Old 09-09-2012, 12:33 PM   #2191
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,856
Originally Posted by Loutre View Post
I prefer your mission. Can I switch commanders?
Mutiny carries with it severe penalty...be careful.
def is offline   Reply With Quote
Old 09-09-2012, 12:35 PM   #2192
def
def's Avatar
Oddometer: 10,856
Originally Posted by rdcyclist View Post
I'm shocked, I tell you, shocked. Is that why they use more cylinders on those engines? Maybe we should be after BMW to make a six cylinder GS?
Yes, there is rocking couple in the Boxer twin. That's a different component of engine balance from harmonics. For a given power, displacement and cylinder count, the boxer motor is going to have less vibration than an inline or V configuration. I know this: All of my GS's have been smoother than my 4 cylinder FJR at cruising velocity. I sold the FJR because: The only thing the FJR did better than the GS was go 150mph...
One already exists...it called the Goldwing and it's water cooled.
Old 09-09-2012, 12:50 PM   #2193
def
def's Avatar
Oddometer: 10,856
Originally Posted by ytsiwt View Post
2 cylinder boxers aren't that smooth.
Obviously the balance on the BMW boxer isn't that good or there would have been no need for BMW to add that single balance shaft to the 1200 hexhead or camhead.
The balance on the 6 cylinder boxer is excellent with some of the pistons always in motion and very little rocking couple.
The balance on the 4 cylinder boxer is OK but now some rocking couple enters and more 2nd order as there are points where all the pistons stop completely at the same time.
The balance on the 360 2 cylinder boxers leave a lot to be desired, especially on large cylinder configurations, as the pistons are not directly across from each other due to being on different crank throws with an offset between rod centers. 2 cylinder 360 boxers also have both pistons completely stop and change direction twice per revolution. Lots of higher RPM buzz and rocking couple excitement.
The C/G on the BMW 2 cylinder boxer isn't all that great either as it has a deep wet sump so the crankshaft is high in the crankcase. The crank must also be high to keep the cylinder heads from dragging the ground in turns. That heavy alternator is also way up high way off the engine roll center. The transmission input shaft is high with the counter shaft not much lower.
Correctomundo.
Remember, as RPM changes, the pistons weight influence changes. Also, as the connecting rods reciprocate, a portion of their mass is able to be offset with crankshaft counter weight. But then, the connecting rod mass changes as its reciprocating mass becomes rotation mass....multicylinder engines can be made much smoother and their crankshafts can be made smaller and these engine can rev higher with fewer forces trying to tear them apart.
Take a look at a 4 row radial P&W or Wright aircraft engine sometime if you want to study the dynamics of force and mass in a piston engine.
An electric motor or a turbine is best. There are no reciprocating parts meaning balance is not a problem.
Old 09-09-2012, 01:19 PM   #2194
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
And of course legend has it that BMW had a water cooled four banging boxer on the drawing board when they got wind that Honda would have the Goldwing engine on the market first. BMW didn't want to be accused of copying Honda, so they started over. Thus the Flying Brick came to be.
PirateJohn is offline   Reply With Quote
Old 09-09-2012, 02:25 PM   #2195
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 992
Correctomundo.Take a look at a 4 row radial P&W or Wright aircraft engine sometime if you want to study the dynamics of force and mass in a piston engine.
Radials are things of beauty and the English sleeve valve radials were enormously complex.
Or, viewed slightly differently, balance is a big problem if a turbine wheel or rotor is not in balance, but I digress.
I add nothing to the conversation, but I was moved to speak. Hmm. My new sig line. It's fitting.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 09-09-2012, 03:14 PM   #2196
ytsiwt
Oddometer: 5
Correctomundo.
Connecting rod mass can't change unless someone enters the engine and welds on it or grinds on it. Mass is mass sitting still or rotating.
You have anything data wise to show how the mass is changing?
I have looked at radial aircraft engines. Those sure aren't
comparable to a boxer twin. Seems to me those don't have a 360 firing order or 360 crankshaft but instead use a master rod with a single crankshaft pin.
ytsiwt is offline   Reply With Quote
Old 09-11-2012, 12:13 AM   #2197
KMC1
There is no spoon.
Oddometer: 2,561
Originally Posted by Parigi View Post
They had this R80 G/S sketch a while ago on Motorrad website, this would be really sweet.
I would be all over this.
Make it about 100lbs lighter than a 1200, air cooled, with a strong subframe.
Instant success.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 09-11-2012, 12:19 AM   #2198
kiwiAdventure
kiwiAdventure's Avatar
Oddometer: 1,409
Instant success.
Sweet looking bike. I do regret selling my HP2 I'm just hoping their will be another in time.
BMW 1200gs 16
BMW 450 enduro 09
kiwiAdventure is offline   Reply With Quote
Old 09-11-2012, 02:41 AM   #2199
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,820
Instant success.
Yeah me too and give it a catchy headlight like the other GS's
Loutre is offline   Reply With Quote
Old 09-11-2012, 08:41 AM   #2200
Parigi
Hoinar
Parigi's Avatar
Oddometer: 286
Oh, and no mambo-jambo one side paralever please. Even better, they should hire this S-Kraft guy, as his sketches always make more sense than BMW's. Sorry BMW.
Rant off.
Parigi is offline   Reply With Quote
Old 09-11-2012, 08:55 AM   #2201
Pongo
Oddometer: 318
Hope they fix the seat.
Pongo is offline   Reply With Quote
Old 09-11-2012, 08:57 AM   #2202
KMC1
There is no spoon.
Oddometer: 2,561
This actually kept me awake for a while last night... serious....
Picture having about 65 HP with a nice fat torque curve, nice and light (365lbs or so) with the utility of a 1200, scaled down......simple design, easy Maintainence, lots of ground clearance,,,,strong subframe.....oh Man....
This would be the bike I would take to Central and South America.....
Old 09-11-2012, 08:59 AM   #2203
KMC1
There is no spoon.
Oddometer: 2,561
Lol! I like that seat....great for offroad work.... I hope they would put a real fender on the front tire though....
Old 09-11-2012, 02:39 PM   #2204
g_e_young
g_e_young's Avatar
Oddometer: 867
in 26 days we'll meet :o)
Holy shit, I think Batman is driving the new GS. Damn. g-
IBA# 15974
www.whatsmyco2.com
g_e_young is offline   Reply With Quote
Old 09-11-2012, 04:15 PM   #2205
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,820
and Bane rides the F800GS: http://vimeo.com/46587712
Times are GMT -7.   It's 10:04 PM.
