12-07-2012, 05:48 AM
#1396 |
Chronic Noob
Oddometer: 2,302
Monolever or twin shock.
Nicasil motor. No SWB.or skinny twin shock swing arms. Wire wheels. Cross spoked wheels have their own complexities when mixing and matching parts. Kick start is cool optional bling.. Unless you want to end up with a G/S or GS variation look alike start somewhere else as examples of the model(s) and the genuine defining parts are expensive. Rest is up to you depending on what the intended purpose.
If the Earth is flat why are my tyres round? |
12-07-2012, 01:45 PM
#1397 |
Oddometer: 77
Keep racing you'r PD can't get any cooler than that!
![]() Try to improve some things but keep the "stock" looks of the bike. Can't get much better than this: ![]() or this:
12-07-2012, 01:58 PM
#1398 |
+/- V TDSPP
Oddometer: 20,326
Thanks mate!
Dont try to out-weird me, mister. I get things stranger than you free with my breakfast cereal. |
12-07-2012, 02:14 PM
#1399 | |
Oddometer: 516
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
12-12-2012, 12:07 PM
#1400 |
+/- V TDSPP
Oddometer: 20,326
I think its time I ditched the oil cooler on the PD.
That means I pull the center stud in the canister and get a new cover, right?
12-12-2012, 12:13 PM
#1401 |
Scope Creep's Victim
Oddometer: 2,284
Yep. Earlier Airheads had a center stud (Oil Flow pipe) that was simply shorter ... I don't think removing it would change it significantly. I have a couple if you want one. There is an R65 block from 83 right here ...
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
12-12-2012, 12:17 PM
#1402 | |
Oddometer: 516
Or you could just bypass it with a hose instead of the cooler.
12-12-2012, 01:15 PM
#1403 |
Location: Moving further away from Wellington, New Zealand
Oddometer: 1,096
Why's that?
Operation: Battle Panda |
12-12-2012, 01:31 PM
#1404 |
+/- V TDSPP
Oddometer: 20,326
I feel like it's dead weight. Fun bling, but I dont need it. It makes my oil changes just a little bit more difficult because the lines are in the way of the cover bolts. The R65RR didnt have one, and it got hot and revved its guts out and didnt flinch. I am certain its not required. Its a stock cooler with TT relocation kit. Regarding the R65- It has been correctly pointed out that if i cant make it to the finish on the bike that is in the final approach right now, what good is it to try and start another? (Unless I just pay somebody to make one
12-12-2012, 03:58 PM
#1405 |
Oddometer: 3,473
Well I happen to have some parts that I'm eying up... want to check the actual lifter angles of the two block types before I decide which to use but if there are no performance cams for the R65 (type 248 AFAIK) block then I'll go with a 247 block. I know this info is out there somewhere but sometimes it's easier to just compile your own.
I have both blocks. A good R65 block and an R80 block with a wasted oil pump. And one or two older R100 blocks. Aren't they just adorable? 17 or 18mm shorter.
12-12-2012, 04:41 PM
#1406 |
Traveler
Oddometer: 234
So this means you can run the non-hinged one piece filter right?
Dan in VT http://vtbeemer.blogspot.com/ 93' R100GS/PD- 06' F650GS- 94' R1100RS 04 R1150R- 91' BMW K75s- 57' BMW R69 77' R75/7- 06' Ducati S4R Monster 74' XL 250- 08' WR250R |
12-12-2012, 04:56 PM
#1407 |
Oddometer: 3,473
What matters is that it's the short one, hinged or not. The unhinged short one went NLA a few years ago.
12-12-2012, 05:04 PM
#1408 |
+/- V TDSPP
Oddometer: 20,326
Anton
12-12-2012, 05:33 PM
#1409 |
Oddometer: 2,284
+1 ... you're going to have to find the shorter one. Good luck.
01-09-2013, 12:09 PM
#1410 |
+/- V TDSPP
Oddometer: 20,326
Sandblast Rally has been pushed backa month, to the beginning of March. I'm basically ready.. I'd race it right now, although there are some things I need to do. Have a small hole developing in the crosstube on the header. Blinkers are all gefuct. Thinking of retrofitting some flushmounts, and getting away from the tape-and-anglebrackets-trying-to-make-stock-one-work Those two things are the most annoying right now. I have a little too much oil in, probably half a quart or so, what the worst that could happen? It gets pushed into the air filter? annoying valve tappiness on the right hand side, especially when cold. Probably the damn rockers. ![]() Want to shed the oil coller as I said, and there you have it.
