Old 11-15-2011, 05:25 PM   #466
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,763
Originally Posted by Reverand Roadblock View Post
Is the swingarm bearing conversion from Mikes XS any good or should I stick with the bushings?
Mr. Greyghost; Hope your leg heals up soon!
Did a similar treatment to my Honda CB750. Huge difference. Would also do steering head bearings too if at all possible. Those combined with progressive springs/shocks has yielded the best handling motorcycle I have ever owned.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 11-15-2011, 05:45 PM   #467
1f2frfbf
full-time fool
Oddometer: 42
I updated (err, well... still updating, really) my bike in bits and chunks. I can say the biggest single change came with the bronze swingarm bushings. Nothing else came close. More power here and there with carbs and pods, better handling with shocks and bearings, more reliability with ignition and charging upgrades, so on, so forth. But: New bushings = totally new and better handling. I dunno how the needle bearings compare, but the bronze bushings upgrade should be the first thing you change.
In less than optimal circumstances,
creativity becomes all the more important.
1f2frfbf is offline   Reply With Quote
Old 11-15-2011, 06:06 PM   #468
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,275
Originally Posted by SpeedFourJoe View Post
This is my '79 Special that I just did some work on. I used the All Balls tapered steering bearings and TC Bros. Choppers bronze swingarm bushings, and recommend them both.
Nice Special with good up-gradage.
KOKA
MSrider is offline   Reply With Quote
Old 11-17-2011, 02:12 AM   #469
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,575
Just found half a circlip on the sump plug while dropping the oil out,
motor now coming out for a good look-see, easier to work on anyway!
keep you posted [with photos]
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 11-22-2011, 01:46 PM   #470
hunter_greyghost
Oddometer: 8,575
Photos of progress on the motor surgery later today
Cheers
Baza
Old 11-23-2011, 01:46 AM   #471
hunter_greyghost
Oddometer: 8,575
As promised; photos of motor surgery,
two half washers [on left] found on sump plug
Culprit is on the left [right photo] - has been squashed flat allowing the collet washers to fall out!
circlip pliers show position of kickstart gearing behind clutch basket
MikesXS bottom filter;- worth it's weight in gold!
Stuffed clutch plates, guess it happens after 45k hard kilometers!
made of steel & works a treat! bashplate shows 'war wounds'
K460 Dunlop [16"] - my favourite tyre, others used Dunlop 606 [18"], Chenshin [19"] & Metzler ME880 [16"]
hunter_greyghost screwed with this post 11-23-2011 at 01:57 AM
Old 11-25-2011, 06:52 AM   #472
hunter_greyghost
Oddometer: 8,575
All the gear is on the way from MikesXS, so for the time being I'm hooting around on my '81 Special 'Tourer',
might even stick the trailer on behind for next weekend's rally
Cheers
Baza
Old 11-25-2011, 05:47 PM   #473
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,839
That is really nice looking. Much less 80's factory chopper looking than most Specials I've seen. Are the bars stock? Looks like aftermarket pipes? Any other details you can share?
cjbiker is offline   Reply With Quote
Old 11-25-2011, 06:15 PM   #474
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,659
I'd jump the gun for him and say stock pipes, aftermarket bars.
Very clean bike.
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 11-25-2011, 06:17 PM   #475
SpeedFourJoe
Oddometer: 45
Thanks! Those are Bikemaster "European" bars. The pipes are stock. It has a Saddlemen seat cover, fork gaiters for a Triumph, an XJ750 front rotor, braided brake lines, and the chain guard is painted black. Other than that it is mostly stock, and still has the original paint on the tank and side covers. Here is a link to the photo set of the work done on it. http://www.flickr.com/photos/speedfo...7627478817247/
SpeedFourJoe is offline   Reply With Quote
Old 11-25-2011, 06:29 PM   #476
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,839
Thanks! I just looked through the photo gallery. Excellent job! I have been looking for a good deal on a standard, but after seeing what you were able to do with yours with just a few minor changes, I may take another look at the more common specials that I see for sale around here.
cjbiker screwed with this post 11-25-2011 at 06:41 PM
Old 11-25-2011, 07:12 PM   #477
SpeedFourJoe
Oddometer: 45
They sure are easier to find. One suggestion is to look for a '78 or '79 Special. Basically, they are about half way between a standard and the '80 and up Specials. They still have the side hinged seat, metal side covers, the BS38 carbs, and a standard style tail light, so easier to make a roadster from.
I have a project '75 standard, and when I first got this '79 I was really surprised how close they were, and I actually like the looks of the slimmer Special tank better. While I prefer the 18"/19" spoke wheels on the '75, the overall height of the 16" rear wheel is about the same as the 18". It has more side wall than the 18", so a little heavier, but handles fine. It feels like my SR500 on the backroads.
Old 11-26-2011, 03:33 AM   #478
hunter_greyghost
Oddometer: 8,575
I was surprised how well behaved a Special is on dirt, given the right tyres of course!
I run Dunlop K460 x 16" on rear, Dunlop K70 19" on front, great combo for all round riding, tar & dirt
Cheers
Baza
hunter_greyghost screwed with this post 11-26-2011 at 05:07 AM
Old 11-27-2011, 02:27 PM   #479
Reverand Roadblock
nobody
Reverand Roadblock's Avatar
Oddometer: 1,903
In addition to the swingarm and steering head bearing upgrades, what other improvements do you folks recommend? I'm putting a shopping list together.
ADV relay rider: New York
Reverand Roadblock is offline   Reply With Quote
Old 11-27-2011, 03:40 PM   #480
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,561
Anybody in AZ looking for a clean XS?
http://tucson.craigslist.org/mcy/2698350575.html
Not affiliated, just saw it today, and can't afford to buy it so I thought I'd post it up here.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Times are GMT -7.   It's 12:43 AM.
