Old 08-16-2013, 04:24 AM   #1411
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,238
Originally Posted by MightyChosen1 View Post
Looks like a proper "adventure " rig now. After seeing what you have done with the stock seat I wish I would have kept mine and done the same mods to the pan.
What XS's came with 18" spoked wheels and a drum brake? I would like to upgrade to an 18" on the bike and mount the 16" on the sidecar.
'74 to '79 Standards have 18" rear drum here in Australia, they will interchange with Special mags ['81 onwards] that had the drum rear system,
Have found that Specials don't like 18" on the rear & behave badly at times, Standards don't mind 16" rear mags though, go figure????
Probably has to do with frame geometry or something, to the naked eye - I've never seen any difference???
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 08-16-2013, 07:21 AM   #1412
10ecjed
Oddometer: 142
Tires
What kind of tires are you two running?
10ecjed
10ecjed is offline   Reply With Quote
Old 08-16-2013, 12:44 PM   #1413
pckopp
Aged Adventurer
pckopp's Avatar
Oddometer: 1,276
You talkin' to me?
Brown Standard
Bridgestone Spitfire
Rear - 110/90 -18
Front - 110/90 - 19
Blue Special
IRC Durotour RS-310
Rear - 130/90 - 16
Front - 100/90 - 19
Phil in Seattle, WA
Europe 2014
pckopp is online now   Reply With Quote
Old 08-16-2013, 04:50 PM   #1414
hunter_greyghost
Oddometer: 8,238
Everything from;
Front - 300x19", both mag & wire.
Dunlop K70 [all purpose], Metzler touring block, Pirelli Trials & Dunlop D606 [dirt]
Rear - 120x16", mag & wire.
Dunlop K460 [duel purpose], Avon Roadrunner 4.10 [old style road], Metzler ME 880 [road], Bridgestone ??? [road]
Rear - 400/130x18", wire.
Dunlop D606 [dirt], Metzler ????[enduro], Dunlop K70 [all purpose], Pirelli Trials
Cheers
Baza
Old 08-19-2013, 06:48 AM   #1415
10ecjed
Oddometer: 142
PCKOOP, yes I was talking to you. Sorry, I was not clear. I like the IRC Durotour tires, I was running them for a couple years on my Special. Prices good on those. I switched to Dunlop GT501. I got better mileage with the IRC but the Dunlop works better on dirt/gravel roads and seams stickier on pavement.
Thanks I was curious.
10ecjed
Old 08-19-2013, 06:51 AM   #1416
10ecjed
Oddometer: 142
Hunter, I am keeping those tires in mind for when I get my extra set of wheels.
10ecjed
Old 08-19-2013, 01:06 PM   #1417
richsuz
richsuz's Avatar
Oddometer: 97
Front wheel Spacer size
Hi XS650 fellow riders,
I need a favor to ask. I changed the front tire last week and realized that the spacer 90560-17126 (OEM #) was missing. I went to the local Yammy dealer and they said they did not have it, only 90560-17146. I don't know the difference, they said it is probably longer that I would have to take it to a machine shop to cut. But #1 I dont know if that is true. Since I don't know the original sized OD and lenght. If that is the case, I might as well have the machine shop make me one all together. Does anyone know how to descypher the 17126 number? I imagine 17 is the ID but the 126? Does anyone have a front tire out to take measurements? I Don't know when it went missing. I imagine during one tire change about 5000 miles ago.
Thanks a lot for your help, anyone's....
richsuz is offline   Reply With Quote
Old 08-21-2013, 12:37 PM   #1418
hunter_greyghost
Oddometer: 8,238
What model ? / year?,
Only difference would be '70-'73 [early] as opposed to '74 onwards,
Cheers
Baza
Old 08-21-2013, 01:33 PM   #1419
redfishguide
Old Dirt Biker
redfishguide's Avatar
Oddometer: 474
I'll answer you over on the micapeak list.
Jack Brown
Beaufort S.C.
Thanks a lot for your help, anyone's....[/QUOTE]
redfishguide is online now   Reply With Quote
Old 08-25-2013, 05:10 AM   #1420
hunter_greyghost
Oddometer: 8,238
Another excellent 'TTT' rally this w/e
'Kenny' looking staunch after the ride in
GodSilla on the mighty XR
Simon on the BIG
Thrasher collecting badge money
Just a little campfire up the hill
Nice beast
Peter's USA import from Oregon
Plenty of older bikes getting about
Cheers
Baza
hunter_greyghost screwed with this post 08-25-2013 at 05:18 AM
Old 08-25-2013, 05:19 PM   #1421
10ecjed
Oddometer: 142
Xs650g
Well, I got the bike back on the road today after a 2 1/2 wks of being down for maintenance. New 520 o-ring chain and sprockets, modified the magnetic pick up screw and set the timing, it was slightly retarded. Adjusted valves, changed oil, iridium plugs, installed new floats in the BS34's, they were sticking and overflowing. Still need to check to see if there are any holes in the floats. Also balanced the carbs as best I could.
BTW.. I am impressed with the progressive shocks and fork springs but need to adjust the emulators a little bit more.
I just got back from test ride, about 45 miles. Got a warning ticket in the Catoctin Mountain National Forest for 45mph in a 30mph limit. Shooeee. Do not need another speeding ticket.
Hunter thanks for the picks of the gathering you went to. I love them all.
10ecjed
Old 08-26-2013, 04:20 AM   #1422
hunter_greyghost
Oddometer: 8,238
Motor in 'Kenny' needs a rebuild, used 3/4 litre of oil in 360kms,
Nothing obvious like a leak or blue smoke, so combined with a new motor vibration - I think it's time for a investigative rebuild
Only done 50,000kms [32k+ miles], so a bit annoyed with the result but it's been a lot of hard kms in there,
Came out with more then I went in with!, picked up those two white panniers for $20!,
off Gnome who had them in his sidecar after buying a job lot in Sydney on the way down
Cheers
Baza
hunter_greyghost screwed with this post 08-26-2013 at 04:41 AM
Old 08-26-2013, 06:25 AM   #1423
10ecjed
Oddometer: 142
Good score Hunter
10ecjed
Old 09-01-2013, 03:01 PM   #1424
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,400
AKRON Canton Craigdlslist
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 09-01-2013, 03:05 PM   #1425
dohcammer
dohcammer's Avatar
Oddometer: 350
Nice. Very nice.
What pipes are those?
dohcammer is offline   Reply With Quote
Times are GMT -7.   It's 09:10 AM.
