Old 02-05-2011, 11:54 AM   #31
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,162
For pictures I use a Facebook account just for pictures. No personal info or anything.
Chillis is offline   Reply With Quote
Old 02-05-2011, 01:23 PM   #32
OaklandStrom
Oddometer: 1,612
Originally Posted by Tommy_J View Post
Anybody know the secret to uploading more than one pic at a time?
If you are uploading from your computer, the limit is one at a time.
If the hosting is done elsewhere (Smugmug, Flickr, Facebook...) you can attach multiple pix to a post.
OaklandStrom is offline   Reply With Quote
Old 02-05-2011, 07:01 PM   #33
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Thanks for the advice on posting pics. The exhaust housing has been machined to make ears the muffler can bolt to. While I was at it I machined some excess metal out of the housing. Then the entire housing was sanded with a flapper wheel until smooth. This way it will look good if I ceramic coat it.
Current Stable : 950SM Turbo! GSXR1000 RT-P1100 VFR800 RXC620 motard EXC520 CR500AF CRF450R Plated! CR250
Past stable : 90 +
Tommy_J is offline   Reply With Quote
Old 02-05-2011, 07:12 PM   #34
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,126
Well now, just get right started, why don't ya!
Dig the one piece mount, muffler and masking.
The muffler profile is so "stock" looking, just paint it flat black when you are done to compete the appearance. Might want some extra heat reflector on the side panel to keep it from melting, its gonna get a bit hot under there.
Probably want a shield where turbine body protrudes too, otherwise you will get the classic KTM dirtbike pants/boot burn.
Thinking of moving heat, would ceramic coating the inners of your muffler box and core help lower temps around/outside the box?
snowhawk jockey is offline   Reply With Quote
Old 02-05-2011, 07:27 PM   #35
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Snow, Your right, some thought and effort will have to go into heat management!
The part of the "muffler" that goes over the turbo will probably become part of a heat shield.
Past stable : 90 +
Old 02-06-2011, 07:17 AM   #36
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Alright lets see if I can upload images from a host.
Here is a series showing development of that muffler bracket. It was laid out on poster board, test fit, re-laid out, re-tested, modified some, transferred to steel, band sawed out, folded, and tack welded in place. A pleasant 20 minute job.
Past stable : 90 +
Tommy_J screwed with this post 02-22-2011 at 04:53 PM
Old 02-06-2011, 07:45 AM   #37
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
The length of the muffler was trimmed down, front and back. It got a serious slash cut. Maybe longer would have looked better but the turn signal was in the way. I considered making a new tail tidy type thing to move the turn signals, but that's the sort of scope creep that would set the project back a week.
Just to state the obvious, this is a mock up. Its not done by any means.
Past stable : 90 +
Old 02-06-2011, 07:51 AM   #38
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
The metal cut off the turbo end of the muffler will be saved to make a heat shield latter. Hence the notch around the wastegate arm.
Past stable : 90 +
Old 02-06-2011, 10:51 AM   #39
cpallen
Nearly Adventurer
cpallen's Avatar
Oddometer: 1,009
Suggestion
Put each image link on it's own line, and you can insert your descriptive text in between eg:
[IMG link # 1]
yada yada yada
[IMG Link #2]
more description
[IMG Link #3]
etc
Courtney in Seattle
'13 BMW F800GT, '07 G650X Challenge '13 C650GT Scooter
cpallen is offline   Reply With Quote
Old 02-06-2011, 11:22 AM   #40
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
CP, will do. This is my first build thread - ever. I'm learning as I go.
Past stable : 90 +
Old 02-06-2011, 11:51 AM   #41
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
As a guide on how to design a muffler I dug up these pics. When this SM was two days old I cut the muffler open and "de-catted". The results were very satisfactory, but as I said before I like my bikes quiet.
While the mufflers were cut open the baffle design was visible. It's hard to see, but there are three baffle tubes separating the muffler into two chambers. After that the exhaust flows out one tail pipe. BTW, that thing on the right is the catalyst. I was surprised how small it was.
My objective is to package a similar design into this space.
Past stable : 90 +
Old 02-06-2011, 12:00 PM   #42
cpallen
Nearly Adventurer
cpallen's Avatar
Oddometer: 1,009
And you are doing a great job! I'm riveted and don't even like KTMs.
You are obviously a brilliant craftsman.
Courtney in Seattle
Old 02-06-2011, 12:38 PM   #43
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
The only thin wall pipe of the right diameter I could scrounge up easily was fencing material. Its very low strength alloy. That's fine though because it easier to form bell mouths on the the baffle tubes.
Here the pipe is being rolled around breaker bar handle.
Past stable : 90 +
Old 02-06-2011, 01:57 PM   #44
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
BTW, this was the plan for the first tube in the muffler. It has a taper the fits tight against the turbine housing and that's what really locates the muffler. That reduces stress on the three little ears which just snug the muffler against the turbo.
Past stable : 90 +
Old 02-06-2011, 04:10 PM   #45
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,126
I sure would like to sponsor the materials for a second get'up mount and tubing, since yer just slappin' it together so quick. Of course, I would have to save up extra to buy the matching whistle, but I could manage. Then I would just have offer to mount it on my bike, you know, fer the sake of enjoy'in it.
Wadda'ya say, shall I start flooding your paypal account with $1 biils?
All right I'll stop bother'in ya with nonsense and let you get the real work done.
Times are GMT -7.   It's 04:52 AM.
