02-15-2012, 05:54 PM
#106 |
Oddometer: 535
pretty good idea sonoran !
rompin stompin tiger 800 XC rider |
02-15-2012, 06:23 PM
#107 | |
incognito
Oddometer: 15,939
2. I agree. If those butterfly stiffeners can be made a bit beefier and laminated into the bag material I think it would be a great improvement.
the sun does not have no prisoners |
02-15-2012, 09:36 PM
#108 |
Oddometer: 7
Has anybody tried the WM bags on the side with a Giant loop bag on top?
02-16-2012, 08:11 AM
#109 | |
incognito
Oddometer: 15,939
I keep my wolfman's on for daily use, the GL Great Basin goes on for extended trips.
02-16-2012, 05:10 PM
#110 |
Oddometer: 326
Sonoran:
"It's a tight fit. All of the buckles need to be undone to get it in there" Once the plastice container is in there, can the buckles be hooked up or do you have to leave them undone permanently?
A gun is like a parachute. If you need one, and don’t have one, you’ll probably never need one again |
02-16-2012, 07:07 PM
#111 |
incognito
Oddometer: 15,939
No you can adjust the straps and reconnect the buckles. There is plenty of length to accomodate the container.
02-17-2012, 06:49 AM
#112 | |
Oddometer: 1,841
![]() ![]() I'm glad it worked out. It's so nice to have something you can actually use around town. Yours probably looks better than mine because I used a pocket knife in the walmart parking lot when I made mine.
Ride 365 LLC Braaaap! |
02-19-2012, 01:19 PM
#113 |
Oddometer: 326
Sonoran: Thanks for the tip. I picked up two of the 5.2 gallon Sterilite containers from Walmart -- cut them to 11.5 inches -- drilled the hole in the bottom to expel air -- and shoved them into the Wolfman bags. VERY tight fit but once inside, EXCELLENT. Sort of the benefits of a soft bag and a hard bag without the downsides of either.
02-19-2012, 01:40 PM
#114 | |
Miserly Adventurer
Oddometer: 95
'12 DR650 '93 DR650 |
02-19-2012, 05:53 PM
#115 | |
Oddometer: 1,841
Where you guys been? I posted the same thing months ago.
![]() Quote:
02-19-2012, 06:27 PM
#116 |
Oddometer: 326
fbj913: you absolutely deserve credit for the idea. Sonoran refined it some.
Both methods get rid of the crappy stiffeners and make the bags much easier to use.
02-20-2012, 09:47 AM
#117 |
Oddometer: 402
I love this
Hi Guys
Eric with Wolfman. I am really liking this discussion about the "Wings" as we call them. I can talk about the purpose etc. and the design behind them if you wish. They are a bit fussy, I find using the EX-T Stuff never give me an issue. The design of the wings is to allow the bags to expand and contract depending on the load so the load can be compressed and stabilized when mounted to the racks. If a ridged non-flexible liner is put in the load will never be tight unless the bags are stuffed full. Since these are Radio Frequency Welded their are no real good places to attach the "Wings" inside the bags. Also the lie flat so our shipping is less -Especially for export. So I decided to "Float the Liners. I am looking into a White or Natural plastic for internal visability. that is the design behind the wings. I like where this is going though. I really like suggestions. PM me any time I'll try to respond in a timely manner, I do get busy. Thank You Eric/Wolfy |
02-20-2012, 10:23 AM
#118 | |
Oddometer: 1,841
02-20-2012, 10:25 AM
#119 |
Oddometer: 326
Hello Eric: With the flexible butterfly stiffeners, the bag will expand or contract around the load thereby keeping things stable. Also, from a shipping standpoint, the stiffeners lie flat.
Your comments make perfect sense. A criticism I have read many times from customers of the Expedition bags is that they are "fiddly" -- which means not suffiently user friendly. The modification of the bags by inserting the cut down Sterilite 5.2 gallon containers (or similar) addresses several issues. Once the container is in and the straps are cinched up -- that is the end of it in that the user really never has to deal with the compression straps again. Also, the useable space inside the bag is maximized -- the bags are far easier to load -- and the white color of the container makes it much easier to see what is going on in there. Using stuff sacks (like those you sell) for items to be placed in the bags does pretty much eliminate the issue of the load shifting around inside the bag. I think you should leave things well enough alone though and if the end user (like me) wants to make the change to insert the white container -- we can always do so. BTW, I have a number of Wolfman products for several bikes and all Wolfman products are high quality and well designed. Thank you all for that.
02-20-2012, 10:27 AM
#120 |
Oddometer: 402
tonopah
Tonopah Would you be willing to try out an idea??
If so please pm with phone etc I have some ideas. woof e
