04-27-2011, 05:35 AM
#91 |
Oddometer: 3
Having installed my new fairing I wanted to share a few comments, thoughts and tips.
Is it any good? - The short answer is yes, however there are some issues surrounding the installation and build quality.
Installation - Relatively straightforward, it took me about 2.5 hours. Care needs to be taken in re-routing the original loom and relays as well as making sure the long metal light adjusters are not going to rub any insulation away. The instructions provided with the kit are adequate but flawed in these 2 areas:
Build / fit – Given the price of the unit (and the fact that it is marketed as ready to use) this was disappointing but can be fixed:
Summary – I would recommend the unit to anyone who is prepared to do the work needed to make it satisfactory but not to someone who wants an out of the box solution. Note to Britannia - please get in touch about the required improvements - info@stephenpotts.co.uk |
04-27-2011, 07:45 AM
#92 | |
Fairing Manufacturer
Oddometer: 482
1) Good point on the OEM plug for the headlight and will update instructions accordingly. 2) We have recently switched to a Hex head for these as they are much easier to tighten with a ratchet (as you suggest) 3) The dashboards have been modified to avoid this issue. In fact we are having a new design of dashboard made to locate off the front face of the top triple, to avoid having to remove the handlebars. This is to allow for better accomodation of a steering damper and also makes the instal quicker. I'm a bit concerned about the movement in the fairing that you describe. These units normal mount absolutely solid. The other significant change since you had yours is the wiring harness. The new harnesses no longer require you to do any wire connections and they also have a ground wire that runs back to the battery along with the power wire, to avoid the need to ground at the headlight area. Cheers Ian
www.britanniacomposites.com |
04-27-2011, 12:15 PM
#93 |
Crazy Bastard
Oddometer: 245
While I have the universal fit unit on my 690, I can tell you that it is absolutely solid with regards to any bounce, vibration or movement when riding over bumps or rough terrain. Do you have the upper thumbscrews absolutely tight?
Our Baja California Loop GPS Tour is now available and shipping! GripTwister Dual Sport Tours |
04-28-2011, 03:20 AM
#94 |
Oddometer: 3
Ian B - thanks for the info here and on email, hope the Adventure Spec team have the updated version available in the UK soon. The move to allow a damper fit and avoiding interruption to the top triple / bar mount machined surfaces sounds like great progress to me. Glad the bottom fastner issue is addressed and I'm pleased the plug suggestion was helpful.
Baja Dave - don't believe all you hear about folk in Ireland, of course the screws are all correctly tightened... |
07-06-2011, 05:54 PM
#95 |
Oddometer: 280
Took the plunge, ordered mine today. If it makes the difference I'm hoping for, the 690E will be my choice for the trip to Colorado this month. Not looking for a Goldwing-level protection, but the variable position of the Lynx shield will be welcome.
07-18-2011, 09:38 PM
#96 |
Oddometer: 280
Mounting was per plan, noticeable difference of wind protection and lighting improvement. Worth the money.
09-12-2011, 11:08 AM
#97 |
Flying Dutchmen
Oddometer: 20
Use a locknut with bolt for screen and dashboard instead of wing-screw /butterfly screw because of the vibrations!
Hans |
09-12-2011, 11:29 AM
#98 |
Flying Dutchmen
Oddometer: 20
Use small dampers.
Hans |
09-12-2011, 09:49 PM
#99 |
Bike Punisher
Oddometer: 671
To all those with HID's in their Lynx fairings. If the lights fail, do not waste time in taking the out. Delaying pulling them out will result in the lights being coated with a fine white dust from the inside and busted glass where the bulb used to be. Hard to believe but both HID bulbs failed spectacularly for me. Hopefully the replacements Ian sent (thanks!) will last longer.
BTW, is there an up to date install sheet in PDF available for reference?
Ride on. ================================== :: Furious Basterds: Velox, Vehemens, Oblivio :: :: "For those who don't understand, no explanation is possible. For those who do, none is necessary." |
11-07-2011, 05:15 PM
#100 |
Oddometer: 147
Pix of Mine Installed on 530
I had mine finally installed. I had George at ESP here in So. Cal. do it for me. I have not test ridden yet but will report back when I get the time to do so.
I mounted my gps and 2 powerlet outlets on the cockpit side. Here are the photos: ![]()
125 Honda (first bike at 13 years old), Early 70's 250WR Husqvarna, Late 70's 390 Husqvarna, Honda 1000VFR (stupid fast
), 2007 BMW R1200RT, 2008 KTM 530 EXCR |
11-07-2011, 05:23 PM
#101 |
Oddometer: 147
Question for IanB at Britania
Any chance you all are designing a heavier duty rock light grill/shield for the Lynx lights? I know "stick on" ones come with the unit but I am wondering if there is anything being planned/designed that is heavier duty.
11-07-2011, 05:50 PM
#102 | |
Oddometer: 482
It's going to be a ba&*%$!!!!d trying to mount something to that shape though ! Ian PS The bike looks great !
11-08-2011, 02:41 PM
#103 | |
Oddometer: 147
11-29-2011, 02:06 AM
#104 |
Oddometer: 22
KTM 690 Enduro R |
11-29-2011, 03:02 AM
#105 |
Oddometer: 66
Handguards
Well the ones on the left with MSR on them are from Malcom Smith Racing.
If you meant the ones attached to the 690, you would do a lot better to ask in the general 690 thread http://advrider.com/forums/showthrea...722987&page=70 This thread is just meant for things related to the Lynx fairing for the 690.
DON'T GET IT TWISTED --ITS DUAL SPORT! ![]() NOT DUEL SPORT!
