Old 10-29-2011, 05:33 AM   #451
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,065
Xt 600 Frame Power 650!!
Originally Posted by hunter_greyghost View Post
Have welder can do! the local blokes call the one on 'Kenny' - a "dozer blade"
How would an XT600 frame work? a bit heavier construction to accomodate the extra weight of the XS motor.
Cheers
Baza
Baza, A XT 600 frame would be good. If you had a title for the frame you go right down the road with it!! Here in Ny no one will know what motor gos in what frame. If you set-it up right, upside forks, "Works Shock", and a big tank would go straight on!!!Just need some time and $$$$$ ED
BIG ED XT FAN is offline   Reply With Quote
Old 10-29-2011, 02:24 PM   #452
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 5,660
Originally Posted by Growl View Post
Baza... What gearing are you running?
17 tooth front cog, [standard]
When towing trailer;
38t x 18" rear [D606 knobby (Dunlop)] for knarley country [hilly]
34t x 16" rear [K460 enduro (Dunlop)] for dirt / tar - in general
Been trying to get hold of some 36 tooth cogs to give me some further variety, have used 30/32 tooth cogs on tar trips without the trailer
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - when / maybe?], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project'
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is online now   Reply With Quote
Old 11-05-2011, 02:10 PM   #453
hunter_greyghost
Oddometer: 5,660
Heading to 'Trout' rally - 5/6 November, up in the alpine country south of here, will post photos.
Cheers
Baza
Well folks, the mighty 'Kenny' was a DNF for this one, made it to the mountains then a slipping clutch turned into a nightmare,
made it back after some big favors from a mate @ Yass who rescued us from the side of the road,
result will probably be RS clutch plates @ least but @ moment I'm recovering from badly twisted leg - courtesy of a bad tempered bike, fell over getting it off the trailer @ home
Cheers
Baza
Old 11-14-2011, 07:16 AM   #454
hunter_greyghost
Oddometer: 5,660
Cheers
Baza
Gunna begin surgery on 'Kenny' [clutch burn-out] this week, keep ya posted
Cheers
Baza
Old 11-14-2011, 10:50 AM   #455
Reverand Roadblock
Snow is bad. Mm'kay?
Reverand Roadblock's Avatar
Oddometer: 1,853
Is the swingarm bearing conversion from Mikes XS any good or should I stick with the bushings?
Mr. Greyghost; Hope your leg heals up soon!
ADV relay rider: New York
Reverand Roadblock is offline   Reply With Quote
Old 11-14-2011, 12:00 PM   #456
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,070
I've never done it on an XS but I have done it on several older bikes that had updated kits available and my 2 cents is that it you're going to ride it hard then it's absolutely worth it. If you're just going to cruise and puttter then just maintain and lube your original stuff. Of course that caveat never stopped anyone from upgrading if theyreally wanted to.
FloridaSteve is offline   Reply With Quote
Old 11-14-2011, 12:09 PM   #457
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,560
swingarm
I did the upgrade to needle bearings and my friend used the bronze or brass upgrade. I had used the fiber ones before in a previous fixup of the same bike. (many miles on this one... over 200,000?)
Any way, those fiber ones wear big time even with lube. You just don't want any slop in there.
Before the needles, I was in a bit of a wabble stage with reguards to hands free driving. (take your hands off the bars for a moment)
With needles in the swing, and the upgrade to tapered in the steering head, I was once more on a straight and narrow track.
Both sets came from mike's.
Good luck, I think it's worth it no matter what/how you drive!
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 11-14-2011, 12:31 PM   #458
FloridaSteve
Oddometer: 2,070
You know what, 22manyrides makes an excellent point and I've changed my mind on this. It really does help just as much in holding a line in a straight line as it does in the turns and shame on me for forgetting that. Change my answer to a solid YES either way.
Old 11-14-2011, 01:25 PM   #459
Reverand Roadblock
Oddometer: 1,853
Awesome. Thanks much!
Old 11-14-2011, 03:04 PM   #460
Garbln
Oddometer: 423
[QUOTE=Reverand Roadblock;17302144]Is the swingarm bearing conversion from Mikes XS any good or should I stick with the bushings?
Ether the needle or brass bushing conversion is better than the stock bushings! While your at it, do the tapered head bearings too. You won't be sorry.
Garbln is online now   Reply With Quote
Old 11-14-2011, 05:39 PM   #461
hunter_greyghost
Oddometer: 5,660
[QUOTE=Garbln;17303746]
Confirmed with Brass & Tapered, handles the rough with the smooth in style!
Cheers
Baza
Old 11-14-2011, 07:11 PM   #462
Gham
Gham's Avatar
Oddometer: 774
I did the brass and tapered head bushings and it made a remarkable difference,but mine were shot(as most are)Got them from Mike's
In a government of laws, the existence of the government will be imperiled if it fails to observe the law scrupulously. Our government is the potent, the omnipotent teacher. For good or ill, it teaches the whole people by its example. If government becomes a lawbreaker it breeds contempt for law: it invites every man to become a law unto himself. It invites anarchy.-Justice Brandais
Gham is online now   Reply With Quote
Old 11-15-2011, 02:00 PM   #463
SpeedFourJoe
Oddometer: 32
This is my '79 Special that I just did some work on. I used the All Balls tapered steering bearings and TC Bros. Choppers bronze swingarm bushings, and recommend them both.
SpeedFourJoe is offline   Reply With Quote
Old 11-15-2011, 02:39 PM   #464
hunter_greyghost
Oddometer: 5,660
That's very nice original looking bike, hope you enjoy it, do you do much travelling on it?
Cheers
Baza
Old 11-15-2011, 03:28 PM   #465
SpeedFourJoe
Oddometer: 32
Cheers
Baza
Thanks! It will mainly be used just for country road exploring and fun, but I'd love to do some long trips on it sometime.
Times are GMT -7.   It's 03:30 PM.
