Old 04-04-2013, 09:03 PM   #136
4play
Next?
4play's Avatar
Oddometer: 2,531
For anyone who wondered about the difference in seat fit between a Ninja & a Versys tank.
Sitting & standing, I like the Versys tank better..
Family isn't always about blood
4play is offline   Reply With Quote
Old 04-05-2013, 08:17 AM   #137
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
Any other mods required to use the Versys tank?
Old 04-05-2013, 08:41 AM   #138
4play
Next?
4play's Avatar
Oddometer: 2,531
The mounts are the same, it slips right on.
JDRocks had to use the Versys slightly longer fuel line, because the Ninja fuel pump is clocked differently. The 5 bolt flange is not symetrical so you can't just reposition it.
All I've done so far is bolt it down, but as far as I know the fuel line is all that's required to install the tank on a Ninja. The seat fits the mounts, just has a gap..
4play screwed with this post 04-05-2013 at 08:55 AM
Old 04-05-2013, 06:38 PM   #139
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,239
You could build the seat foam out to match the tank.May look odd tho.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 04-05-2013, 06:44 PM   #140
4play
Next?
4play's Avatar
Oddometer: 2,531
The seat is a non issue for somebody like
Fisher, it'll look like OEM or better when he's done. I was going to have the seat redone anyway, for comfort and to get it all one color.
4play screwed with this post 04-05-2013 at 09:29 PM
Old 04-09-2013, 06:34 PM   #141
4play
Next?
4play's Avatar
Oddometer: 2,531
Swing arm is done, should be plenty stout
4play screwed with this post 04-09-2013 at 07:09 PM
Old 04-09-2013, 09:51 PM   #142
4play
Next?
4play's Avatar
Oddometer: 2,531
It rolls!
The 950# spring rate feels pretty good jumping up & down on it in the shop.
I didn't measure the sag, but it has some static & the race sag felt about right. I'm thinking about mounting the computer under the rear rack. I'm still trying to decide on a rear fender/tailight/license plate holder.
Old 04-09-2013, 10:08 PM   #143
ktmklx
ktmklx's Avatar
Oddometer: 689
Nice job on the swinger and the pegs, looking good!
ktmklx is offline   Reply With Quote
Old 04-09-2013, 10:44 PM   #144
4play
Next?
4play's Avatar
Oddometer: 2,531
Thanks, I appreciate all of you guys that led the way & shared your builds
Old 04-11-2013, 01:48 PM   #145
4play
Next?
4play's Avatar
Oddometer: 2,531
I really don't like the ignition switch assembly, but it works, it's free & I hid it here for now. Still thinking
Old 04-11-2013, 03:52 PM   #146
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
+1, it's a dang heavy thing as well!
Old 04-11-2013, 06:33 PM   #147
dentvet OP
Oddometer: 1,345
You are doing great on your mods and i love that bike stand that you rigged up. I kept thinking of stuff to do with that tube running through the center of the bike. you could store some full size roll up maps in that thing.
This guy has a simple ignition switch on his rat bike
http://www.advrider.com/forums/showp...1&postcount=23
dentvet is offline   Reply With Quote
Old 04-11-2013, 08:07 PM   #148
4play
Next?
4play's Avatar
Oddometer: 2,531
Thanks, it sure helped having a head start
Without the rubber bump stop figuring 2.75" of shock travel, I get just over 9" of wheel travel, using a more realistic 2.5" with the snubber compressed I get 8.25"
With the rather large 150/70-18" Mefo Super Explorer This is my clearance bottomed out.
Brake pedal is now lower, I trimmed the spacer to bring the guards in almost a 1/4" and reversed the bolt. I think the "fake brake" will be a non issue
Old 04-13-2013, 08:03 PM   #149
4play
Next?
4play's Avatar
Oddometer: 2,531
I was not happy with the flex I was getting at the pegs from the 3/16" steel plate being unsupported for ~4". I welded a 1/8" x 3/4" strap on edge on the back & they are rock solid now, no need for additional bracing. I had forgotten about the brake switch, looks like I'm going to have to use a pressure switch/banjo bolt. With the brace, I don't see a reasonable way to mount the original pull switch.
Foot controls are done! I'll paint the shifter assembly after I'm sure about it. I don't like the angle of the linkage, but it seems to function fine.
Old 04-25-2013, 02:41 PM   #150
4play
Next?
4play's Avatar
Oddometer: 2,531
Extending the seat base. I've never worked with ABS before, now I'm thinking about using this stuff for the inner fender.
I still need to trim & remold the bottom, but I'm getting closer.
Times are GMT -7.   It's 10:04 PM.
