Old 02-15-2011, 08:27 PM   #91
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Here is an attempt at a bracket to support the tube near the turbo. It's a really 3D part. The tube slopes up and out and has a bend there.
The idea is to support the turbo by the stock KTM exhaust mount up front and by the KTM muffler mount in back. A decision on if this bracket can be used will come after the tubing is welded up more.
Current Stable : 950SM Turbo! GSXR1000 RT-P1100 VFR800 RXC620 motard EXC520 CR500AF CRF450R Plated! CR250
Past stable : 90 +
Tommy_J is offline   Reply With Quote
Old 02-16-2011, 06:06 AM   #92
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
Very nice work. The brackets and joints look OEM...
Are you gonna ceramic coat it all when it's done?
The turbo is a long way from the exhaust ports, where efficiency is concerned. A major source of energy for the turbo will be exhaust heat, in addition to flow. The ceramic coating will help to contain the exhaust heat to help aid turbo spoolup. There is a hotter version of ceramic coatings called turbo-kote. It's black, and can even be used on turbine housings and wategates, inside and out.
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 02-16-2011, 07:20 AM   #93
LeChatNoir
artiste
Oddometer: 145
Swoon! What work! Any interest in a DRZ-SM experiment? I can come over... it is carbed though maybe. A megasquirt setup as well
I am subscribing to this thread.
LeChatNoir is offline   Reply With Quote
Old 02-16-2011, 07:59 AM   #94
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
One of my other lurking zones is Supermoto Junkie and member unclebob did a thread for his DRZ-SM turbo build:
http://www.supermotojunkie.com/showt...light=unclebob
Here is Turbo 2.0 of unclebob's project:
http://www.thumpertalk.com/forum/arc...t-683446.html&
Tommy, the slip fit joints are very streamline. I wondered how those made a seal, thanks for the explanation.
snowhawk jockey screwed with this post 02-16-2011 at 11:23 AM
snowhawk jockey is offline   Reply With Quote
Old 02-16-2011, 01:25 PM   #95
Keith
Slabbing it
Keith's Avatar
Oddometer: 918
Cooooooool
Random Crap
Keith is offline   Reply With Quote
Old 02-16-2011, 07:37 PM   #96
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
I probably won't go the ceramic coating route, at least not at first. Its hard to do repair/rework with that coating, and it'll probably cost as much as the turbo did. Anyway, I have a couple of special tricks in mind to avoid turbo lag and I hope to get to work on them soon.
Past stable : 90 +
Old 02-16-2011, 07:46 PM   #97
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
I remember reading every post in Uncle Bob's first thread back in 2006. Honestly, it was probably his project more than anything else that got me spun up to do this one. I'm not sure his project was a 100% success so I can't wait to read the redux thread.
Uncle Bob, if you ever read this I dedicate this thread to you!
Past stable : 90 +
Old 02-16-2011, 08:08 PM   #98
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Exhaust pipe clearance to the tire should work out OK. There was insufficient clearance with the mud guard so it needed a little trim on one side. During removal a bolt snapped. Are KTM fasteners made out of cheese? Repaired with a larger fastener.
Past stable : 90 +
Old 02-17-2011, 07:05 AM   #99
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Installed
Past stable : 90 +
Old 02-17-2011, 08:48 PM   #100
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Some more welding was accomplished and a heat shield added. Its actually more camouflage/styling than heat shield. As I said before, I wanted to build a sleeper.
Past stable : 90 +
Old 02-17-2011, 11:30 PM   #101
duxrneet
duxrneet's Avatar
Oddometer: 671
I dunno how a modified orange motorcycle qualifies as a sleeper, but I don't care
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 02-18-2011, 04:24 AM   #102
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,536
Didn't look like much trimming on the rear fender/mudflap, think there will be any clearance issues when the suspension compresses?
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 02-18-2011, 02:14 PM   #103
NONo443
NONo443's Avatar
Oddometer: 158
I have a question (and probably a stupid one), but have you thought about using an exhaust flex joint where your slip joint is located now? Any problems with doing that?
NONo443 is offline   Reply With Quote
Old 02-18-2011, 05:29 PM   #104
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Clearance is ample now. That brake line is another matter though.
Past stable : 90 +
Old 02-18-2011, 05:48 PM   #105
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
That would work, but its hard to think of any great advantage to it.
A flex joint would not have fit were the slip joint was, plus it costs money.
Past stable : 90 +
Times are GMT -7.   It's 10:53 AM.
