Old 05-18-2011, 06:33 PM   #91
JBADV
searching for sanity
JBADV's Avatar
Oddometer: 3,430
Should be picking up my XR650L on Saturday.I am interested in an oil cooler.The bike is new,under warranty,and has the air pump on it.Will the cooler work with the air pump on the engine?Are the mounting brackets raw aluminum ? Thanks,JB
The older I grow,the faster life goes.
The more I learn,the less I know.
JBADV is offline   Reply With Quote
Old 05-19-2011, 06:40 PM   #92
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 886
Hi JB,
The kit will not work with the smog octopus.
All of the brackets/guards are made from aluminum.
You are going to love your new bike.
Congratulations!!!!
Cheers,
Mark
AMA Earned Life Member • Iron Butt Association Member
suttoncycleworks.com
Honda XR650L XR600 NX650 Oil Cooler Kit
• KTM 990 Adventure • Honda CRF450 Supermoto • H-D Sportster Streettracker • Honda XR650L
GSMark is offline   Reply With Quote
Old 05-20-2011, 09:24 AM   #93
JBADV
JBADV's Avatar
Oddometer: 3,430
Thanks for the reply.
Are the brackets anodized ?
Old 05-20-2011, 04:52 PM   #94
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 886
They are not anodized.
M
Old 05-28-2011, 03:44 PM   #95
Rass
Oddometer: 7
Thumb One kit for chile arrived
I got mine
After to get my old piggy chassis repainted I'll show you some pictures.
‘Saludos!
S
Santiago de Chile.
My Piggy: XR650L '95 - WRP "94"db ex, stock headers - HSR42 Pumper - UNI - JE 10.5:1, Falicon Knife rod - WRITZ handelbars and clutch servo - Trailtech Vapor stealth + H3 upgraded X2 front lamp - Clarke 4.7gal - XR's only temp dipstick - Contis TKC's 80 - XT660 mirrors - Sutton oil cooler + Bypass Valve -->150% worth it.
Rass is offline   Reply With Quote
Old 06-05-2011, 11:18 AM   #96
formulals1
Semi-Adventurer
formulals1's Avatar
Oddometer: 311
Oh man, I bent-up the artwork. I might need the skid plate to help protect the lower end of the cooler set-up. Either a strong rock flip-up or my light fall to the left side in the woods cuased this.
Mark, should I try to flatten it out or would that weaken it too much?
formulals1 is offline   Reply With Quote
Old 06-05-2011, 06:38 PM   #97
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 886
WOW! Custom by Crunch! Is the cooler okay?
It should bend back pretty easy without hurting it. You might want to use two wood 2x4s.
edit: Drill two holes in one of the boards to make room for the rivet nut inserts on the guard.
Put the guard between the two boards and press them together with a vice, a press, or some large c-clamps. Just make sure you don't flatten out the original "kick" in the guard. This should get the guard close to flat again. You might have to do a little tweaking after you get done. The aluminum might have a little "spring" to it.
Keep us posted.
Cheers,
Mark
Old 06-05-2011, 07:08 PM   #98
formulals1
Semi-Adventurer
formulals1's Avatar
Oddometer: 311
The cooler is all good. I'll try that to bend it back - pretty much what I was thinking.
Keep us posted.
Cheers,
Mark
Old 06-06-2011, 05:46 AM   #99
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Go slow! AL only likes to bend once but not twice. It is more brittle than steel, especially as thick as the guard is and having the one edge rolled to a 90 like it is. Don't ask how I know this.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 06-07-2011, 08:11 PM   #100
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 886
The last batch of coolers are unpainted and have a bare aluminum finish. I really like the look.
What do you guys and gals think?
Cheers,
Mark
Old 06-21-2011, 12:56 PM   #101
sc-razor
sc-razor's Avatar
Oddometer: 3,777
Very nice! I have the bike as of last Saturday. Should be ready for a cooler in a couple of weeks
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 06-21-2011, 06:42 PM   #102
GSMark OP
Just Love Bikes
GSMark's Avatar
Oddometer: 886
Great!
You will like this bike.
Now that the weather is getting hot, I am getting a bit more requests for the kits... Really Who woulda thunk?
Thanks to all!
Doing my best to keep up... Darn day job keeps getting in the way!
Cheers,
Mark
Old 06-22-2011, 04:39 PM   #103
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,353
Mark.......i`ve been doing tests to see how effective the cooler works.....i took it down the highway at 140kph with the bypass turned on,no oil flowing through the cooler........after about 15-20 miles it hit it`s highest temp on my oil temp guage....250 degrees......and climbing ...but slowly.
Now bear in mind it was a cold day......i`ve seen 275 and climbing on this same run in summer on hot days......with the OE tank with the air scoops.....
I pulled the bike over,turned the bypass off.........oil now flowing through the cooler.........turned arround immediately and hit the highway back home........220-225 was max......
So 25 degrees or better cooling is really decent......if it was a hot day it wouldn`t get over 250 degrees.......this is also riding the snot out of it,,basically WFO for 20 miles.............it`s a Honda,it likes it rough
B
techforlife is offline   Reply With Quote
Old 07-16-2011, 09:25 PM   #104
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,580
I installed my cooler last night.
If you follow the instructions (I didn't) the install will go without a hitch. I cut the oil line short hoping to be able to route it out the left side of the bike. Well.... it didn't work. I ended up following Brian's install and fabed up a custom line for the return hose. A 3/8 inch fuel line custom bent and flared. Piece of cake. It works great!
Last night before the custom oil line:
Today:
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed screwed with this post 07-25-2011 at 12:03 PM
ThumpnRed is online now   Reply With Quote
Old 07-18-2011, 04:45 AM   #105
techforlife
CDI REPAIR
Oddometer: 4,353
Cool.so you got it done.........looks good Red.......
Just a note to Mark.......i`ve found one thing of real advantage to me after installing the oil cooler,the oil stays golden almost forever,,,,usually it would turn black as coal after a few rides,i just changed the oil with almost 2000 and it`s still almost clear,definately still golden and can see through it........so keeping the oil at cooler temps is at least very good for the oil and not frying the shit out of it.......now i can actually feel safe going the 2k recommended oil change intervals...
I`ve dropped the bike a few times,numorous rock gardens.....no problems,,sweet looking/working rig these are.....
THANKS MARK.....
B
techforlife screwed with this post 07-18-2011 at 05:13 AM
Times are GMT -7.   It's 12:07 PM.
