Thread Tools Rating: Thread Rating: 27 votes, 4.89 average. Display Modes
Old 01-27-2011, 06:05 PM   #91
MZcountryboy OP
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
That is some spectacular looking roller paint there, Dwight, although I'm really diggin' the matte black on the Camaro too. I think I am going to have to try it.
Did you have to build a trophy room yet, Mr. Race Car driver?
MZcountryboy screwed with this post 01-27-2011 at 06:20 PM
MZcountryboy is offline   Reply With Quote
Old 01-28-2011, 05:47 AM   #92
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,663
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is online now   Reply With Quote
Old 01-28-2011, 08:43 AM   #93
hankgs
Oddometer: 1,906
Mad Skills
Man, I wish I could attempt a "multi-faceted project" like this... To have a shop, tools and skills- Awesome!
If there is anyone in my area doing a project like this and needs a noob-grinder, tool getter or clean up guy-let me know!
Thanks for the post!
hankgs is offline   Reply With Quote
Old 01-28-2011, 11:55 AM   #94
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,643
It's amazing to me that those hinge boxes are available! I did some restoration work on a '73 IH Scout II, and there wasn't much available.
I hesitate to mention this, since you've already got it finished....
If you feel like buying tools, one of these is really pretty sweet to have and not terribly expensive:
Horrible Fright Shrinker/Stretcher
This tool would have let you get the entire windshield surround done in one piece. I have a pair of the smaller units (the bigger one hadn't come out yet) and they're a real treat to use, although the greater throat depth would be very nice. With two bodies, you don't have to switch jaws all the time.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 01-29-2011, 05:03 AM   #95
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,194
Not yet. The key to me getting a trophy is to select those races that will be terribly under-subscribed. My first two races only had 3 cars in the class. I'd have won one of them after the leader spun had my head not been up my posterior during a yellow flag. Stupid noob mistake. In 'real' races I've finished as high as 5th, which is pretty good considering I have the wrong wheel/tire package, a power steering pump that is still hooked up and driving skills that are best classified as 'average'.
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is offline   Reply With Quote
Old 01-29-2011, 05:32 AM   #96
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,754
Originally Posted by ddavidv View Post
THREAD HIJACK WARNING
Not what I was going for...the point was to be an homage this:
So I wound up with this (sorry for the ginormous image):
I've since fixed the stripes to the right color scheme.
THREAD HIJACK OVER--back to Saving The Panel Truck
Whew! For a moment there I though you were waiting for things to dry to get the green stripes on to match the KLR in your avatar.
How's that motor coming along, Scott?
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 01-29-2011, 05:46 AM   #97
MZcountryboy OP
Oddometer: 5,466
I finally found one of those parts that seemed to be impossible to buy. Thank-you, ebay.
The exhaust manifold on the 250 6 cylinder uses a heat riser setup to warm the intake manifold and carburetor faster when the engine is cold.
On the V8 - this was a bolt on unit on the bottom of the collector, and can be replaced easily. The 6 cyl has it built into the manifold, and is welded in place. The key to making it work is a temperature sensitive bi-metallic coil spring, that wraps around the shaft of the flapper valve next to the counterweight.
Cold engine:
Hot engine:
My spring was broken, and the heat riser was inoperative. Replacing the spring required cutting the flapper from the shaft and pulling it out of the manifold, then re-welding.
The 1/4" bolt is the stop for the spring, the original pin was rusted away.
Got the carb on the intake - along with my fast idle cam + link rod.
The two manifolds nest together -
All new studs, (one of the collector studs needed to be drilled out, and wow, I didn't get it very straight, but the collector flange has elongated holes, so it should be OK. (I can always bend it if need be.....)
Getting close to being ready to put a motor together.
MZcountryboy screwed with this post 01-29-2011 at 05:51 AM
Old 01-29-2011, 06:05 AM   #98
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Thats really cool you're going through the stock setup parts instead of going all repop :)
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 01-29-2011, 04:00 PM   #99
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,191
Subscribed and loving it!
Whitey1 is offline   Reply With Quote
Old 01-29-2011, 05:17 PM   #100
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,975
I was headed off to read a book until I found this. What a great read, MZ.
Adding another subscription...
Laconic is offline   Reply With Quote
Old 01-29-2011, 07:05 PM   #101
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
[/QUOTE]
The maintenance trick for the heat riser valve back in the day was to give the counterweight a wiggle every time you checked the oil. Keeping the unit moving freely greatly extends the life of the spring. They usually didn't require much more maintenance than that - dead simple.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 01-29-2011, 07:54 PM   #102
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
What??? You never used GM's special Heat Riser Valve Lubricant.....!
Worked great to release rusty fasteners too, I remember the smell to this day.
Great thread BTW, reminds me of all the hours I spent on a similar GMC owned by a friend, installing a 350 Olds engine in it.....back in 1974.
Have tools, will travel!
Old 01-30-2011, 05:23 AM   #103
natedog39
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,550
Count me in.
Maybe over the summer both our projects will be in the same place at the same time,,,,that'd be a cool photo op.
Keep up the good work.
2014 FE 501
2012 990Adv
Team Ghetto does a hot lap of America
natedog39 is offline   Reply With Quote
Old 02-01-2011, 12:29 PM   #104
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Here's something to shoot for
bwanacswan's dad
MrBob screwed with this post 02-01-2011 at 05:24 PM
Old 02-01-2011, 12:34 PM   #105
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Super crappy photo of my old sedan delivery. This was a 52 Pontiac and Canadian made with a combination of Pontiac and Chevy parts.
bwanacswan's dad
Thread Tools
Times are GMT -7.   It's 04:23 AM.
