Old 03-28-2012, 09:10 PM   #766
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,560
Is that resistor also called a zeon diode or something like that? vaguely remember a unit on old bikes I had in the past
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 03-29-2012, 10:48 AM   #767
dungspreader
King of the Heap
dungspreader's Avatar
Oddometer: 451
Originally Posted by retiredgentleman View Post
That will not work. The stock regulators and a PMA regulator operate on totally different principles.
With the stock system, when the alternator produces higher voltage as the rpm goes up, the regulator reduces the voltage going to the rotor and this keeps the output voltage at around 14.3 volts, which is safe.
With the PMA when the alternator voltage starts to exceed 14.3 volts, there is no way to reduce the rotor voltage because it does not have any voltage at the rotor. The PMA just keeps generating its full output as the rpm goes up. Once the voltage goes above 14.3 volts, the PMA regulator starts directing the excess current to a resistor as a dummy load. The resistor gets rid of the extra current in the form of heat. The PMA is a bit like driving your car with one foot fully down on the gas and one foot on the brake to control the speed.
If you do run your bike with the PMA and the stock regulator, the output voltage to the bike and battery could go way up to 20 or more volts, which will likely cook your ignition/lights etc............................oh yeah, smoke is a definite possibility
Yep , that's right .But with regard to regulating the voltage ; I wondered whether the reg / rect would restrict the voltage to the brushes , or whether it just sent 12v down there all the time and then turn the excess into heat [ like a five wire reg/rect would do ] .
ANYWAY - I gave it a shot and the results were 13.5 volts at 1200 rpm , rising to 17.5 volts at 3500 rpm . After that I didn't go any further .
SO , the reg/rect off a later special will not work on a PMA system unless you add a voltage regulator as well .
I thought WanKing was a town in China 'till I discovered Adventure Rider
dungspreader is offline   Reply With Quote
Old 03-29-2012, 10:56 AM   #768
dungspreader
King of the Heap
Oddometer: 451
Cheers
Baza
Hi Baza , cheers for the wiring diagram .
What you are referring to is a Zener Diode . It is a crude voltage regulator that just turns excess voltage into heat , you mount it on a heatsink . [ A finned plate on Triumphs and BSA , the alloy footrest brackets on a Norton Commando ].
They work , but they are expensive and you need a rectifier as well .
Modern reg/rects are a better alternative .
I guess I'm just going to have put my hand in my pocket and buy one !
Old 03-29-2012, 12:24 PM   #769
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,420
Cheers
Baza
I believe that it is commonly known as a flux capacitor.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 03-29-2012, 04:36 PM   #770
Mr. Whipple
Mr. Whipple's Avatar
Oddometer: 21
Put a new clutch in 'Kenny' last time I got into his guts but I'm not happy with the performance factor, noticed a bit slip up the hills the other weekend, + feels light for H/D springs
Thinking of trying out some H/D Barnett jobs from 650Central, don't want to have slipping clutch next time I've got the trailer behind.
Anyone recommend any thing else?
Cheers
Baza
You'll have an impressive handshake after using those Barnett springs for a season. They are pretty firm. Did you burn in the new clutch? What oil are you using?
Mr. Whipple is offline   Reply With Quote
Old 03-30-2012, 01:53 AM   #771
hunter_greyghost
Oddometer: 8,560
Can you give me an idea of what you mean by 'burning in the clutch',
haven't heard that term before,
clutch got a bit of a workout when I did the Bridle Track last month, creek crossings & muddy tracks mean a bit of feathering of the clutch @ times
Using a Castrol oil, 25-50 weight from memory, can't remember the name but it hasn't been a problem before, used it last 5 yrs, I'll get back to ya on the name & specs
Cheers
Baza
Old 04-01-2012, 03:21 AM   #772
hunter_greyghost
Oddometer: 8,560
I use the reg/rect units that MikesXS sell, haven't had any problems so far!
Cheers
Baza
Old 04-02-2012, 07:28 PM   #773
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,862
From the AHRMA Daytona races in 1988. An XS650 in the 750 Sportsman class.
And another in a purpose built flat track frame converted to street trim.
bk brkr baker is online now   Reply With Quote
Old 04-03-2012, 02:43 AM   #774
hunter_greyghost
Oddometer: 8,560
What's that second lever above the brake lever?
Cheers
Baza
Old 04-03-2012, 05:19 AM   #775
bk brkr baker
Oddometer: 5,862
Cheers
Baza
Flat track bikes in America only turn left and lean lto the left. Unless it's a TT race.
But anyway that's the shift lever moved to the right side. The right foot does double duty and the left foot wears a steel shoe to slide with.
Old 04-03-2012, 01:44 PM   #776
hunter_greyghost
Oddometer: 8,560
OK, now I know, it also work for a leg amputee as well, either leg - move the levers [& tack on a chair]
Cheers
Baza
Old 04-03-2012, 02:56 PM   #777
dungspreader
King of the Heap
Oddometer: 451
That right hand gearshift would be ideal for this conversion.
Old 04-03-2012, 07:36 PM   #778
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,656
the motor fits in there but the counter shaft seems so much lower than the swingarm pivot.
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 04-03-2012, 08:32 PM   #779
dungspreader
King of the Heap
Oddometer: 451
Here's another .
http://www.xs650chopper.com/2010/10/...nfield-bullet/
Actually , I quite like the look of the bike .
Is it a Yamfield , Enfaha , Royal Yamfield ?
dungspreader screwed with this post 04-03-2012 at 08:43 PM
Old 04-06-2012, 09:49 AM   #780
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,656
celebrities of a sort
OK,
I have boasted, and I have shown this pic;
Now the rest of the story;
(names and faces altered to protect the innocent)
too many...
Times are GMT -7.   It's 03:54 PM.
