Old 08-03-2012, 04:29 PM   #991
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,668
Baza, do you ever go to 650 garage?
I'm 2manyrides on that forum.
Have not been using it as much in the last couple years because of ADVRider.
http://xs650temp.proboards.com/
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 08-03-2012, 09:19 PM   #992
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,668
Had a bit of a look, could spend hours in there!, gotta behave & get into the workshop for some spannerwork
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 08-03-2012, 09:30 PM   #993
retiredgentleman
Oddometer: 124
Originally Posted by MightyChosen1 View Post
After some hard riding on my XS/sidecar I can tell that I am going to need some more stopping power for the extra weight. Its not so bad by myself but when one of the kids is with me I am concerned about the stopping distance.
I guess my choices are dual disc in the front or replacing the rear drum with a disc.
I would guess to cheapest way would be to go with another disc on the front but what is involved swapping the rear drum for a disc? Did they ever make a spoked 18" rear with a disc?
Another option I might consider is swapping the whole front end with something else with a little stiffer springs and dual disc . Maybe an XS1100 or something like it.
Another option is to install a Brembo 4 piston caliper on the front. Should be able to use your existing stock disc and stock master cylinder.
I installed the 4 piston Brembo calipers on my front and on my rear. 1978 SE.............I'm using my stock discs and stock master cylinders, and gives much better braking than stock.
retiredgentleman is offline   Reply With Quote
Old 08-04-2012, 03:16 AM   #994
hunter_greyghost
Oddometer: 8,668
MikesXS & 650Central both have good looking replacements,
where did you get yours from ?
Cheers
Baza
Old 08-04-2012, 06:42 AM   #995
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,404
That looks like a great option but a little out of my budget for this build. I think I found a kit that will let me go with twin disc on the front using XJ-750 rotors.
http://www.xs650.com/forum/showthrea...isc+conversion
I'm going to fab up a mount this week and get the sidecar brake working and see if that helps for now.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 08-04-2012, 01:27 PM   #996
hunter_greyghost
Oddometer: 8,668
Nice one, thanks for the link
Cheers
Baza
Old 08-04-2012, 04:35 PM   #997
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,668
Cheers
Baza
Oh ok, I take it you're not a registered user there. Just wondering cause there's a ton of knowledge there. A little slow in usage so answers don't come as fast as here, but lots of info...
For those unfamiliar it's the 650 garage...
Tell-em 2manyrides sent you...
Not that it'll do you any good!
My 650 has been the transportation machine for the last month with my second job. My BSA must be mad at me for that, cause it took quite a few kicks to fire her up for the first time. And thereafter took three kicks the next couple starts. but today she's back to a one kick.
I guess she got over it!
And they both must be pissed cause I did the yearly "big" camping trip with two of the dirt bikes...
The dirt bikes don't get mad cause they know they can't do what the 650 can, they just wait their turn.
Treating one to a new tire and chain this weekend.
Sometimes you can run yourself to the edge with all their demands for replacements!
too many...
Old 08-04-2012, 10:26 PM   #998
retiredgentleman
Oddometer: 124
Cheers
Baza
I bought the calipers from www.gothamcycles.com. I made up my own adapter brackets from 3/8" aluminum.
Old 08-05-2012, 03:08 AM   #999
hunter_greyghost
Oddometer: 8,668
Nice bit of fabrication there, look like they'll do the job with style
Cheers
Baza
Old 08-08-2012, 03:57 AM   #1000
hunter_greyghost
Oddometer: 8,668
Found a few more home-grown photos from Griffith 'o9
Pete's XS2
Rod's '74, 750 kit with 277 crank
Hooky's XS1
Cheers
Baza
Old 08-08-2012, 04:16 AM   #1001
hunter_greyghost
Oddometer: 8,668
I'm a registered user, just forgot that I was, as I said, I'll explore it one day, just haven't got around to it,
Cheers
Baza
Old 08-14-2012, 03:59 PM   #1002
hunter_greyghost
Oddometer: 8,668
Mrs Ghost wasn't happy, but we were soon on the road again
Out & about yesterday, had trouble with Pamco ignition!, pin came out again, will be making a washer to go over them & stop the problem, [silastic only a stop gap measure!]
Cheers
Baza
Old 08-14-2012, 04:15 PM   #1003
2manyrides
shifty charactor
2manyrides's Avatar
Oddometer: 1,668
when you do post photos of your fix.
(not how you fixed the wife's attitude...the pamco)
too many...
Old 08-14-2012, 05:58 PM   #1004
hunter_greyghost
Oddometer: 8,668
Will do, think I should make the washer in Alloy or steel?
You having trouble with yours again?
Cheers
Baza
hunter_greyghost screwed with this post 08-14-2012 at 07:58 PM
Old 08-14-2012, 08:09 PM   #1005
retiredgentleman
Oddometer: 124
Cheers
Baza
If you mean the washer that covers the 4 magnets on the rotor, use steel for that one.
Times are GMT -7.   It's 01:07 AM.
