02-01-2011, 04:27 PM
#106 |
Dude Buddha
Oddometer: 575
[QUOTE=Roadracer_Al;15032660]Living the dream, MZ! I have similar fantasies about '50s era Willys wagons. This is why I hate the internet -- because it makes undertakings like this seem reasonable.
I'm not jealous of the panel, I'm jealous of your garage - and as the happy owner of 3 Willys 4x4 wagons, very jealous that you can find re-pop parts so readily. Well, OK, the panel is lovely too. Of course I also have an FJ45 one ton Toyota 4x4 truck, so I guess I like the odd ball stuff. Nice work. I must builds me a big shop this year. And it has to be big enough to take the Hagglunds BV206 on the trailer... |
02-01-2011, 05:37 PM
#107 |
Ouch.. Ta Daaaaaa..
Very cool!!!
02-02-2011, 03:19 AM
#108 |
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,201
Jeez-louise - you weren't kidding aobut the bits falling off. Are both the headlights taped in? I suppose they weren't bright enough to worry about aiming them anyways..............
![]() Thanks for digging that up - |
02-02-2011, 06:47 AM
#109 |
Careening forward
Oddometer: 5,662
The tape would get wet and the headlights would fall right out onto the street.
KLX 400 dual sport Tune in, turn on, drop out. |
02-02-2011, 11:30 AM
#110 | |
A proud pragmatist.
Oddometer: 2,859
![]() But I tought that chrome looked familiar, after all I learned to drive on a 57 Chevy PU, 4x4.
Have tools, will travel!
02-13-2011, 04:13 AM
#111 |
Oddometer: 5,201
Got my starter motor back from Wild Auto Electric in Barre, VT - They took my starter apart,checked it all over, replaced the solenoid, rebushed the drive gear pinion, and shot a *really* thin coat of paint on it. Looks great, and only cost me $44. I was astounded.
![]() The machine shop doing the driveshaft called - it's ready!......... |
02-13-2011, 05:16 AM
#112 | |
Down & Out
Oddometer: 2,928
The "thin" coat of paint on the starter provides a good patina. |
02-13-2011, 02:58 PM
#113 |
1.5 Finger Discount
Oddometer: 20,075
Fuckin
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
02-18-2011, 03:55 AM
#114 |
Oddometer: 5,201
been snowmobiling with my Dad, who is up from FLA. Haven't made much progress, but a few things are coming into place.
got some more primer on - ![]() yesterday, I tangled with the door latch + remotes on the d/s rear barn door. this is the center latch, that uses pivots + link rods to activate the upper + lower door latches. The two square blocks pivot and the link rods thread into them. It was all frozen, and both link rods broken. ![]() broken link rod - ![]() the threads are #10 x 24 - pretty small. cut the threads off, weld on a piece of machine screw. The other end of the link rod has a large pan-head screw head for adjusting, and cannot be easily duplicated. ![]() lower latch was frozen on one side, and the attachment arm was broken. welded that up. ![]() ![]() I had to drill/tap one of the lower retaining bolt holes. ![]() I got it all back together + functioning, the bottom of the door where the lower latch bolts in had rusted badly, letting the latch move around. Welded a small patch in, and now it is secure. Scored a p/s barn door check strap assembly off ebay, mine was mia. The rear doors are now working good, I may not take them off. |
02-18-2011, 06:44 AM
#115 |
"Cool" Aid!
Oddometer: 41,497
That is looking great! Nice work on the paint and door hardware!
![]() Jim
02-18-2011, 11:32 AM
#116 |
Countersteer it.
Oddometer: 2,847
Damn. I just got to the last post on the last page and I feel like someone just put poop on my cupcake.
Good stuff MZ....can't wait for more.
Don't know why I'm lost all the time... Everyone is always telling me where to go. |
02-27-2011, 03:50 PM
#117 |
Oddometer: 5,201
here we go, this afternoon - ripping into the bottom end, changing the oil pump + rear main seal.
old pump - ![]() new pump - melling stock volume/pressure ![]() oil screen/pickup reintalled - ![]() I'm going to change the cam and timing gears for new ones - ![]() the camshaft is worn in a few places. it's outta here! ![]() fuel pump lobe - ![]() lobe with wear - ![]() rear main seal is next - |
02-27-2011, 04:12 PM
#118 |
Oddometer: 581
Chassis and body are looking great ! Noice work, great choice. Subscribed!
02-27-2011, 04:29 PM
#119 |
Oddometer: 5,201
lifters are out!
![]() pulling the cam gear off - ![]() pulling the crank gear off ![]() new crank gear on - ![]() rear main seal out - 1/2 of it anyways. ![]() new main seal 1/2 in - ![]() the other half going in - ![]() all in, a dab or two of rtv to seal the halves together - ![]() new cam gear on new cam - ![]() lotsofassemblylube - and it will be good to go in! ![]() easy!!!!! slow!!!!!!!! ![]() all in - make sure the dots line up w/each other!
02-27-2011, 05:29 PM
#120 |
"Whitebread"
Oddometer: 9,331
Looking good!
| Thread Tools | |
