Kragen/O'reilly, Ace Hardware, Checkers, CarQuest and Napa all carry it in the US. Get a couple cans for each bike and dose regularly to keep problems at bay. HTH and good luck. Remember...it's all part of the adventure |
01-10-2011, 08:17 PM
#8 | |
Oddometer: 386
![]() http://www.bmw-motorrad.com.pe/lam/es/index.html BMW Motorrad Perú Automotores Gildemeister Perú S.A. Dirección: Javier Prado este 5535 La Molina, Lima Ciudad: Lima Teléfono central: (511) 617 9750 Fax:(511) 617-7777 |
01-10-2011, 11:58 PM
#9 |
Big red dog
Oddometer: 1,322
My vote is on low octane. If it were debris or gunking, it would be a hell of a coincidence for it to affect both bikes simultaneously. Water, which sits at the bottom of the tank, gives you an instant (and most likely permanent) engine stall.
Although I love my 800, a bike with a thirst for 95RON (or 91 if you had the dealer adjust it for that) can be a liability in the second and third world, where fuel is often considerably lower than that. Low octane gives you funny noises under load (pinging / detonation), shit power, and the engine will struggle so much to adjust the ratio right you'll get either massive exhaust overheat or thick palls of smoke out the back (depending which way it goes with mixture to try and compensate).
"It's cunnilingus and psychiatry that's led to this" - Tony Soprano 10 F800GS |
01-11-2011, 02:57 AM
#10 |
Citation Collector
Oddometer: 403
Why would there be oil in the airboxes though?
"An expert is someone who has made every mistake possible within a very narrow field of inquiry" -Niels Bohr |
01-11-2011, 03:46 AM
#11 |
Oddometer: 266
I'm not 100% sure but I would think that the F8 has a similar scavenging/PCV circuit as any modern, emissions regulated motor does.
I'm working overseas right now so I can't check mine, but I would bet that (to differing degrees of course) most F8's will have some sort of oil residue in the airbox. I'd be more worried about fixing the sputtering and stalling first, then keep an eye on the oil levels after it was running correctly. Hope you get it sorted out - my money is on bad fuel as well. Just my $0.02.
My apologies to the meek and the Earth they will not inherit. |
01-11-2011, 07:32 AM
#12 | |
Clear Clowdy Trails
Oddometer: 3,106
Trujillio is at sea level.
01-11-2011, 07:38 AM
#13 |
Not so nOOb
Oddometer: 307
Pre ignition can cause exsive oil in the air box caused by low octane fuel on heavy loads.
01-11-2011, 08:07 AM
#14 |
ADV rider wannabe
Oddometer: 734
Muchas gracias!
Thanks to every one for your input. We'll now drain our tanks, put 97 octane gas in one of the bikes than put a octane booster and a injector's cleaner.
Will report back witht the results. Keep the advice coming in the meantime. One thing that I forgot to mention is the oil leaking/running down most likely coming from the air-filter chamber's draining hose (usually used for letting fumes scape, i'm guessing?). This is happening to both bikes. The 'metal' pounding noise coming from the bottom part of the engines, where the letters 'BMW' are (bellow the twin cylinders) on the left side (chain and sprockets side). Cheers guys, Alberto.
01-11-2011, 08:19 AM
#15 | |
Romanian Trailbiker
Problem cause = bad gas. Solution = drain + put in good gas + injector cleaner. 97+octane booster isn't a bit of overkill? :)
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon. |
