Old 02-15-2015, 09:29 AM   #1
800 OP
Oddometer: 16
1982 R 80 G/S gas mileage
My 1982 R 80 G/S only takes me 12 KM/L without passenger or load. It runs perfect and the carburators have just been serviced. Have you any idea how to improve the gas mileage? Thanks
800 is offline   Reply With Quote
Old 02-15-2015, 11:08 AM   #2
JR356
JR356's Avatar
Oddometer: 3,737
Best to post this in the airheads section of"Old's Cool"section of this site.
Thats where all the airhead experts/folks hang out.
That's about 28 mpg,seems like it should be better.
JR356
JR356 is offline   Reply With Quote
Old 02-15-2015, 04:00 PM   #3
sunlinden
Fun Muncher
sunlinden's Avatar
Oddometer: 110
mixture?
Try adjusting the mixture screw. It sounds like the carbs are running too rich. The screws should be on the bottom and you turn them in to lean the mixture. If I remember correctly, they should be approximately 1&1/2 to 2 turns out.
sunlinden is offline   Reply With Quote
Old 02-16-2015, 08:28 AM   #4
anderstornvig
Oddometer: 46
Helloo, I thought my G/S had great mileage until I found out the speedo was about +20 km/h off, the tacho corresponding amount. Fully loaded I get anything from 15-20 km/L but I've waited too long to get it "tuned in". It's most thirsty at highway speeds where the fifth gear is not long enough, >100 km/h or so. Like you probably, I have the 37/11 gearing in the final drive.
Sorry to spec only metric units. On that note, since I see you're danish , be aware of the difference between imperial and US gallons when reading people's mpg. It's almost never specified and it's very confusing..!
anderstornvig is offline   Reply With Quote
Old 02-17-2015, 09:01 AM   #5
RGregor
Oddometer: 446
These bikes suffer from low CR and a rich carb setup.
In a BMW related magazine there was a very interesting article on how to improve mileage with these bikes.
However, it's not only buying the correct jets and needles, as Bing does not offer many variations.
In principle the procedure was to reduce the diameter of the needle at the cylindrical part for ~1/100mm and combine that with a smaller needle jet.
And smaller mains.
I have the magazines here and could look for this article to provide accurate info.
RGregor is offline   Reply With Quote
Old 02-17-2015, 11:10 AM   #6
800 OP
Oddometer: 16
[QUOTE
I have the magazines here and could look for this article to provide accurate info.[/QUOTE]
Thanks, that would be great!
Old 02-17-2015, 12:18 PM   #7
RGregor
Oddometer: 446
One question in advance. You have checked valves and ignition?
You shouldn't try to fix a problem with carbs when the reason is somewhere else.
For the problem you describe you'd have to change the needle jet / needle combo to lean the mid range. However, there's only one needle available.
As a first step you could change the needle position and set the needle deeper.
Next step would be to change the needle jet.
Can you read german?
The author of the article I mentioned provides an Excel sheet for documenting/calculating carb setup.
Unfortunately all comments are in german.
http://www.mo-web.de/downloads/vergaseroptimierung.xls
The basic idea behind the modification is to lean the jetting in the middle, but not at low or wide open throttle positions.
If you reduce the needle jet you lean at low and middle positions.
The problem seems to be that the steps between the available needle jets are too big.
So if you go down one step the engine might already run too lean and start jerking (is that the correct expression in english?).
In that case you would have to:
- determine needle diameter in the cylindrical area
- reduce needle diameter with very fine emery cloth by ~1/100mm
- polish the needle in that area.
So with a smaller needle jet you'd have the same area between needle and jet in the cylindrical part, but less , which means leaner, in the tapered part of the needle. So it affects merely the mid range.
One reason why I like Dellortos. They offer so many needle jets and needles you'll always find something suitable.
Old 02-17-2015, 02:30 PM   #8
Warin
Retired
Oddometer: 2,122
This is a double thread - as this thread has been moved from another forum .. the other thread is on
http://www.advrider.com/forums/showt...3#post26177123
A standard R80G/S 1980s will get
20km/l at 80km/h ...
or 50mpg (us) at 50mph.
That is with luggage, on dirt. Standard jets, needles. May have had a Staintune exhaust.
Warin is offline   Reply With Quote
Times are GMT -7.   It's 04:00 PM.
