Old 05-19-2012, 07:09 AM   #901
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
Originally Posted by hunter_greyghost View Post
I was tempted to do that, can't remember whether I did it or not!
Or was that on the Boyer system on 'Kenny' ?
Both bikes now have over 50,000kms / 31,500mls since last major overhaul
'Kenny' has camchain noise [?], & 'White Beast' is starting to look like a Triumph with oil leaks around the head gasket etc.
Just keep riding until I get some spare time to strip them down & have a look @ what's going on inside, maybe renew the rings & camchain too?
Cheers
Baza
OK, thank you for that...
And if your memory on the washer changes...let me know.
Ya, I'm a little sad as I have some seepage at the cylinder base gasket on the 81 motor I recently swapped into the 77D. I'll get by with a rag on hand to clean up the slight deposits that tend to pool at the case behind the jugs.
Anybody else do the shimming?
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 05-19-2012, 10:54 PM   #902
retiredgentleman
Oddometer: 115
Shimming the ATU rod
I had 0.031" of axial end play, which I thought was a little on the large size for my Pamco. I installed a 0.015" shim washer behind the slotted disk on the right end.
retiredgentleman is offline   Reply With Quote
Old 05-20-2012, 04:54 AM   #903
tjoseph
tjoseph's Avatar
Oddometer: 17,549
I got mine from Omars, and I think they're great. My XS had the stock shocks, and they'd long ago given up damping. Just springing around. The Omars Red Wings were a quick bolt-on affair, and instant improvement. The bike is good and solid and well-damped. I bought them with the lightest weight springs, because I'm around 175, but I run them on the lowest pre-set and I like the way they feel. They're supposed to be rebuildable, so if I ever get around to that I might try lighter weight oil, but for the money I think they're great. But then again, my old ones were pretty worn and bouncy. I spend a lot of time in backroad winding stuff, and relatively bumpy pavement, and that's why I might lighten up the oil weight. I think they could use a little less damping, but happy with the springing.
Originally Posted by Fleksta View Post
How do you like the Redwing shocks? I was about to order a set from Mikes but noticed Omar's has NOS redwings (with new progressive springs) for only a little more money.
tjoseph is offline   Reply With Quote
Old 05-20-2012, 06:26 AM   #904
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
I see it! Thanks for that...
What material was the shim?
I opened up one of my old engines sitting on a shelf to find that even a stock points set up has just about the same end play.
But still, I think I will go for this adjustment to reduce this end play.
too many...
Old 05-20-2012, 09:47 PM   #905
retiredgentleman
Oddometer: 115
The shim was just a metal washer I found in my spare washer collection. With points, the axial movement may not be a problem, but I didn't want the Pamco rotor moving in and out that much.
Regretably the picture is a bit large................just learning to post on this site, and this was my first picture, lol.
Cheers
retiredgentleman screwed with this post 05-20-2012 at 09:51 PM Reason: added comment about large picture
Old 05-21-2012, 01:26 AM   #906
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,330
Cheers
I'm assuming that there is still some axial movement ?
Allowing the bob weight to move ?
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is online now   Reply With Quote
Old 05-21-2012, 04:14 PM   #907
retiredgentleman
Oddometer: 115
Cheers
Baza
For sure, there was still 0.016" end play.
New problem has reared its ugly head. Changed my exhaust this winter on my 78 SE (still OEM stock exhaust), and now my rpm wants to hang up around 1800 to 2000 rpm and not come down. No air leakage around carbs/manifolds, carbs sychronized, ATU bob weights lubed and working freely, throtte cable/butterflys are free no binding.
My old left side exhaust had a big dent in the header from the PO running into a large rock. I think that side had restricted flow. Exhaust on that side is now more free flowing, so thinking it may be too lean. I'm going to try one size larger pilot jet as a trial.
Old 05-22-2012, 02:33 PM   #908
hunter_greyghost
Oddometer: 8,330
Had look @ both bikes & it was 'White Beast' with the Pamco,
same thing exactly, so after reading some of the preceeding posts, I'll probably have a go @ doing the same as retiredgentleman,
I'm wondering if that's why the pin fell out in January
Cheers
Baza
Old 05-22-2012, 11:02 PM   #909
retiredgentleman
Oddometer: 115
Baza....................you should have a large washer covering the Pamco rotor. The washer keeps the small magnets from falling out.
RG
Old 05-23-2012, 01:18 AM   #910
hunter_greyghost
Oddometer: 8,330
RG
Well it ain't there, bugger, I've been short changed again!
it wasn't in the kit, I'll chuck a bit more silastic over it!
Cheers
Baza
Old 05-23-2012, 05:42 AM   #911
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
washer
Hey ya, I know of NO large washer with the pamco kit...
Got mine directly from pete as opposed to Mikes XS.
too many...
Old 05-23-2012, 01:27 PM   #912
hunter_greyghost
Oddometer: 8,330
Got mine from MikesXS, definately no big washer in there, haven't had any dramas since the episode when I wacked the silastic on it.
Cheers
Baza
Old 05-23-2012, 08:28 PM   #913
retiredgentleman
Oddometer: 115
Large Pamco washer
Well when the Pamco first started selling the kit, it did not come with a large washer. Some users were having rough running engines, and found that one of the small magnets had vibrated out of the rotor. Pamcopete fixed the problem by supplying a large washer to cover the magnets. Since you don't have one, you could just find one at a local hardware outlet and install it.
Old 05-24-2012, 03:59 AM   #914
hunter_greyghost
Oddometer: 8,330
Definately worth the effort of getting one to stop that pin problem, though it seems secure now with the silastic on it
Cheers
Baza
Old 05-24-2012, 08:24 AM   #915
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,600
Yes, good idea...
Care to suppy a photograph of an installed washer?
too many...
Times are GMT -7.   It's 03:26 AM.
