01-29-2011, 05:06 PM
#16 |
Smile 4 Miles
Oddometer: 1,375
Video of dimmer
Installed using 3M strong plastic velcro. This dimmer is exactely what I was looking for since installing these super bright LED's, LED's are way too bright when it gets dark outside, the only other option would be pointing the beam downwards but then what would the lights be good for?
tallguy-09 screwed with this post 02-01-2011 at 10:37 AM |
01-29-2011, 06:02 PM
#17 |
Oddometer: 1,812
Thanks Tallguy-09...was that German Satellite radio
Adventurer transitioning from 4x4 to 2x1 '07 G650Xch - Under Mod-struction |
01-30-2011, 05:21 AM
#18 |
This looks like a great product.
2007 FJR1300A - 150K Miles Club If you see my bike on a trailer call 911 TBA 904, IBA 27221 |
02-04-2011, 10:44 AM
#19 |
Smile 4 Miles
Oddometer: 1,375
I like the clean install of only having one switch and the dimmer controller away from the handlebar better than the potentiometer/switch combination. For me two brightness settings with the switch and a 3rd. with Hi-Beam is sufficient.
02-07-2011, 08:11 PM
#20 |
Lost ADVR
Oddometer: 546
Can you tell me Where/Name to get the dimmer switch?
I like this module also but been looking for waterproof dimmer also.
ChildsPlay Riding ChildsPlay Racing Of all the roads you take, Make sure a few of them are dirt. |
02-11-2011, 06:26 PM
#21 | |
Oddometer: 62
02-14-2011, 06:59 AM
#22 |
Oddometer: 182
We have a safe rider rebate on our P3Lights and Photon Blasters.
In order to encourage rider training, we offer a $20/set rebate on these systems: http://www.lights.skenedesign.com/Rebate.shtml
________________________________________________________________________________ Visibility Lights - P3 Lights and Photon Blaster High Intensity Motorcycle Visibility Lighting Systems: Be Smart - Be Seen |
02-15-2011, 08:28 PM
#23 |
Smile 4 Miles
Oddometer: 1,375
Received controller with updated software in exchange for the first one, now also working great on the BMW (R1200GS)
with delayed hi-beam on after ignition is being turned on (basically you have more time to enter programming mode...) The dimmer now has a wider adjustment range at the lower LED brightness levels. I'm not affiliated with the seller but that's really a nice product that intelligently fills a market niche.
02-15-2011, 10:28 PM
#24 |
2 Many Motersikles
Oddometer: 748
Rocket Moto proudly sells and offers professional installation of all Skene Design safety lighting products, for over a year, now.
Terrific, innovative products from great company.
=Adam= Like us on Facebook -- Follow us on Twitter PM us for your personal ADVRider discount code to use at RocketMoto.com Autocom | Clearwater Lights | Sena Bluetooth | Scala Rider Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design |
03-31-2011, 07:37 AM
#25 |
Oddometer: 182
I have customers asking where to get the auxiliary switch shown to the right of your stock switches in your photo below.
Do you have a recommended source for this? Thanks
03-31-2011, 08:14 AM
#26 |
Smile 4 Miles
Oddometer: 1,375
Hi Jerry:
I got it from here in the US: http://www.cyclenutz.com/Mini-Handle...tch_p_210.html Didn't like the cross lines on the switch so I took a sharp knife an removed them... also you can re-route the cable so it exits on the bottom. The same switch I've seen in red in Germany at Detev Louis: http://www.louis.de/_4036fd065f41a26...artnr=10032918 I like your controller, works very well, thanks for a great product. |
08-04-2012, 01:35 PM
#27 |
Oddometer: 182
We have updated our popular IQ-170 Intelligent Lighting Controller with our unique ALERT feature. Simply double-tap your brakes to rapidly flash your auxiliary lights on & off for a second or so to ensure that you are noticed by oncoming traffic.
We have carried this feature over from our Photon Blaster front visibility lights, where it has received an extremely positive response. Note that the flashing rate and sequence is very different from a normal high beam flash, so it will not be confused as such. The new model offers the same LED lamp programmability as the original IQ-170, allowing you to set the brightness of your auxiliary LEDs to any brightness and rapidly switch between three different pre-programmed values, with a high beam override. It is compatible with virtually all aftermarket LED lamps of up to 60 watts power consumption. More details plus a video of the ALERT feature may be found here.
________________________________________________________________________________ Visibility Lights - P3 Lights and Photon Blaster High Intensity Motorcycle Visibility Lighting Systems: Be Smart - Be Seen jskene screwed with this post 08-04-2012 at 01:59 PM |
08-09-2012, 08:00 AM
#28 |
Oddometer: 182
Some of our customers have asked whether our IQ-170 LED dimmer will work with their particular brand of LED. While we haven't tested every LED brand, we have tested our controller with several of the more popular brands, and have seen no issues.
Some LEDs can generate voltage spikes when they are turned off, and these spikes could potentially cause damage to the controller or the LED. Our controller's design includes circuitry that limits the voltage of these spikes, should they occur, minimizing the chance that they will cause any problems. Many of our controllers have been in use since they were introduced last year and we have yet to see an instance where there was an incompatibility.
01-31-2013, 08:34 AM
#29 | |
Oddometer: 22
Noob Question
Any help you can offer would be super helpful Thanks in advance for your info !!!
Your not lost until you're out of gas and money!! |
01-31-2013, 08:47 AM
#30 |
Oddometer: 4,900
Hello Jerry,
I sent an email to the support address given on your website, please let me know if you received it. Best regards, Lukas
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
