03-22-2011, 01:35 PM
#196 | |
shifty charactor
Oddometer: 1,559
Little tough
But you might try this. If you think you cable is in good shape then... Take the tank off and route the cable in the most "open air" way you can...set your tank backwards on the seat to hook up a gas supply and fire it up. Then if it works properly you've just found your problem... You were binding somewhere... Try it all again. Really doesn't matter what routing you have as long as it's long enough and doesn't hang up. My particular routing is from the throttle, slung under and along the bars, through the center of the instument cluster to the left side of the frame. Along the backbone, and eminating from the tank's tunnel right down the the carbs. Of course I have a STD and a STD cable, but I do have lower bars than stock. It makes some pretty good bends but doesn't hang up like yours seens to be. With the cable disconnected at the carb, operating the throttle, do you perceive any resistance?
too many... I have completely lost count and here's my channel... http://www.youtube.com/user/2manyrides?feature=mhsn#p/u |
03-22-2011, 02:11 PM
#197 |
XS650 Allroads Traveller
Oddometer: 5,477
Handling;
After checking & replacing the swingarm bushes & steeringhead bearings, the next big one is to replace the front fork springs with progressive types & progressive sprung rear shocks [good quality ones]. Then you move onto tyres, my preference is; Road type [black top] - Metzler M880 front & rear [found they work well even on dirt], General dirt riding;- K70 Dunlop [19"] on the front & K460 Dunlop [16"] on the rear. Cheers Baza
1981 XS650SH "Tourer" [ For Sale - when / maybe?], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' www.aussiegreyghost.smugmug.com Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
03-22-2011, 03:07 PM
#198 | |
shifty charactor
Oddometer: 1,559
Us cheap SOB's cut a 1" long piece of 3/4" galvanized pipe and shove it in on top of the stock spring!
03-22-2011, 04:49 PM
#199 | |
Oddometer: 158
03-22-2011, 04:54 PM
#200 |
Oddometer: 158
Handle bars and high RPM
I aggree with "manyrides"
Take off the tank and let the cable hang and try it. I've had a few xs's that where very fusy about cable routing and would rev just by turning the handlebars.
03-22-2011, 05:04 PM
#201 |
Oddometer: 158
03-22-2011, 07:07 PM
#202 |
EAT WINGS OR DIE
Oddometer: 57
i hate to admit it and this is very embarrassing, but I've never taken the tank off of a bike.
is it easy? i am the ultimate newbie. i have the clymer and the other manuals, and i'm not intimidated by it or anything, but is it a significant job? am i going to have to resync my carbs or anything?
Kid's like us will be alone forever, Kid's like us will be alone together. |
03-22-2011, 07:15 PM
#203 |
Oddometer: 478
its pretty easy, you wont have to mess with your carbs or anything like that.
03-23-2011, 01:38 AM
#204 | |
Oddometer: 5,477
Cheers Baza
03-23-2011, 01:40 AM
#205 | |
Oddometer: 5,477
Cheers Baza
03-24-2011, 09:08 AM
#206 | |
shifty charactor
Oddometer: 1,559
I imagine you've done it by the time I write this but... Super simple to do. One 10mm bolt at back, two gas lines. Detach lines from petcocks, remove bolt, lift tank above bolt's post, wiggle rear of tank while slowly pulling back. Thus sliding receivers off the front gromets.
03-24-2011, 10:18 AM
#207 | |
EAT WINGS OR DIE
Oddometer: 57
03-26-2011, 01:22 PM
#208 |
Oddometer: 5,477
Took these photos on Saturday, view from the verandah
![]() looking north-west toward Bowning ![]() looking south-west toward Wee Jasper Cheers Baza
03-27-2011, 05:49 AM
#209 |
Oddometer: 1,038
03-27-2011, 02:29 PM
#210 | |
Oddometer: 5,477
Cheers Baza
