Old 03-22-2012, 07:52 PM   #751
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,408
Been 80+ degrees all week and we have been riding.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 03-22-2012, 08:33 PM   #752
redfishguide
Old Dirt Biker
redfishguide's Avatar
Oddometer: 477
Wow really love your hack Do you have a build thread somewhere? Looks very similar to something I have been considering.
Thanks,
Jack
redfishguide is online now   Reply With Quote
Old 03-22-2012, 11:06 PM   #753
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,424
XS650 hack
Lookin' good, what are those tyres you have on it? Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 03-23-2012, 05:50 AM   #754
RFLIVES
Oddometer: 70
Thanks,
Jack
http://www.xs650.com/forum/showthread.php?t=5650
Tires are maxxis dtr-1 cd5's
RFLIVES is offline   Reply With Quote
Old 03-23-2012, 12:49 PM   #755
hunter_greyghost
Oddometer: 8,424
Don't think they're available in Australia, good tyre?
Cheers
Baza
Old 03-23-2012, 03:39 PM   #756
RFLIVES
Oddometer: 70
Hell if I know they push around the garage real good
Old 03-23-2012, 05:58 PM   #757
hunter_greyghost
Oddometer: 8,424
Oh dear, let us know what they're like when you get it into some action
look an interesting pattern though, good luck with it
Cheers
Baza
Old 03-24-2012, 04:27 PM   #758
Honda Scoot
My First Gold Chain
Honda Scoot's Avatar
Oddometer: 364
Two years ago it seriously dusty. Good to see it all cleaned up.
Honda Scoot is offline   Reply With Quote
Old 03-24-2012, 07:52 PM   #759
ThomasVolomitz
New Old Stock
Oddometer: 4,408
Good to hear from you Duane. It took two years to get it right but now it's a blast.
Still Riff Raff
Old 03-26-2012, 03:16 PM   #760
hunter_greyghost
Oddometer: 8,424
Clutch Springs
Put a new clutch in 'Kenny' last time I got into his guts but I'm not happy with the performance factor, noticed a bit slip up the hills the other weekend, + feels light for H/D springs
Got them from MikesXS, New Kevlar fibre plates & steels, also hexhead Allan screws to replace the Phillip heads [std]
Thinking of trying out some H/D Barnett jobs from 650Central, don't want to have slipping clutch next time I've got the trailer behind.
Anyone recommend any thing else?
Cheers
Baza
Old 03-27-2012, 10:26 AM   #761
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,362
A little progress on the XS this week. Mounted a TrailWing on the rear and found a cheap set of shocks off a Triumph Scrambler that will give me a couple more inches of ride height.
A little final assembly and some wiring and it should be ready for a test ride.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 03-27-2012, 03:40 PM   #762
hunter_greyghost
Oddometer: 8,424
That Trailwing looks almost identical to the Dunlop K460 I use!
120/90x16"
Cheers
Baza
Old 03-28-2012, 01:00 PM   #763
dungspreader
King of the Heap
dungspreader's Avatar
Oddometer: 451
PMA and reg/rects
Hello XS nutcases everywhere .
I have been tinkering with a permanent magnet alternator and now have it installed on the bike .The only part that I am missing is a five wire regulator/rectifier.
HOWEVER , I do have a couple of reg/rects from the later specials , which have seven wires .
Does anyone know if they can be used with a PMA ?
What I had in mind was just insulating the green and brown wires [ which would normally supply 12v to the rotor ] and hooking up the red and black to the battery .The three whites would be connected to the alternator.
I might just give it a go for shits and giggles - "what could possibly go wrong ?".
I thought WanKing was a town in China 'till I discovered Adventure Rider
dungspreader is offline   Reply With Quote
Old 03-28-2012, 06:58 PM   #764
hunter_greyghost
Oddometer: 8,424
No pain - no gain, hope there's no smoke either
There's wiring diagram on one of the threads somewhere, I'll see if I can find it
Found it - hope that helps
Cheers
Baza
hunter_greyghost screwed with this post 03-28-2012 at 07:13 PM
Old 03-28-2012, 08:39 PM   #765
retiredgentleman
Oddometer: 115
That will not work. The stock regulators and a PMA regulator operate on totally different principles.
With the stock system, when the alternator produces higher voltage as the rpm goes up, the regulator reduces the voltage going to the rotor and this keeps the output voltage at around 14.3 volts, which is safe.
With the PMA when the alternator voltage starts to exceed 14.3 volts, there is no way to reduce the rotor voltage because it does not have any voltage at the rotor. The PMA just keeps generating its full output as the rpm goes up. Once the voltage goes above 14.3 volts, the PMA regulator starts directing the excess current to a resistor as a dummy load. The resistor gets rid of the extra current in the form of heat. The PMA is a bit like driving your car with one foot fully down on the gas and one foot on the brake to control the speed.
If you do run your bike with the PMA and the stock regulator, the output voltage to the bike and battery could go way up to 20 or more volts, which will likely cook your ignition/lights etc............................oh yeah, smoke is a definite possibility
retiredgentleman is offline   Reply With Quote
Times are GMT -7.   It's 11:38 PM.
