Old 02-06-2012, 09:56 AM   #1486
Deans BMW
Granpa Hoon
Oddometer: 2,625
Originally Posted by JimVonBaden View Post
I don't get it???
How many R1100/1150/1200 bikes actually require any sort of major engine work, let alone rebuilding/reboring? IMHO it is a non-issue.
Jim
Absolutely.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 02-06-2012, 10:07 AM   #1487
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 29,130
Originally Posted by ragtoplvr View Post
When the crank is 90 degrees from TDC there will be pretty good access to the rod nuts. Non-issue. If you take care of the bike, I would expect well over 200 K. Hopefully the cam chain guides can be replaced without major disassembly, that to me would be a bigger issue, they can and do fail sooner than the cylinders wear out.
I would count on there being pretty good supply of low mileage engines from bikes that get totaled.
Rod
How do you get the piston out to access the rod?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-06-2012, 01:30 PM   #1488
Marki_GSA
Oddometer: 197
Take the sump/oil pan off.
Marki_GSA is online now   Reply With Quote
Old 02-06-2012, 02:29 PM   #1489
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Where are you "DasMatti"?
"DasMatti"
Undoubtedly we need some help getting this thread going again, how was your test ride?
tallguy-09 is offline   Reply With Quote
Old 02-06-2012, 05:46 PM   #1490
marchyman
Talks to cats
marchyman's Avatar
Oddometer: 5,298
I didn't think about that. Or, to be more accurate, I didn't think.
How often do you need access to the piston on a modern boxer? I'm aware of one where the piston disintegrated at 180K miles. The solution to that problem was a salvage engine that was only 25K miles old. Much cheaper than trying to fix the old engine.
What oil pan?
marchyman is offline   Reply With Quote
Old 02-06-2012, 05:58 PM   #1491
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 4,347
I seem to recall a number of posts regarding one cylinder vibrating and ultimately failing on the GS12. Often it was the right side. Hate to see some similar issue on this design.
I'll say it again-makes me wonder if what we're seeing isn't a running development engine being put through its paces for research.
I found Jesus. He was behind the sofa the whole time.
1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF"
hillbillypolack is offline   Reply With Quote
Old 02-06-2012, 07:23 PM   #1492
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Looks like a (or two) running motorcycle(s) to me and I'm thinking all will be good
First thing I'll remove: Rear Footpegs
tallguy-09 screwed with this post 02-06-2012 at 07:28 PM
Old 02-06-2012, 09:45 PM   #1493
rdcyclist
rdcyclist's Avatar
Oddometer: 1,037
In the case of the integral case/cylinders, you split the cases and the crank "falls out". Similar to rebuilding a Japanese four, the bottom case is split from the top and the rod bigends are exposed for disassembly.
The truth of the matter is, almost nobody rebuilds motorcycle engines anymore. There are plenty of wrecking yard engines available with low miles and in the case of a worn out engine, the rest of the bike is usually done by then anyway. How much is a ten year old bike with 250k worth?
rdcyclist is offline   Reply With Quote
Old 02-06-2012, 10:00 PM   #1494
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,582
Send a message via Yahoo to Ricardo Kuhn
You are right about everything, my fear will be with the "Chain tensioner" plastic guides that tend to disintegrate from time to time.
Ps: If the new engine does not have the pesky plastic tensioner sliders, me bad and more power to them
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Old 02-06-2012, 10:06 PM   #1495
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 29,130
It was a rhetorical question raised for the purpose of intellectual exercise.
Old 02-07-2012, 07:58 AM   #1496
rdcyclist
rdcyclist's Avatar
Oddometer: 1,037
Lord knows I need the exercise...
Old 02-07-2012, 11:10 AM   #1497
Marki_GSA
Oddometer: 197
What oil pan?
There has to be some access otherwise you wouldn't be a able to build the engine in the first place. Of course they could be 3D printing them. ;)
Old 02-07-2012, 12:10 PM   #1498
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Don't bring logic into this!
Seriously, they simply compress the rings as they assemble the block halves!
Jim
Old 02-07-2012, 02:53 PM   #1499
Beemerlover
Oddometer: 270
Probably off-subject, but do those guys in the pics REALLY need those knee sliders with boxes mounted on those bikes?
Beemerlover is offline   Reply With Quote
Old 02-07-2012, 02:54 PM   #1500
Beemerlover
Oddometer: 270
Jim
Just like assembling a Goldwing engine, right Jim?
Times are GMT -7.   It's 10:35 AM.
