Old 02-02-2011, 07:25 PM   #1
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
950 Supermoto Turbo Build Thread
Hey All. I decided to go nuts and turbo my 950 Supermoto. Some folks, even as far away as France, have asked for info on the build so here we go. This is the virgin prior to defiling.
Current Stable : 950SM Turbo! GSXR1000 RT-P1100 VFR800 RXC620 motard EXC520 CR500AF CRF450R Plated! CR250
Past stable : 90 +
Tommy_J is offline   Reply With Quote
Old 02-02-2011, 08:09 PM   #2
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Step one : Decide on objectives
I have in mind a low boost installation. Say under 6 psi. A couple of things are really important to me. One is that boost start early and enhance the already excellent midrange. Peak power does not need to be huge but if the turbo machinery can be sized for 150 hp with good midrange so much the better.
The bike should be quiet. This is important to me as I like to travel with the front tire Ĺ inch off the ground whenever possible and being quiet make it possible more. Turbos make nice mufflers but additional muffling will be needed for the level of stealth Iím after.
To make things interesting Iím shooting for a net weight reduction and significantly improved off road ability
Past stable : 90 +
Old 02-02-2011, 08:37 PM   #3
andyhol
volcano rider
andyhol's Avatar
Oddometer: 153
standard 950 supermoto not enough?
increase off-road ability and add a turbo?
too awesome and really fucking crazy, good luck
current rides: tiger 200 and cb200 scrambler in indo
90 yamaha xtz750 super tenere, 98 honda vtr 1000 firestorm in the uk
andyhol is offline   Reply With Quote
Old 02-02-2011, 09:33 PM   #4
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Step Two : Select Turbo
Looks like a clone of a Borg Warner K03 will do fine. This trim should be good for 180 HP at a pressure ratio of 1.63, or 9.26 psi boost. Not that I’ll ever run it that hard. Peak boost is achieved at 4200 RPM.
There’s a lot of talk about how great ball bearing turbos are but I have no desire to spend $700. Final decision was for a Chinese journal bearing turbocharger. K03 turbos are used on untold thousands of VW Golfs and Beetles and there are a lot of these Chinese clones running around as replacements. I goggled around to see if anyone had bad experiences with them and came up empty. Sure, the quality is more spotty than the real thing but this sucker only cost $190. If it goes bad I’ll replace it for less than a change of tires.
Here's the efficiency map
Past stable : 90 +
Tommy_J screwed with this post 02-03-2011 at 05:18 PM
Old 02-02-2011, 11:16 PM   #5
duxrneet
duxrneet's Avatar
Oddometer: 671
Subscribed
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 02-02-2011, 11:23 PM   #6
OaklandStrom
Oddometer: 1,612
Holy crap.
Subscribed!
OaklandStrom is offline   Reply With Quote
Old 02-03-2011, 05:28 PM   #7
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Step Three : Mounting Arrangement
The usual approach is to put the turbo in front of the motor, down low. A novel thing I want to try is to package the turbo where the right muffler was. This gives cleaner routing for the exhaust. Its all flowing backward. The air cleaner position makes more sense up high. Oil can probably drain from the turbo by gravity without need for an expensive and fragile scavenge pump.
Past stable : 90 +
Old 02-03-2011, 05:39 PM   #8
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
I wish I could post more than one pic at a time.
Hereís another view with a temporary bracket and bailing wire holding the turbo. Iím trying to get it positioned in tight and keep the turbo within 18 degrees of level. Thatís so oil wonít leak past the compressor seal and make embarrassing smoke.
Past stable : 90 +
Tommy_J screwed with this post 03-06-2011 at 12:57 PM
Old 02-03-2011, 07:33 PM   #9
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,399
Subscribed!
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 02-03-2011, 07:45 PM   #10
1200B
Ride everywhere...
1200B's Avatar
Oddometer: 282
Photo Site:
http://JustinStG.com
1200B is offline   Reply With Quote
Old 02-03-2011, 07:48 PM   #11
awork13
Gas was made to burn
Oddometer: 313
Are you making a pressure box for the carbs?
2012 Honda CB1000R
2013 Victory Cross Country
2003 Honda CR125
2009 CRF150R
awork13 is offline   Reply With Quote
Old 02-03-2011, 08:27 PM   #12
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,705
Good thinking! I'm in.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 02-03-2011, 10:11 PM   #13
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
That's the plan
Past stable : 90 +
Old 02-04-2011, 01:37 PM   #14
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
Saw your comment on the 990SM Turbo thread and had to join here.
I wondered when the convenience of the SM exhaust header outlet would be exploited with a whistle. The routing for pressure to plenum could all be contained within the bodywork, under the seat, with room left on the other side to pipe the exhaust outlet through a short can. Stealthy indeed.
Plus, with a rear mount, there's no messing with the oilbag or its plumbing.
Nice use of a Chirbo, too. My kind of budget.
along for the ride
snowhawk jockey is offline   Reply With Quote
Old 02-04-2011, 03:58 PM   #15
cnw126
Oddometer: 107
Seriously interested in this! I wish you the best of luck.
cnw126 is offline   Reply With Quote
Times are GMT -7.   It's 10:14 AM.
