Old 05-24-2012, 06:05 PM   #181
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Email sent
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 05-27-2012, 05:46 PM   #182
AllenL
Oddometer: 79
Got mine today, I'll be checking it out next week. I'm still a few months away from having a running bike, but I'll be sure to give an update.
Thanks Mark.
1986 XR600R --> 2014 XR700CW - work in progress
AllenL is offline   Reply With Quote
Old 05-28-2012, 02:46 AM   #183
5131dan
5131dan's Avatar
Oddometer: 81
Oil line next to header pipe ?
Hey Mark, By looking at all the photo's , it's easy to tell you do really precise work. Nice Job ! I was wondering about the inner oil line running so close to the header pipe. Is there any concern about the heat and that rubber oil line , or is there plenty of clearance in between ? It's a little hard to tell by the pictures. Thank's , and again - Awesome Job.
5131dan is offline   Reply With Quote
Old 06-04-2012, 09:08 PM   #184
formulals1
Semi-Adventurer
formulals1's Avatar
Oddometer: 293
I like the new design. I need to order a few parts.
Originally Posted by formulals1 View Post
Oh man, I bent-up the artwork. I might need the skid plate to help protect the lower end of the cooler set-up. Either a strong rock flip-up or my light fall to the left side in the woods cuased this.
Mark, should I try to flatten it out or would that weaken it too much?
formulals1 is offline   Reply With Quote
Old 06-04-2012, 10:22 PM   #185
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
The guard looks like it did the job. Just like protective gear, better the protective stuff gets destroyed than the goodies.
No worries. Send me an email at mark@mega.net or PM me. I will get you the latest guard for your beast.
I need to update the home page and list an upgrade kit to replace the old design should anybody want one.
Cheers
Maek
AMA Earned Life Member Iron Butt Association Member
suttoncycleworks.com
Honda XR650L XR600 NX650 Oil Cooler Kit
KTM 990 Adventure Honda CRF450 Supermoto H-D Sportster Streettracker Honda XR650L
GSMark is offline   Reply With Quote
Old 06-04-2012, 10:40 PM   #186
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
There is plenty of room between the oil hose and the exhaust. 3/4" to be precise.
Thanks for the kind words about my work. Even though I get some parts cut at a water-jet machine shop (rough cut), I spend over an hour on each kit, finishing, bending and checking each part. I just received another batch of parts from the machine shop and spent many hours getting 10 sets ready for put the finishing touches on them. About another 2 hours to get them finished for the kits. I really could just throw the parts in an industrial tumbler and let it do the work, but the finish isn't up to my standards. I am way too anal.
Not to worry about the header pipe and the oil line. I really wouldn't sell something with that problem.... after all, it is on my own bike too.
Cheers,
Mark
Old 06-04-2012, 10:41 PM   #187
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
Thanks Mark.
Thanks AllenL!!!!
Old 06-05-2012, 06:00 PM   #188
opjocephus
I'm down, I'm down!
opjocephus's Avatar
Oddometer: 571
I rode my XRL approx 6000 miles last year with GSMark's cooler. Never a problem. I might not ride mine like most. Mostly back roads and a little gravel. No extended interstate riding. Oil is definitely not as dark at 1500 mile oil change.
OP
"They're skanky, but they look pretty good!"
Plastic seat sweat, my balls are mighty wet.
"Your eyes look like a couple of piss holes in a snow bank." The Great Jaydini
opjocephus is offline   Reply With Quote
Old 06-06-2012, 12:15 PM   #189
5131dan
5131dan's Avatar
Oddometer: 81
Cheers,
Mark
Thanks for the reply Mark
Old 06-17-2012, 09:15 AM   #190
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Received my oil cooler for the XR600R , trick piece of work !!
Can anyone give me a ballpark on how much oil should be added to the system vs. standard ?
Gives me an idea on how many liters of oil I should go out and buy prior to installing
Thanks !
Btw, Mark I love the instructions, very clear !
Old 06-17-2012, 09:45 AM   #191
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
Thanks !
Thanks for the kind words about my oil cooler kit.
I finally checked the oil capacity of the kit. It was quite a bit less than I thought it would be.
Figure about 170cc of additional oil.
The oil cooler holds 130cc and the lines hold 40cc.
Hope this helps.
Cheers,
Mark
Old 06-17-2012, 11:21 AM   #192
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Hope this helps.
Cheers,
Mark
Thanks Mark !
Old 07-03-2012, 04:50 PM   #193
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
XR650L/XR600 HD Upgrade kit for the early design:
I've added an upgrade kit for the people that purchased the original oil coolers.
This new guard is rubber mounted and still attaches to the frame.
This kit includes low profile oil cooler bolts, aluminum counter-sunk washers, new motor mount bolt /washer, and new guard.
This will fit the XR650L and the XR600.
$45.00 Including shipping.
Cheers
Mark
Old 07-04-2012, 09:46 AM   #194
Rider11x
Resident Hillbilly
Rider11x's Avatar
Oddometer: 142
These are very sweet! Very interested in what Honda should have had on them from the factory. Beautiful work!!!!
2012 Honda XR650L Adventure Bike
Honda XR Fan for 30+ years!!!!!
Rider11x screwed with this post 07-05-2012 at 07:03 AM
Rider11x is offline   Reply With Quote
Old 07-05-2012, 06:54 PM   #195
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 875
I hope this helps in answering your questions about the kit:
You have my apologies for the late reply.
Thanks for looking at my oil cooler kits and your kind words about them.
Q 1. Where do the two lines tap into on the 650l?
A 1. The line that is located behind the frame down tube, the one right in front of the engine, is cut and the new oil lines are clamped to the ends.
Q 2. Are the above existing locations?
A 2. See answer 1. This is very easy to do. I provide very detailed and illustrated instructions.
The instructions are easy to follow.
I have always hated getting a product with crap instructions.
I took the time to illustrate each step so I wouldn't have to answer questions about the installation (I do illustration work as my day job).
I also wanted to make the instructions so my customers would have an easy, painless installation.
I may have gone into too much detail on some steps, but I really don't know the mechanical ability of each customer. One gal purchased the kit and said "so easy, a girl can do it".
There was only one problem with one of my oil coolers. That customer looked at the parts and thought it would be easy to install without the instructions. Big mistake.
He had problems with the oil lines kinking and blocking oil to the cooler.
Please follow the instructions and you will have no problems.
At very the most, I would give it about 3 hours if you took your time and had a few beers.
Q 3. Are there any permanent mods required?
A 3. Only the cutting of the oil line. You can splice it back together with the clamps or replace it if you should ever want to remove the oil cooler.
Q 4. I saw mentioned somewhere about selection oil cooler color? What is available?
A 4. The cooler come in bare aluminum and powder coated black.
The bare aluminum look much better and blend into the bike much better visually. Depending on who you talk to or what you read on the internet, they should cool better too.
Q 5. Does the install require draining my oil?
A 5. Yes.
Q 6. How likely is it to need the bypass in temps down to 30 degrees Fahrenheit?
A 6. I would recommend using a by-pass valve if you are riding A LOT at 30 degrees Fahrenheit.
It really depends how much of your riding is at very low temperatures, weather you need the by-pass valve or not.
You can put a strip of duct tape over the guard if you find yourself in cold temps. I live in Arizona and that is what I do.
The by-pass valve can be added to your bike later if you don't order it with the kit.
Q 7. Where do I sent my Paypal to?
A 7. PayPal to: mark@mega.net
Please look at the first page on my vendors page:
http://www.advrider.com/forums/showthread.php?t=652313
I give all of the options, prices, shipping cost, and ordering details.
Q 8. What is the total for a HD unit for my 2012 xr650l?
A 8. $279.00 add $15.00 for shipping in the USA.
Please go to:
for detailed prices and ordering details.
I hope this helps.
Thanks again for looking at my oil cooler kits,
Cheers,
Mark
Times are GMT -7.   It's 01:31 AM.
