Thread Tools Rating: Thread Rating: 27 votes, 4.89 average. Display Modes
Old 04-03-2011, 04:04 AM   #256
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,715
Originally Posted by MZcountryboy View Post
I'm some shifter and throttle linkage away from being there. Don't think it hasn't crossed my mind.
Lawn chair screwed to piece of plywood?
I double-dog dare ya!
Screw down two so Melanie can go along and get some sweet footage.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 04-03-2011, 05:15 AM   #257
MZcountryboy OP
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
Originally Posted by Boatman View Post
I believe this guy holds the same philosphy,,, snapped the pic outside the local Harbour Freight this afternoon...
That is awesome, Boatman! How much $$ did you offer him on the spot???!
Although some might object to the flat black and red wheel bit, but not me.
MZcountryboy is offline   Reply With Quote
Old 04-03-2011, 07:55 AM   #258
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,429
Late one night, I got my V8 Cortina running, but no throttle cable/pedal. I was so excited to show my buddy, I hooked up a coat hanger to the carb and pulled on it to drive the car to my buddy's house. That made for a real interesting ride! btw, he wasn't home.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 04-03-2011, 08:06 AM   #259
Gimpinator
This is my Mom's cat
Gimpinator's Avatar
Oddometer: 1,121
Cam break-in! Don't run that engine at idle like that until you've had it up at 2,500 rpm for a few minutes.
With today's low-ZDDP motor oils, people are losing cams like crazy on new builds. You'd hate to have to tear that thing down again...
"Son, I thought by now you would have run out of stupid."
Gimpinator is offline   Reply With Quote
Old 04-03-2011, 09:00 AM   #260
MZcountryboy OP
Oddometer: 5,466
I've been reading about that too, needs additive and extra (more than idle) oil pressure to break in properly.
I've only run the engine about 5-6 minutes total so far, and none of that was less than 2000 rpm, as the manifolds didn't seal well enough to idle properly.
I can't really finish the break-in until I get a radiator in, and that will take the body, as the rad support mounts to both.
I just wanted to spark it up, to hear it run! Adds fuel to my "finishing it" fire.
Soon, when the timing is set right, and I have a radiator, I'll do it by the book.
Old 04-03-2011, 09:08 AM   #261
Hughlysses
Hughlysses's Avatar
Oddometer: 3,340
It sounded like he had it revved high enough once he got the timing straight. Crane used to have a list of break-in recommendations in the their catalogs. IIRC, the main points were:
(1) use assembly lube on everything when putting it together
(2) pre-lube before cranking
(3) get the timing and fuel right BEFORE trying to crank it so that you don't have to grind the starter for 5 minutes before it fires
(4) bring the RPM up to ~2500 or so as soon as it fires. VARY the RPM so oil flung off the rod bearings gets thrown to different parts of the inside of the engine during this critical period
(5) DON'T let it idle for any length of time until the cam and lifters are broken in
(6) after ~30 minutes of running like this, the cam and lifters are broken in and you can worry about breaking the rings in however you see fit.
I think MZ's covered every one of those so far as we've seen. I'm sure those steps are more critical for high-lift high performance cams too; they're probably less critical for a mild cam like this.
Oh yea, they recommended the addition of GM Engine Oil Supplement (EOS) to the oil. I don't know if they even make they stuff any more.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 04-03-2011, 03:11 PM   #262
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,608
Flat black and red wheels are only OK when they're absolutely filthy.
Suck, Squeeze, Bang, Blow
Roadracer_Al is online now   Reply With Quote
Old 04-03-2011, 05:56 PM   #263
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Imagen what you could do,if you knew someone who owns his own garage,and fix's cars for a living.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 04-03-2011, 09:36 PM   #264
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,912
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 04-04-2011, 07:25 AM   #265
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
"Soon, when the timing is set right, and I have a radiator, I'll do it by the book."[/QUOTE]
I seem to recall you pressurizing the oiling system by running your oil pump with a drill. That would have to help.
I've been reading more about the effects of ethanol on my old parts and I think know why my gas gauge needle has palsy - alcohol-corroded connections. I'll find out when I pull the sender.
This stuff seems interesting:
http://www.eastwood.com/review/produ.../category/156/
I found quite a bit of scuffing on my engine parts. I know the PO changed the oil regularly so I'm wondering if the lower zinc level in today's oils was partly to blame.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 04-04-2011, 07:27 PM   #266
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,159
MZ Boy certainly knows what he's doing. He can work on my broken shit anytime he wants to come visit.
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is offline   Reply With Quote
Old 04-06-2011, 07:21 AM   #267
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Napco 57 gmc
http://jalopnik.com/#!5786093/1957-gmc-panel-truck
bwanacswan's dad
Old 04-06-2011, 07:42 AM   #268
110
Oddometer: 126
Originally Posted by MrBob View Post
Even has its own pedestal...
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you."
110 is offline   Reply With Quote
Old 04-06-2011, 09:49 AM   #269
Roadracer_Al
Oddometer: 1,608
OOOoooh. Lusty. Those NAPCO conversions are super-desirable, and priced to match, unfortunately.
Old 04-06-2011, 05:30 PM   #270
vtwin
vtwin's Avatar
Oddometer: 7,429
This was in the movie "Man Without A Face" with Mel Gibson. I "borrowed" this picture from this sight.
http://67-72chevytrucks.com/vboard/showthread.php?t=282284&page=3
Monroe.
unknown
Thread Tools
Times are GMT -7.   It's 05:07 PM.
