Old 03-21-2011, 10:52 AM   #76
captnmack
Oddometer: 6
Send a message via Skype™ to captnmack
W/ IMS Tank
All, I recently installed this Oil Cooler and a new IMS 4.0 tank at the same time and had NO issues, except I did have to share the left tank support mount. I rode with my new stuff in West Texas and it worked great!
Great product Mark!
Thanks,
XR650L...Mack
captnmack is offline   Reply With Quote
Old 03-22-2011, 10:17 AM   #77
pgup
Oddometer: 52
I have mine. Might install today. Thanks Mark
pgup is offline   Reply With Quote
Old 03-22-2011, 05:18 PM   #78
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 3,418
Originally Posted by GSMark View Post
Thanks techforlife and formulals1 for the photos and kind words.
Do you guys think that I should take out the exhaust removal step in the instructions? Everybody that has done it my way is going to want to kill me... depending on your answer.
Thanks again guys!
Mark
Don`t need to remove the exhaust Mark......although it might be easier to get the oil pipe out???????? I removed mine because i need to paint it or cermachrome it.........not sure yet...
Oh....i`m gonna update my pic here when i get the exhaust on and the red ano`d skidplate....... serious bike porn goin on with these coolers
B
01 XR650L,102mm JE 11.25:1..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.FCR MX pumper.42/158 NVCT needle.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife is offline   Reply With Quote
Old 03-26-2011, 05:42 AM   #79
opjocephus
I'm down, I'm down!
opjocephus's Avatar
Oddometer: 402
Way cool!
Any photos?
Thanks,
Mark
Not yet, Mark. I have been trying to find a 90 degree fitting to replace the tube I made. I don't have the thread size in front of me to tell you what it is.
M16 X 1 or M16 x 1.5??? I wrote it down and can't find it.
I had a buyer here look for one and he was having trouble. If I ever find one, will let you know.
OP
"They're skanky, but they look pretty good!"
Plastic seat sweat, my balls are mighty wet.
"Man, there's nothing worse than watching a mouth breather trying to smoke a cigarette." jdrocks
opjocephus is offline   Reply With Quote
Old 04-05-2011, 08:44 PM   #80
benno.h
cageracer
Oddometer: 421
Well I have my cooler installed and running on my XR600. It's a beautifully made little thing. Apologies Mark for bolting it to such a ratty looking XR!
It seems to stand a bit further out than it would on an XRL.
EDIT: F*** YOU PHOTOBUCKET! My pic is right side up on the iphone, and uploads upside down. Then the photobucket online editor puts them right side up, but if I link to them from outside they're upside down again!
When I have some time I will cut the spacers down a fraction to try and bring it inboard a little, but there isn't much clearance on the other side of the actualy oil cooler body.
It works pretty well - I am getting temps about 50-60ºF less than I was before after long highway slogs and such, although ambient temps have dropped a few degrees recently and I am now running a different carb.
I intend to keep the small section of hard oil pipe that I cut out in my spares pack on the bike incase something goes wrong - I should be able to plug the two oil hoses back together in the event of a leak.
Originally Posted by GodSilla View Post
I'll step out on a limb here and state that bikes without kick starters are just plain gay, for pansies, ladyboys, and suchlike. Furthermore, they should have to ride at the back, not speak until spoken too, and set everyone else's tents up, then cook and wash up afterwards, before sitting up all night guarding the real men's bikes.
benno.h screwed with this post 04-05-2011 at 08:54 PM
benno.h is offline   Reply With Quote
Old 04-12-2011, 05:26 AM   #81
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 679
Send a message via AIM to switch Send a message via MSN to switch Send a message via Yahoo to switch
Install log, Honda NX650, EU-spec frame, roughly identical to US-spec NX frame:
First impression is that everything will bolt right on
The frame bolt for the cross-brace piece of Al is 1/2 an inch higher
- fixed problem by drilling two extra holes in A-shaped support
Radiator shroud no longer lines up
- replaced "beautiful" shroud with a spatula-like shroud
- ground spatula-shroud to fit the wrong-way around and not hit the frame near the bottom
- drilled cross-brace to fit the holes on the spatula-shroud
- test-install
Done. No pics as I didn't have the camera on me. Stay tuned :)
Mark, I'll be returning the nice-looking curved shroud just in case you want it for another customer. I had no idea how useful the "extras" would be :)
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 05-04-2011, 03:58 PM   #82
Zojirushi
Surly Sailor
Zojirushi's Avatar
Oddometer: 87
Ordered mine. I am looking forward to installing this! I'll update soon.
Zojirushi is offline   Reply With Quote
Old 05-07-2011, 11:19 AM   #83
Rass
Oddometer: 7
cooler for chile
Mark, please contact me again.
Let's close the deal
¡Saludos!
Gracias.
Sebastián Corrales from Chile.
My Piggy: XR650L '95 - WRP "94"db ex, stock headers - HSR42 Pumper - UNI - JE 10.5:1, Falicon Knife rod - WRITZ handelbars and clutch servo - Trailtech Vapor stealth + H3 upgraded X2 front lamp - Clarke 4.7gal - XR's only temp dipstick - Contis TKC's 80 - XT660 mirrors - Sutton oil cooler + Bypass Valve -->150% worth it.
Rass is offline   Reply With Quote
Old 05-07-2011, 11:24 AM   #84
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 750
Rass,
PM Sent.
Mark
AMA Earned Life Member • Iron Butt Association Member
suttoncycleworks.com
Honda XR650L XR600 NX650 Oil Cooler Kit
• KTM 990 Adventure • Honda CRF450 Supermoto • H-D Sportster Streettracker • Honda XR650L
GSMark is offline   Reply With Quote
Old 05-08-2011, 01:55 PM   #85
JBADV
searching for sanity
JBADV's Avatar
Oddometer: 3,064
Originally Posted by techforlife View Post
Well Mark........i got pics
B
Nice install.
Where did you get the hose wrap ?
Thanks,JB
The older I grow,the faster life goes.
The more I learn,the less I know.
JBADV is offline   Reply With Quote
Old 05-08-2011, 02:55 PM   #86
techforlife
CDI REPAIR
Oddometer: 3,418
http://www.designengineering.com/cat...nized-sleeving
DEi makes it.not really needed though,but looks cool so i put it on,Marks cooler definately works well.....
I`ll be vposting temp diffs with the cooler turned on and off as soon as i get a decent day to try it.........tons of rain lately..
P.S. Hey Mark......how`s it going,haven`t heard from you lately,are you selling tons of these......finally got the tank mounts to work,took very little time,but i am lazy
OH......it looks better now with the exhaust on and the skidplate......
B
techforlife screwed with this post 05-14-2011 at 04:59 AM
Old 05-12-2011, 12:54 PM   #87
Zojirushi
Surly Sailor
Zojirushi's Avatar
Oddometer: 87
So I finally got around to installing my cooler. Everything was going well until I installed the two bolts that hold the cooler itself to the support arm. I had tightened the top bolt to roughly 5 Nm when spin spin spin. The lock nut had not even flattened!
The instructions do say not to overtighten, but I can only assume mine was especially weak. I am usually not surprised when I strip things. This time I was! The only thing holding it together is a very small (1mm?) collar of aluminum. I had it welded back, threw some paint on it, and finished the install predictably.
The kit is great, and, as previously mentioned, the instructions are impressive. We're finally getting some rain here, so while I fired her up to check for leaks, I haven't taken her out. Thanks again, Mark.
Old 05-13-2011, 07:16 AM   #88
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 750
Thank you for the update.
I am sorry that you had to go through this.
I will look into this matter a little further.
Mark
Old 05-13-2011, 01:27 PM   #89
Rass
Oddometer: 7
I've cleared payment and sent you my shipment adress. Please tell my shipment's status. I'll thank you.
Bye.
Old 05-13-2011, 09:08 PM   #90
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 750
Bye.
No worries, PM sent.
Your oil cooler was sent out yesterday.
I will be away from my computer all weekend. Returning on Sunday night.
Cheers,
Mark
Times are GMT -7.   It's 06:15 PM.
