Old 11-30-2012, 07:33 PM   #1366
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,682
Originally Posted by GSD4ME View Post
Pity it`s already sold. It sat around for ages now people want it.
I didn't really want it but was very interested in the technology and mods he did.
Sort of hoped he was going to do a full on dirt bike with it and come an play on the side of the volcano ocassionally
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 12-01-2012, 03:29 PM   #1367
RealOldDualSportGuy
RealOldDualSportGuy's Avatar
Oddometer: 483
Tires for the SC Sand
Any suggestion as to tires for the Sand Blast rally?
Stage Hand has us "hooked" on rallying in the sand come spring.
Any and all assistance/input is appreciated.
Regards
Blame It on Stage Hand
I wont be wronged, I wont be insulted, and I wont be laid a hand on. I dont do these things to other people, and I require the same from them. John Wayne -- The Shootist (1976)
RealOldDualSportGuy is offline   Reply With Quote
Old 12-01-2012, 03:39 PM   #1368
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,488
Tom!
I was just thinking about you, today.
I recommend D606's. They're DOT, (which is technically required byt he rules ) and they have good sand bite (when they're new) and they're relatively cheep and they are made in a 17 and an 18".
My personal preference.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 12-02-2012, 07:46 AM   #1369
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,232
Originally Posted by Stagehand View Post
SInce the short width of the R65 stems from the short con-rods, and one is required to shave the cylinder bases down anyway, is it feasible to simply put short con-rods in an R100?
A bit (4.5mm?) of the narrowness also comes from the shorter stroke. For a high-RPM motor I suspect short rods with regular stroke is a bad idea. The narrow race motors of the '70s used extreme pin location in the piston. On some (or all) you had to remove the rings to get the pin out. There is one such motor about 100 miles away; I should go check it out.
I think the mix 'n' match logic goes like this: if you want the shorter rods you need the shorter stroke. Once you have the heads closer to the crank you might as well use the R65 block for better pushrod angle. Therefore, use the whole R65 bottom end. The problem with that (in the old days at least) has been the lack of cam selection, and I think some vintage racers are using the R65 setup in R100 blocks and just accepting the funky lifter angle.
Old 12-02-2012, 10:55 AM   #1370
RGregor
Oddometer: 446
They also used 125mm rods (Butler & Smith and Helmut Daehne for example). That's minus 10mm each side.
Gives about the same rod-length ratio like in the oilheads.
I would think the 118mm rods of the small blocks would be a bit too extreme in combination with the long stroke.
In the meantime Schleicher offer a variety of cams (from 320 to 344) for the small blocks.
RGregor is online now   Reply With Quote
Old 12-02-2012, 06:59 PM   #1371
Owly
Into the Dark
Owly's Avatar
Oddometer: 152
I read that Helmut Daehne's bike with the shorter barrels, the engine was taken off the production line and where the push rod tubes go into the block, that the block had to be machined to allow for a steeper angle on the shorter push rods.
But i am no expert engine builder.. Just a reader
a BMW Tragic
Owly is offline   Reply With Quote
Old 12-02-2012, 07:06 PM   #1372
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,488
Here I am wondering if its more manly to build a damn bike and race it and knowing me that is a dodgey prospect, the build part) rather than just get a hold of one any way I can. And go race it. Especially listening to you guys talk tech, god I am forty years old there isnt enough time in the day to take in all this info, I should have started back when I was just a kid, instead of this whateverthehellitisIdo, The race, I now realize is all about the suspension. Tied with reliability.
Good old reliable R100? or hotted up 650 with shaved private parts and an unfamiliar cam stuck in its hoo ha.
Ooo but the little hottie is tempting. Should I waste my time building it? Or have somebody build most of hte damn thing and I just put my resources into fixing what i break out in the bush?
Old 12-02-2012, 08:23 PM   #1373
igormortis
igormortis's Avatar
Oddometer: 1,358
Well, I guess you've worked on Rider for a bit. Now do Chassis. When you can't go any faster, build a stonking Engine.
igormortis is offline   Reply With Quote
Old 12-03-2012, 12:33 AM   #1374
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,682
Rolling Chassis aint that hard.
Running gear and adding the elusive lightness is the hard part.
Weight loss from the motor is minor compared to other areas of fat.
Engine weight loss is an expensive chase usaully combined with increasing the performance.
Like you said. You have enough power already.
P.S. Forty is young but it doesn't last much longer
Old 12-03-2012, 03:22 AM   #1375
Prutser
Prutser's Avatar
Oddometer: 995
On a picture that was put on airheadsdown under fb. (on the MX track)You really tried to snap the bottom shock mount.
How much problems do you have with the suspension ?
The travel in Paul's bike must have been great. But would you mind to have your bike that tall when doing single tracks with technical sections ?
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 12-03-2012, 06:44 AM   #1376
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,406
I know where you can get a bike that's halfway there!
Uploaded from the Photobucket iPhone App
hardwaregrrl is online now   Reply With Quote
Old 12-03-2012, 07:33 AM   #1377
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Rapid Dog is offline   Reply With Quote
Old 12-03-2012, 08:38 AM   #1378
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,488
Originally Posted by Rapid Dog View Post
Lol! I know that bike!
Old 12-03-2012, 08:50 AM   #1379
hardwaregrrl
ignore list
Oddometer: 7,406
nathan mende has it. Has had it for almost a year. Rebuilt the trans, the carbs, and a new clutch. After all of that, he's asking 4500 I think. That's why it hasn't moved, but it is a damn blast to ride! I want the bike, but can in no way afford it right now. If anyone is interested let me know. I've tried to sell it for him, just not here for fear of being flamed. And I will say, I've tried to convince him to let me race it at Sandblast.......but he wasn't going for that one.
Old 12-03-2012, 10:48 AM   #1380
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,488
How low does it feel in the rear? I always thought it needed a longer swingarm, it just doesnt have it yet
That might be a good start, though, get it back up in NY where it was born, prodigal son returns, etc
Adding lightness I love that
One more week of Nutcracker, then I see about what we can do with the monster/mistress already waiting down there. Lets maybe just trail ride that once or twice and see?
Paul says I should maybe buy a race bike from him, come down to the Safari again, and take advantage of the race org's free shipping to get it back home. That sounds pretty efficient in all ways but financially
Times are GMT -7.   It's 12:27 PM.
