Old 03-27-2011, 02:00 PM   #196
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 184
Originally Posted by K u r t View Post
Pardon me, but is there confirmation this new engine is 1300 cc? Where did that figure come from?
Here it reads as follows:
  • 75 stroke x 100 bore => 1178 cm³
  • 75 x 102 => 1225
  • 78 x 102 => 1274
"Confirmation"? You really ask for "confirmation" - by whom? BMW?
The difference between theory and practice practically is larger than the difference between theory and practice theoretically.
BMW Airhead -> www.zeebulon.de/bmw
BMW R1100GS -> www.zeebulon.de/R1100GS
XT 500 -> www.zeebulon.de/xt
Basic_Gerd is offline   Reply With Quote
Old 03-27-2011, 02:13 PM   #197
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 184
Originally Posted by Emoto View Post
So the cylinders are part of the engine crankcase. OK. Can you imagine how the pistons are installed...? When & where shall the piston pins be pushed in...?
Overhauling... ? You think that clutch changing is a MCA? You ain't seen nothing yet.
Well, since the Nikasil days way back in the airhead mesozoicum, the excessive wear of pistons / cylinders (meaning regular boring and oversized pistons) is more or less over. But think of all the tuning shops selling their "fablulous super hi-pro performance big-bang pistons" ... better think of something new, guys. Betta getta EPROM burner. Machining? Forget it - learn C#...
Old 03-27-2011, 02:30 PM   #198
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,582
Send a message via Yahoo to Ricardo Kuhn
Yeah how do they do it....
I was wondering about that too, Do they install them when the cases are "Split", Man what a pain in the butt, Even more if you ever need to work on them and/or replace anything even a job as simple as the rings.
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn screwed with this post 03-27-2011 at 02:43 PM
Ricardo Kuhn is offline   Reply With Quote
Old 03-27-2011, 02:34 PM   #199
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,139
So the cylinders are part of the engine crankcase. ...
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 03-27-2011, 02:49 PM   #200
Ricardo Kuhn
Oddometer: 11,582
Then again the target audience for this bike, Will not keep the bike for more than a few years (even A Year like you sadly see around here all the time) so is a None Issue at least for them....
Disposable Engines My ASs
Old 03-27-2011, 02:54 PM   #201
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,139
You could be right, Ricardo. And, from an engineering standpoint, I suppose that not having to keep seals tight at joints between cylinders and blocks, is a plus for the idea, but who the hell wants to pull the motor and split the cases to re-ring or put in a new piston.
Old 03-27-2011, 03:00 PM   #202
i_isntreal
Oddometer: 67
They probably have a removable oil pan. Kind of like a V8 where you have to put the piston on the connecting rod and drop it into the jug. Only it would be a bit more of a headache to get the top connecting rod bolt on/off. Nothing impossible, just a headache, and another specialty tool for the stealerships to sell.
For every mile of road there are two miles of ditches.
i_isntreal is offline   Reply With Quote
Old 03-27-2011, 03:05 PM   #203
supershaft
because I can
Oddometer: 6,070
I'm still stuck on the water cooling. If a boxer twin isn't air cooled, there is no need to run one. So many engine layouts can do everything better IMO, except for air cooling.
Old 03-27-2011, 03:15 PM   #204
OConnor
Bad juju
OConnor's Avatar
Oddometer: 2,604
The cylinders are like really expensive frame savers.
2008 GSX1250S
2006 Ducati S2R1000
1974 Honda CB125
2000 Suzuki SV650 race bike
1971 CB175 vintage racer inabox
OConnor is offline   Reply With Quote
Old 03-27-2011, 03:30 PM   #205
gelandestrasse
Fidem Scit
gelandestrasse's Avatar
Oddometer: 20,237
You can get the frame saver saver. And since that's kind of expensive to replace if it gets scuffed there's the frame saver saver saver that protects the frame sever saver which is necessary to protect the frame saver.
"The trouble with quotes on the Internet is that you can never know if they are genuine."
- Abraham Lincoln
gelandestrasse is offline   Reply With Quote
Old 03-27-2011, 03:37 PM   #206
Ricardo Kuhn
Oddometer: 11,582
You are so Right, Really good point, The Boxer's Make sense if you need to keep the heads cool down by the air (well Oildheads kind of do it too)
But the extra width is kind of waste if the engine is cooled by water
Old 03-27-2011, 03:56 PM   #207
Knee Dragger
Knee Dragger's Avatar
Oddometer: 88
Well , BMW might just be working on how to put a modern twin in a modern Isetta . http://www.bmw-tech.org/wiki/Isetta On the bottom it talks about a 2010 . Just a thought ,
Knee Dragger is offline   Reply With Quote
Old 03-27-2011, 04:00 PM   #208
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,491
The full bike pick is a terrible photoshop of a mix of 1150GSA, R1200R and doG only knows what.
As for the motor, I highly doubt that is anything like any possible very future Water Boxer.
Jim
Old 03-27-2011, 04:13 PM   #209
Ricardo Kuhn
Oddometer: 11,582
Jim
Jim what makes you say that...
Old 03-27-2011, 06:55 PM   #210
kvr929rr
kvr929rr's Avatar
Oddometer: 165
You can't really tell if the cylinders are integral with the block from that picture. Having the cylinder not attached to the block is not an impediment to water cooling either. The CBR1000RR has separate crankcase and cylinder blocks. Having the cylinders stick out with a longitudnal crankshaft does have other advantages over other layouts such as packaging & handling
kvr929rr is offline   Reply With Quote
Times are GMT -7.   It's 10:14 AM.
