Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Old 02-02-2011, 09:52 AM   #61
Brummbär
Pathfinder
Brummbär's Avatar
Location: ööö, here at Colonia Claudia Ara Agrippinensium
Oddometer: 142
Originally Posted by Aurelius View Post
Combat history
All but two of the 91 available Ferdinands were put to use in the Battle of Kursk, the first combat the Ferdinand saw. Although they destroyed many Russian tanks, they performed quite poorly in other respects. Within the first four days nearly half of the vehicles were out of service, mostly due to technical problems and mine damage to tracks and suspensions. Actual combat losses to direct Soviet action were very low as the Ferdinand's very thick armor protected it from almost all Soviet antitank weaponry. However, at this point in its development the Ferdinand lacked a machine gun or any secondary armament, making it vulnerable to attack by infantry. Most total losses of the Ferdinand occurred during the Soviet counter-offensive after the Kursk offensive, many damaged Ferdinands had to be abandoned as they were too heavy to tow and others were lost to mechanical breakdown during the retreat.
You´re more than right...i meant the direkt confrontation between the German/Russian tanks
(...and i just don´t like the designation "Cannon Fodder")
Sending thousands of soldiers against a superior enemy is more Cannon Fodder to me than this Machine...
“Well, you're damned if you do, and you're damned if you don't.”
XT600K ´93 89.000km
XT660Z ´09 33.333km
Brummbär is offline   Reply With Quote
Old 02-02-2011, 10:07 AM   #62
Aurelius OP
Aurelius's Avatar
Oddometer: 22,783
If I remember correctly, the Elephant was the brainchild of Hitler, who demanded bigger and bigger tanks in response to every reversal on the Russian front. The Elephant succeeded in its limited role as a static defense weapon, but it was a very poor design in all other respects.
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius is offline   Reply With Quote
Old 02-02-2011, 10:10 AM   #63
papalobster
With Gusto!
papalobster's Avatar
Oddometer: 13,802
Sturmtiger
Originally Posted by EvilGenius View Post
No looking at the photo tag, that's cheating.
papalobster is offline   Reply With Quote
Old 02-02-2011, 10:27 AM   #64
Hodag
native
Oddometer: 23,307
Originally Posted by papalobster View Post
Sturmtiger
http://www.advrider.com/forums/showp...2&postcount=58
patton museum T-28
Hodag screwed with this post 02-02-2011 at 10:34 AM
Hodag is offline   Reply With Quote
Old 02-02-2011, 10:27 AM   #65
RBR
RBR's Avatar
Oddometer: 90
One big problem with the turretless tank destroyer is the lack of range of motion in the main gun. There are only a few degrees of traverse available. If your target is outside that range you have to move the whole vehicle which screws your aiming up and exposes your location. I imagine most during WW2 were used as a mobile pillbox and engaged other armor from the ambush rather than actively persuing.
~ Never Get Off the Boat ~
RBR is offline   Reply With Quote
Old 02-02-2011, 10:36 AM   #66
Brummbär
Pathfinder
Brummbär's Avatar
Oddometer: 142
A little bit. It´s first Name was "Ferdinand", after his Developer Ferdinand Porsche. The Chassis was first named to be Chassis for the Tiger Tank. 90 of them were built, but then Hitler favoured the design of Henschel´s Tiger. So the 90 Porsche Chassis were used for the Ferdinand, which were, after the Kursk Battle, taken to Austria for several Changes(machine guns, etc.) and then renamed into Elefant and sent to the Italian Front. And yes, Hitler wanted more and bigger ones as the King Tiger, Sturmtiger and never in Series built Tanks as the "Maus" and a so called Landcruiser( should have a weight of 1000tons!).
The ideas were sometimes not bad, but the results were out of touch with reality... Sure, sometimes there were 5 Sherman´s in need to destroy one Panther for example, but in this Case Quantity won against Quality..
XT600K ´93 89.000km
XT660Z ´09 33.333km
Old 02-02-2011, 10:50 AM   #67
No False Enthusiasm
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 5,002
Originally quoted by Brummbar:
...but in this Case Quantity won against Quality...
For ten points, which Russian general said, "Quantity has a quality of its own."?
We're experiencing rolling blackouts, evidently throughout Texas. Can't participate in the discussion very well but try to follow.
Extremely heavy armored vehicles become limited by bridge limitations and other real world issues. Our M1 can have problems due to weight of 67 tons compared to the M60 A1 at 53 tons.
Good point made regarding turretless tanks and engagements of moving targets. Unless the opponent is traveling directly toward the turretless tank (or directly away) the gun is unable to traverse enough to lead the moving target.
No False Enthusiasm is offline   Reply With Quote
Old 02-02-2011, 10:50 AM   #68
Aurelius OP
Aurelius's Avatar
Oddometer: 22,783
The problem with relying on a simple formula of heavy armor and big guns is that the resulting design is only suitable for long distance confrontations on vast open terrain. In urban battlefields or forests, which required speed and maneuverability, these giant tanks were completely out of their element.
Old 02-02-2011, 10:54 AM   #69
Aurelius OP
Aurelius's Avatar
Oddometer: 22,783
Old 02-02-2011, 10:56 AM   #70
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,548
Originally Posted by steelbreeze68w View Post
For some reason that reminded me of something an instructor told us during trainup for route clearance: "In the neverending race between warhead and armor, the warhead always eventually wins." It was meant as a caution against assuming our armor was invulnerable. Seven IED hits later I will be eternally grateful that race wasn't concluded against the armor around me.
On a somewhat related tangent- does anyone know the etymology of the term tank? I was told what i have always assumed was an urban legend regarding the origin of the term as it relates to armor having to do with mislabeled cargo. Details are a bit hazy.
My urban legend says that the mislabeling was on purpose.
Uncle Pollo is offline   Reply With Quote
Old 02-02-2011, 11:04 AM   #71
No False Enthusiasm
a quiet adventurer
Oddometer: 5,002
T-28...
Can you imagine the effort required to change a broken end connector on the inside of the double track?
Just routine tightening of the wedges would take a long time. And it would be dangerous to have crew members working to advance the end connector to the correct position and check eight end connectors at once.
A simple failure would take the vehicle out of action for an extended period of time.
Old 02-02-2011, 11:30 AM   #72
Brummbär
Pathfinder
Brummbär's Avatar
Oddometer: 142
T-28...
Yes. And, as Aurelius and you said: more Quantity and those Giants were completely useless. That´s the reason why smaller ones were often more effective than these Monsters. On the other Hand, when the small tanks needs to hit you three or four times the Giant needs only one hit to smash the target. Butthe constant supplies are the next problem, and this is were the small hunter is in advantage, turret or not...
XT600K ´93 89.000km
XT660Z ´09 33.333km
Old 02-02-2011, 11:49 AM   #73
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,366
The autobiography "Tigers In The Mud" by panzer commander Otto Carius mentions the later King Tigers did not have a turret but had to be aimed by steering the tracks which apparently caused a lot of transmission failures.
Good book BTW, I recommend it.
GreaseMonkey is offline   Reply With Quote
Old 02-02-2011, 11:58 AM   #74
Aurelius OP
Aurelius's Avatar
Oddometer: 22,783
It's not just a matter of quantity. In close quarter combat, it's not necessary to penetrate the tank's thick frontal armor to destroy it. The modest 75mm cannon of the Shermans was more than capable of destroying the tracks and penetrating the lighter armor surrounding the Panzer's engine at close range. Once a tank is unable to move, it quickly falls victim to any number of methods of attack.
Old 02-02-2011, 12:26 PM   #75
RandyB
Oddometer: 5,072
If you can peel the supporting Infantry away from them.... The Panzerschreck, IIRC, (88mm bazooka) was nothing to fool with.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:49 AM.
