Old 04-25-2012, 08:19 PM   #856
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,400
Originally Posted by dungspreader View Post
Here you go
If all goes well with this unit , I plan to build a larger sidear for my Vstrom , similar to the excellent Aussie self made sidecars that we see on Advrider .
Some of those are great units but wait 'til you have to dig one out of a bog or sand!
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 04-25-2012, 08:49 PM   #857
redfishguide
Old Dirt Biker
redfishguide's Avatar
Oddometer: 477
Thanks alot!!!
Jack
Here you go !
I didn't fabricate the suspension , it's standard for that sidecar .
Very simple to make though , just two shafts [ axles ] joined in a kinda Z shape with taper roller bearings . One end holds the wheel hub which is free to rotate. At the other end the shaft is welded to the frame and it's outer tube rotates to provide the suspension movement via an arm which is attached to a motorcycle coil shock .
It's a lightweight unit for a lightweight sidecar , if I was to build one , I would beef it up a bit .
You could make a similar set up with two trailer hubs .
redfishguide is offline   Reply With Quote
Old 04-25-2012, 10:33 PM   #858
dungspreader
King of the Heap
dungspreader's Avatar
Oddometer: 451
Cheers
Baza
Yeh , I can imagine .
That's what mates are for .
One of the reasons for mounting a chair on the Vstrom was beause I don't like picking it up .
So maybe we'll have to carry a shovel and one of those handy chainsaw winches .
I thought WanKing was a town in China 'till I discovered Adventure Rider
dungspreader is offline   Reply With Quote
Old 04-26-2012, 06:34 AM   #859
hunter_greyghost
Oddometer: 8,400
One of the nicer outfits around, belongs to ADV inmate called Clancy from down Melbourne [Victoria] way, photo @ 2010 OCR @Wanaaring NSW
Cheers
Baza
Old 04-26-2012, 10:34 AM   #860
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,356
Cheers
Baza
That is a nice rig. You fellows down south seem to have the best hacks anywhere. At first glance I thought the 3 tubes on the front lid were some kind of rocket launchers, The ultimate ADV accessory.
Got my XS fired up today. Spending a little extra time on the carbs paid off. Started up with a little bit of choke, No leaks , And it idles now as well. Just need to chase down a couple of electrical demons and tighten everything up and I will be ready for a road test.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 04-26-2012, 04:22 PM   #861
hunter_greyghost
Oddometer: 8,400
Went to the 2012 Griffith Classic Ride on 20th April;
Only two other XS650's there, nice '73TX
'81 SH Special
& of course - 'Kenny'
Cheers
Baza
Old 04-28-2012, 06:10 AM   #862
AtLarge
AtLarge's Avatar
Oddometer: 125
That 73 TX is gorgeous.
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Old 04-28-2012, 06:52 AM   #863
Fleksta
Oddometer: 116
Finally had her out on the road:
I went with the Mikesxs Commando exhaust system. It sounds fantastic, but is only slightly louder than stock.
Just need to get the Hugh's Handbuilt PMA & Pamco ignition installed one of these weekends. But she goes down the road fine, so no hurry
Fleksta is offline   Reply With Quote
Old 04-28-2012, 03:15 PM   #864
hunter_greyghost
Oddometer: 8,400
Takes awhile to sort out what you want but always worth it in the long run!
Pamco system works well, have it on my '81 SH, just gotta watch the little pick-up pins don't fall out,easy to fix though, bit of silastic works!
Cheers
Baza
Old 04-29-2012, 08:00 PM   #865
dungspreader
King of the Heap
Oddometer: 451
Tub
Managed to find time to fit the tub today .
Old 04-30-2012, 04:18 AM   #866
hunter_greyghost
Oddometer: 8,400
Looking very nice, you're never going for a ride without a passenger again I'd say!
Cheers
Baza
Old 04-30-2012, 02:51 PM   #867
MightyChosen1
I wanna be sedated
Oddometer: 1,356
I got my hack on the road today as well. Drives pretty good but I need to tweak the alignment a bit, car wants to pull to the right.
I still have about a weeks worth of work before I call it roadworthy. A little wiring and tuning and need to replace the front mount on the car since I found a small crack in one of bolts. I might try to have it welded for now but no way am I going to take my kids for a ride till I deem it 100% safe.
Old 04-30-2012, 04:23 PM   #868
hunter_greyghost
Oddometer: 8,400
Is that screwdriver through the top front mount an optional extra?
Looks like a nice set-up, those bodies are not common out here in Oz
Cheers
Baza
Old 04-30-2012, 05:10 PM   #869
MightyChosen1
I wanna be sedated
Oddometer: 1,356
Cheers
Baza
That way I always have a screwdriver handy when the XS breaks down.
I would guess the Velorex is one of the more common cars here. Not a bad unit but the frame is a little light duty. I hope to remedy that next year by strengthening the suspension or maybe a entire new frame might be in order.
Old 05-01-2012, 08:16 AM   #870
hunter_greyghost
Oddometer: 8,400
I've always liked that style of body, very nice lines
Cheers
Baza
Times are GMT -7.   It's 09:10 AM.
