Thread Tools Rating: Thread Rating: 27 votes, 4.89 average. Display Modes
Old 01-16-2013, 03:45 AM   #451
MZcountryboy OP
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
Originally Posted by AKjeff View Post
I like the paint. It's not as flat as the rattle can jobs I see on CL. That look is getting old.
Was the mineral spirits only to allow it to roll nicely, or did it add the slight gloss to the finish?
I'm thinking I'd like to do a two tone with similar black and a gloss contrasting color.
Mineral spirits is to thin the paint so that it dries with no orange peel. Some of the internet guys don't like the flat paint on the roller jobs, as the roller marks + brush marks are hard to hide. I was super careful to roll it out evenly and then the very last roll with no pressure on the roller frame. Most folks use a gloss paint, and wetsand between coats to get a nice finish, like JVB has on the red door.
I did no sanding between coats.
I did a bit of research and Rustoleum reccomends thinning with acetone only, but this is due to new VOC regulations, not performance. The roller paint guys say that the acetone takes too long to dry, and mineral spirits works better, I used the "green" mineral spirits even, and it came out great.
MZcountryboy is offline   Reply With Quote
Old 01-16-2013, 03:50 AM   #452
MZcountryboy OP
Oddometer: 5,466
Originally Posted by Speedo66 View Post
The paint looks great. I saw the mix ratio, but what is the technique?
What type of roller do you use?
The roller paint guys reccomend the foam brushes and foam roller covers. I used the foam brushes (no brush marks!) and a regular 3/8 nap roller cover. During the first coat it is important to let the roller soak up some paint and "steep" for a while, I got lots of air bubbles on the roof (they dried out fine....) on the first coat, but once the roller was saturated, it went much better. Roll it on as thin as you can to get coverage, then come back and add multiple coats to get the finish desired. 3 coats was enough for me, some people go 5 or 6 if wetsanding between coats.
Old 01-16-2013, 05:42 AM   #453
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,144
I'm another believer in the roller job, having painted my BMW race car that way. Did it as a joke after reading about it on the interweb, and get endless giggles from people who look at it and can't believe that's how it was done. I went with a higher dollar Inerlux boat paint, which doesn't require as much thinning (and thus as many coats). The no-buff finish is really glossy, and if you get the technique down you can achieve an almost glass-smooth finish that will fool just about everybody to think it came from a gun.
It is more labor intensive because of the multiple applications and sanding between (I did it more for adhesion than to smooth it out), but the lack of mess from spraying in my home garage was worth it, not to mention the savings in materials over 'real' auto paint. Just remember, it doesn't do anything for your prep quality; do a crappy prep job and it will look like crap! You can't hide bad prep no matter what path you take.
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is offline   Reply With Quote
Old 01-16-2013, 07:05 AM   #454
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,656
Originally Posted by MZcountryboy View Post
One who wishes to maintain his marital bliss does not count the pennies spent on a folly of a restoration project.
(run away from the CL rustbombs!........)
Hahaha, that's true. I've done just enough body work to know it's a miserable job, but you make it look so eeeeeeasy!
cjbiker is online now   Reply With Quote
Old 01-16-2013, 09:49 PM   #455
Speedo66
Transient
Oddometer: 6,744
Thanks for the info! One day I may attempt something more my size, like a bike tank.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-19-2013, 04:36 PM   #456
MZcountryboy OP
Oddometer: 5,466
mustache and bumper on the front, I have most of the new wiring harness is as well.
Glass on the passenger door is in, with all new fuzzies.
Old 01-19-2013, 04:56 PM   #457
Beez
Given to fly
Beez's Avatar
Oddometer: 5,798
Looks great Scott!
Beez is offline   Reply With Quote
Old 01-19-2013, 09:07 PM   #458
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,818
Absolutely gorgeous
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 01-20-2013, 04:44 PM   #459
cbolling
Here...Hold my Beer.
cbolling's Avatar
Oddometer: 2,910
nice work!!!
2011 Kawasaki Versys
http://www.advrider.com/forums/showthread.php?t=661436
cbolling is online now   Reply With Quote
Old 01-20-2013, 05:15 PM   #460
ADK
____
Oddometer: 8,201
Laugh
Go back to post 1 to see what he started with...
ADK is offline   Reply With Quote
Old 01-21-2013, 10:14 AM   #461
c.herman126
c.herman126's Avatar
Oddometer: 527
Awesome progress Scott! It's all coming together.
"Dream as if you'll live forever. Live as if you'll die today" James Dean
1993 XR650L
2008 530 EXC-R
c.herman126 is offline   Reply With Quote
Old 01-26-2013, 02:46 PM   #462
MZcountryboy OP
Oddometer: 5,466
back door glass in with new rubber gasket
tail lights are in, almost wired up. chrome is pitted, matches the bumpers - $5 plate light. Can't find the right one....
side glass in passenger door
current engine bay pics -
made good progress on the wiring today, got the blinkers working!
Old 01-26-2013, 03:46 PM   #463
Hughlysses
Hughlysses's Avatar
Oddometer: 3,327
(Sigh...) I remember when you could actually see the engine in a car and had plenty of room to work on it.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 01-26-2013, 04:30 PM   #464
troidus
Oddometer: 14,359
There's enough room in there to jump in with it and pull the hood down over you to keep the rain off.
troidus is online now   Reply With Quote
Old 01-28-2013, 12:11 PM   #465
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,790
Scott, your handiwork is incredible! It serves to remind me that I need to get my butt back in gear with my '57 Chevy 3100. I started out with a shell and a good rolling chasis. I put in a 350/200-4R and a disc brake / PS conversion on the straight axle. Bump steer was scary at best, and I decided on a Camaro subframe.
After the Camaro subframe was done, I wanted fuel injection and went with an old Crossfire system from an '83 Z-28. I never did get it quite right. Now the bug has bit me to make mine NAPCO-esque.
I need to replace some of the cab floor, and the thought crossed my mind to mount the body on a 1994-2001 Dodge Ram 1500 4WD chasis with a modified wheelbase to match the body. I have a Jeep Cherokee with a 4.0L 4X4 drivetrain that I am going to use instead of the 350. I want to enjoy driving this, not filling it up everytime I turn around.
Thanks for the motivation to get my butt in gear again!
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is online now   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:44 PM.
