Old 12-20-2012, 11:11 PM   #1
TouratechUSA OP
Made For Adventure
TouratechUSA's Avatar
Oddometer: 341
Touratech USA: Suspension
Greetings ADV,
We will be highlighting and describing our Touratech Suspension systems.
We welcome any and every question or inquiry.
Touratech USA ADV Vendor Thread:
ADV Vendor Thread
Free shipping on select Klim Gear
(Taken automatically at checkout. Free ship valid for whole order if combined w/ non-Klim products)
Thanks, TT USA
All Touratech Suspension
All BMW Suspension
BMW R1200GS and Adventure - Touratech Extreme Rear Shock
We let the mad-scientists build the shock of their dreams with this product. When we asked for the absolute highest performance shock they could imagine, they developed the Touratech Extreme Shock. If NASA built suspension for the R1200GS they’d be happy with this one. You know the feeling… you see a pot hole last minute and feel the force of the hit radiate through your body as your shock bottoms out. Well, the Touratech Extreme Shock has advanced technology to make bottoming out a thing of the past. This shock has a secondary compression dampener that goes into action when your shock approaches the end of its stroke.
Combine this PDS “bottoming control technology” with a remote reservoir, fully adjustable high-speed and low-speed compression dampening, adjustable rebound dampening, remote reservoir, low friction seals and 50% more preload adjustment than other shocks on the market and you begin to see why this is the shock of choice for R1200GS or GSA riders who want the ultimate in touring performance.
Feature Summary:
Bottoming Control with secondary compression dampening technology which prevents bottoming out. The (PDS) Position-dependent Dampening System is like a hydraulic pillow at the end of the stroke.
Remote Reservoir, made from high-strength aluminum, keeps the fluid cool and ensures pressure stability in the shock which results in better performance. The reservoir also increases fluid volume by 50% extending the life of your shock.
Adjustable Shock Length, allows 8mm (-4mm to +4mm) of length adjustment to fine tune the ride height of your bike.
Adjustable high-speed and low-speed compression dampening allows absolute control of shock tuning to give you the precise handling characteristics you want in any conditions.
Adjustable Rebound Dampening allows you to fine-tune the ride characteristics to meet your preferences.
50% more preload adjustment than other shocks on the market. A generous 15mm of adjustment allows proper spring pre-load set-up for a fully-loaded R1200GS or GSA. Most shocks have 8-10mm which is not enough to accommodate the varying quantities of long-distance luggage or even a passenger.
Hydraulic Spring Preload Adjustment allows quick changes to be made to the preload by twisting the knob with your hand.
A floating piston separates the air and the oil to prevent oil foaming. This technology ensures that your shock will have smooth and consistent performance even in punishing environments.
Cold forged 6082 T6 aluminum shock body machined to exacting standards offers high-strength and maximum heat dissipation.
High-strength stainless steel bushings ensure the mounting points of the shock will go the distance.
Low-friction seal with integrated Teflon back-up ring maximizes performance and extends the life of the shock.
Oversized 16mm high-strength shaft made of chrome-moly steelfor maximum strength and durability.
Available in a range of spring rates to match the rider weight requirements.
Dampening set up for fully-loaded R1200GS or GSA right out-of-the-box.
Why do I need this?
Motorcycle Manufacturer’s Shocks - The shocks found on new motorcycles are designed to be inexpensive and fit the needs of the average 170lb rider with 15lbs of luggage. As a result, they often meet the minimum standard for function. The performance of a stock shock is typically not confidence inspiring. With heavy loads, stock suspension “bottoms out” easily and doesn’t have sufficient preload or damping adjustment range. They aren’t serviceable and, with heavy loads, are prone to blown-out seals and other failures. The rider often feels the bike is too spongy and doesn’t handle properly.
Aftermarket Shocks - Most after-market shocks are made with performance riding in mind, but aren’t built for use on a fully-loaded touring bike. Most can only withstand the weight of the rider and don’t offer good handling, or have adequate preload adjustment. They also aren't durable enough to go the distance with a fully-loaded touring bike.
Key issues to consider when selecting a shock:
PDS Bottoming Control - Imagine riding your fully-loaded R1200GS or GSA on the ‘Road of Bones’ in Siberia and not having to worry about bottoming out the bike. The Position-dependent Dampening System or (PDS) makes this possible with a secondary dampener piston that creates progressive dampening. This allows you to keep the primary compression dampener settings a bit softer and more comfortable because the (PDS) dampener will kick-in when needed like a hydraulic pillow to prevent bottoming out at the end of the shock stroke.
Remote Reservoir –This piggy-back style remote reservoir is made from high-strength aluminum and is designed to keep the fluid cool and ensure pressure stability in the shock which results in better performance. The increased oil capacity results in longer shock life.
Adjustable High-speed and Low-speed Compression Dampening – Separate adjustments for high-speed and low-speed compression dampening allows absolute control of shock tuning to give you the precise handling characteristics you want in any conditions. This allows you to control how the bike handles in a high speed corner separately from how it behaves absorbing a pothole.
Adjustable Rebound Dampening – Right out of the box, this shock is ready for adventure with its rebound dampening levels set for touring on a fully-loaded R1200GS or GSA. The rebound dampening is also fully adjustable so the ride can be customized to your preferences.
Hydraulic Preload Adjustment - With a Touratech Extreme Shock, the preload can be hydraulically adjusted by turning the knob with your hand.
50% More Preload - When loading your R1200GS with luggage and all the gear for a weekend trip or extended tour, the bike will sag under the weight of the load. Most shocks are NOT designed to handle this. With Touratech Suspension, you can adjust the spring pre-load to bring the bike back to level. Because of the full 15mm adjustment you can raise the back of the motorcycle as much as 1.8 inches to compensate for the load which restores proper geometry for optimum handling and overall feel of the bike. Most shock preload adjusters only have 8-10mm of adjustment which can only raise the back of the bike by 1.2 inches.
Floating Piston Superiority – Touratech Suspension uses a Floating Piston design which offers the best dampening performance because it physically separates the nitrogen gas from the oil. Most shocks use oil emulsion dampening which allows oil to mix with the nitrogen gas in a foaming process that basically ‘thins’ the oil and prevents the shock from working properly. When the oil is 'foamed' the bike bottoms easily and also springs up too quickly resulting in erratic handling and an unsteady ride.
With the floating piston design of Touratech Suspension there is a physical separation of oil and nitrogen gas which means you can ride your R1200GS or GSA on rough roads all day long and enjoy consistent high performance. Why buy a shock whose performance gets worse the harder you ride it? Before you invest in new suspension make sure it’s a floating piston design.
Stainless Steel Bushings – While many aftermarket shocks use aluminum bushings where the shock mounts to the motorcycle, Touratech Suspension uses high-strength, non-corrosive stainless steel. This creates a strong and rigid connection which is important for loaded touring motorcycles. The stainless steel bushings protect against corrosion and seizing and offer low maintenance and longer life.
Low-Friction Seal – Our seals have a backbone that virtually eliminates friction interference on the dampening activity. On other shocks, the seal deforms as dampening pressure increases and causes stiction on the shaft. Touratech Suspension is equipped with a proprietary low-friction seal that is supported by Teflon back-up ring. This Teflon backbone keeps the seal from deforming and eliminates stiction on the shaft even at high pressures. The result is better performance, increased reliability and longer service life, even in harsh environments.
Oversized High-strength Shaft – While most manufacturers use a 14mm carbon steel shaft, Touratech suspension uses a 16mm high-strength chrome-moly steel alloy.
Aluminum Shock Body – Some manufacturers use a steel shock body to reduce cost. Touratech uses cold-forged 6082 T6 aluminum for the shock body because it’s lightweight, strong and durable. It also dissipates heat 30% more effectively than steel, which results in more stable and predictable dampening delivering better handling and a smoother ride. A cooler shock will also have more consistent dampening and a longer service life.
Custom Springs – Touratech Suspension is available in a range of spring rates so we can ensure your shock has the proper spring for your requirements.
Fully Serviceable – All Touratech Suspension is fully serviceable and can be customized or re-built by Touratech-USA or any qualified suspension technician.
Adjustable Shock Length -The Touratech Extreme Shock also features 8 millimeters (-4mm to +4mm) of length adjustment allowing you to fine tune the ride height of your R1200GS or GSA. While other manufactures use a M16 thread, we’ve chosen an M20 thread which is twice as strong as M16 and is better suited to handle the forces of a fully-loaded motorcycle in difficult terrain.
Summary - Touratech Extreme Shock:
The PDS bottoming control gives peace of mind that you won’t bottom out the shock. Having the secondary dampening that works like a hydraulic pillow at the end of the stroke allows you to have a plush ride on your R1200GS even in the most extreme conditions. It also extends the life of the shock and is better for the motorcycle and the rider by eliminating the forces and possible damage associated with hard hits.
The Touratech Extreme Shock offers adjustable high-speed and low-speed compression dampening, a remote fluid reservoir, adjustable rebound dampening, floating piston superiority and low-friction seals which add up to a highly refined shock that can be tuned with precision to meet the ride style and handling characteristics you prefer.
The Touratech Extreme Shock is over-built by design with heavy-duty materials, over-sized components, and 50% more spring pre-load adjustment than other shock on the market. The preload can be hydraulically adjusted by turning the knob with your hand.
Touratech Suspension is the world’s first purpose-built shock absorber for long-distance touring with a fully-loaded motorcycle. Right out of the box, it has the strength, features, and adjustments to go the distance on your packed R1200GS or GSA.
The Touratech Extreme Shock is the ultimate in suspension technology, and the ideal choice for extended trips or off-road rides like a Backcountry Discovery Route. For the rider who wants absolute control over suspension set-up, high performance and durability, this is the product.
If you want the best suspension on the planet for adventure touring with a fully-loaded R1200GS or GSA, the Touratech Extreme is the top choice. Nothing else comes even close.
BMW 1200GS & Adventure - Touratech Expedition Rear Shock
BMW 1200GS & Adventure - Touratech Explore HPe Rear Shock
BMW 1200GS & Adventure - Touratech Explore HP Rear Shock
BMW 1200GS & Adventure - Touratech Explore Rear Shock
1200GS & Adventure - Touratech Explore Front Shock
TouratechUSA screwed with this post 04-30-2013 at 08:28 PM
TouratechUSA is offline   Reply With Quote
Old 12-20-2012, 11:19 PM   #2
TouratechUSA OP
Made For Adventure
Oddometer: 341
Yamaha Super Tenere - Coming Q1 2013
Triumph 800 & 1200 Explorer - Coming Q1 2013
TouratechUSA screwed with this post 12-21-2012 at 12:15 AM
Old 12-20-2012, 11:20 PM   #3
TouratechUSA OP
Made For Adventure
Oddometer: 341
Media coverage:
http://www.expeditionportal.com/vehi...l-luggage.html
http://www.ultimatemotorcycling.com/...e-at-ims-video
TouratechUSA screwed with this post 12-21-2012 at 12:14 AM
Old 12-21-2012, 04:20 PM   #4
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,432
Wow those are some amazing looking shocks TT
The price is high but everything looks top shelf and a step above what else exists on the market.
Eye candy perspective is over the top.
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 12-21-2012, 10:47 PM   #5
FlyingFinn
Oddometer: 940
Other than the Touratech badging and price tag, are these somehow different from the standard WP shocks that these are "based on"?
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is online now   Reply With Quote
Old 12-21-2012, 11:24 PM   #6
ParaMud
ParaMud's Avatar
Oddometer: 443
I feel kinda dumb, but what is a front shock?
Do you stick that thing in the front forks somehow?
04 KLR 650
07 KLR 650
06 sv650s
07 Ducati Monster
ParaMud is offline   Reply With Quote
Old 12-22-2012, 11:08 AM   #7
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 1,446
BMW has front spring over shock instead of conventional forks, paraleaver I thinnk its called on front.
"I refuse to tiptoe through life only to arrive safely at death"
2009 Buell XB12X(sold), 2006 Triumph Sprint ST, 2006 Tiger 955i, 01 XR650L replaced by a KLR, and now a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 04-30-2013, 08:38 PM   #8
TouratechUSA OP
Made For Adventure
Oddometer: 341
BMW calls it front fork suspension a Telelever.
http://en.wikipedia.org/wiki/Suspens...elever.29_fork
The forks are just sliders and a single center-mounted shock handles all the damping and such.
Old 05-15-2013, 05:44 AM   #9
shin938
Oddometer: 25
I just got an email back from touratech and discovered that warranty for the shocks is only one year,isn't that too short comparing to other brands?
shin938 is offline   Reply With Quote
Times are GMT -7.   It's 12:25 PM.
