Old 04-21-2012, 05:27 PM   #841
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,596
Thoughts from those who have a guess...needed
OK I'm haveing a hick-up with pamco...
I now have 1,000 miles on my 81 motor in a 77D the motor has 16,000. We did nothing to the motor in the way of rebuild.
I put on a pamco ign during the motor swap and now have a bind in the advance. Or at least after further inspection the bind is on the rod at the bushings through the cam.
My advance began not returning.
All new advance from mikes, bushes and all including pamco have 1,000 miles on them. It was springing fine when we installed it and now this is the first time I've gone back to look at it cause I was perceiving some sluggishness while pulling up hill.
So we took a look, sure enough not returning. Took the nut off the rod right side, no change. removed rod's little cam under bobbers. Bobbers fine. went ahead and pulled the rod, looks fine, reinstalled with lube...binding again.
Pulled rod out again and tapped at bushes to see they were seated and flush, no iterfearance, reinstalled...binding.
Took the rod out again and looked closer for wear where the high spots ride the bushes. Nothing wrong there, but you can perceive a shinny area 1/4" from the left side thingy?? magnet?
So we took fine sand paper and cleaned up the surfaces where they ride the bush. Better now, returning bob weights.
BUT, you know the rod has some end float when it's installed, and if you tap the rod's play all the way to the right from the left side it's more binding. (most of which is now aleaviated)
When you tap the play to the left by tapping on the right side to end of travel, she's free as a bird.
General consensis please?
Sand a little more?
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 04-21-2012, 10:15 PM   #842
retiredgentleman
Oddometer: 112
Originally Posted by BIG ED XT FAN View Post
How can i wire my headlight to come on with the key? Can it be done? My XS is a 81 650!! usa model.
Normally the headlight does not come on until the engine starts. That is the preferred way because there is more voltage available to the ignition. If you want the light to come on with the key, you would have to bypass the safety relay contacts.
retiredgentleman is offline   Reply With Quote
Old 04-21-2012, 10:18 PM   #843
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,213
Thanks! Yes the XS 650 has to have all the juice going to the starter!!!
BIG ED XT FAN is offline   Reply With Quote
Old 04-22-2012, 02:22 AM   #844
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,151
Sand a little more?
Haven't had that problem with the Pamco system, had a pin drop out on the left-hand side [pick-up pin], sounds like you've got it sussed though
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost screwed with this post 04-25-2012 at 05:23 AM
hunter_greyghost is offline   Reply With Quote
Old 04-22-2012, 09:20 AM   #845
retiredgentleman
Oddometer: 112
Actually, my 78SE is wired (from the factory) so that I can have the headlight on with the engine off, if I wish. My bike has a "Headlight" switch that bypasses the safety relay. I leave the "Headlight" switch off normally, so my headlight stays off during starting, and once started the safety relay turns the headlight on automatically.
The "Headlight" switch was deleted by Yamaha on 79 to 83 models I wonder how much money they saved by doing that???
Old 04-23-2012, 04:39 PM   #846
hunter_greyghost
Oddometer: 8,151
Sorry people, haven't been able to use my Smugmug for a few days & I can't workout what's going on?
Cheers
Baza
Old 04-25-2012, 12:50 AM   #847
dungspreader
King of the Heap
dungspreader's Avatar
Oddometer: 451
keeping busy
Did a bit of work on the 79 Special , fitting a Spirit of America , Eagle sidecar . All the old fittings had rusted out and had to be remade . The frame is rather small and it was a struggle to fit the mounts and leave room for the exhaust and still be able to kickstart the bike
I thought WanKing was a town in China 'till I discovered Adventure Rider
dungspreader is offline   Reply With Quote
Old 04-25-2012, 04:04 AM   #848
hunter_greyghost
Oddometer: 8,151
Lookin' good dungspreader, keep the photos coming
Cheers
Baza
Old 04-25-2012, 07:41 AM   #849
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,312
Getting the mounts to clear the exhaust can be quite a chore. I think I am going to run a set of pipes that exit the left side from GordonScott to eliminate the problem.Just cant decide if I want to go with high-pipes or a 2-1 low setup.
I am getting close to getting my sidecar rig ready for the road. Most of the fab work is complete. I just need to bolt the carbs on and beef up the front forks. I cant decide what to to about sidecovers. Number plate or the originals? What do you think ?
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 04-25-2012, 10:48 AM   #850
dungspreader
King of the Heap
Oddometer: 451
The copilot is getting impatient !
Old 04-25-2012, 12:36 PM   #851
dungspreader
King of the Heap
Oddometer: 451
[QUOTE=Furious D;18538887]Getting the mounts to clear the exhaust can be quite a chore. I think I am going to run a set of pipes that exit the left side from GordonScott to eliminate the problem.Just cant decide if I want to go with high-pipes or a 2-1 low setup.
I am getting close to getting my sidecar rig ready for the road. Most of the fab work is complete. I just need to bolt the carbs on and beef up the front forks. I cant decide what to to about sidecovers. Number plate or the originals? What do you think ? ---------
The number plate looks good !
Left side exhaust makes life easier for sidear mounting ,that's for sure .
However it only becomes a necessity if you want to attach a mounting to the bottom frame rail .
High pipes or low ?
For road only , I would go for low as it gives you better access to engine covers and carbs , panniers are easier too.
If there's a chance you would be going off road , high is the better option , as ruts would not be such an obstacle for you .
Good luck with the build !
Old 04-25-2012, 03:57 PM   #852
redfishguide
Old Dirt Biker
redfishguide's Avatar
Oddometer: 459
Great stuff especially since I'm considering a similar project. Did you build the suspesion on the hack? Would love a couple of pics in this area and an idea on what parts you used.
I also have a furry partner just waiting for me to get off my duff.
Thanks,
Jack
redfishguide is online now   Reply With Quote
Old 04-25-2012, 04:03 PM   #853
hunter_greyghost
Oddometer: 8,151
That's a big dog! sure the hack is gunna be big enough?
Cheers
Baza
Old 04-25-2012, 06:06 PM   #854
dungspreader
King of the Heap
Oddometer: 451
Thanks,
Jack
Here you go !
I didn't fabricate the suspension , it's standard for that sidecar .
Very simple to make though , just two shafts [ axles ] joined in a kinda Z shape with taper roller bearings . One end holds the wheel hub which is free to rotate. At the other end the shaft is welded to the frame and it's outer tube rotates to provide the suspension movement via an arm which is attached to a motorcycle coil shock .
It's a lightweight unit for a lightweight sidecar , if I was to build one , I would beef it up a bit .
You could make a similar set up with two trailer hubs .
If all goes well with this unit , I plan to build a larger sidear for my Vstrom , similar to the excellent Aussie self made sidecars that we see on Advrider .
Old 04-25-2012, 06:10 PM   #855
dungspreader
King of the Heap
Oddometer: 451
Cheers
Baza
The chair is rated at 250 lbs capacity .
She informs me that she is 85 lbs of svelte German Shepherd and doesn't take kindly to remarks about her size . [ It's just her winter coat ]
Pictures of tub to follow when it stops bloody snowing !
Times are GMT -7.   It's 03:42 PM.
