Old 10-02-2012, 03:16 AM   #2356
luca9277
luca9277's Avatar
Oddometer: 251
2013 r1200gs
beautiful....
http://www.moto.it/news/intermot-2012-boxer-futuro.html
luca9277 is offline   Reply With Quote
Old 10-02-2012, 03:20 AM   #2357
Moronic
Moronic's Avatar
Oddometer: 1,671
Originally Posted by Dorsicano View Post
fuel tank is 20 litres, of which 4 litres reserve.
Really? Damn! Hoped they'd give us 24 and match the new KTM.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 10-02-2012, 03:21 AM   #2358
Dorsicano OP
Oddometer: 88
Engine
Type Air/liquid-cooled four stroke flat twin engine, double overhead camshaft, one balance shaft
Bore x stroke 101 mm x 73 mm
Capacity 1,170 cc
Rated output 92 kW (125 hp) at 7,750 rpm
Max. torque 125 Nm at 6,500 rpm
Compression ratio 12.5 : 1
Mixture control / engine management Electronic intake pipe injection / BMS-K+ digital engine management with electromotive throttle actuator
Emission control Closed-loop 3-way catalytic converter, emission standard EU-3
Performance / fuel consumption
Maximum speed over 200 km/h
Fuel consumption per 100 km at constant 90 km/h 4,1 l
Fuel consumption per 100 km at constant 120 km/h 5,5 l
Fuel type Unleaded super, octane number 95 (RON)
Electrical system
Alternator three-phase alternator 580 W (nominal power)
Battery 12 V / 11,8 Ah, maintenance-free
Power transmission
Clutch oil lubricated clutch, hydraulically operated
Gearbox Constant mesh 6-speed gearbox with helical gear teeth
Drive Shaft drive
Chassis / brakes
Frame Two-section frame, front- and bolted on rear frame, load-bearing engine
Front wheel location / suspension BMW Motorrad Telelever; stanchion diameter 37 mm, central spring strut
Rear wheel location / suspension Cast aluminium single-sided swing arm with BMW Motorrad Paralever; WAD strut (travel-related damping), spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable at handwheel
Suspension travel front / rear 190 mm / 200 mm
Wheelbase 1.507 mm
Castor 99.6 mm
Steering head angle 64.5°
Wheels Cast aluminium wheels
Rim, front 3,00 x 19"
Rim, rear 4,50 x 17"
Tyres, front 120/70 R 19
Tyres, rear 170/60 R 17
Brake, front Dual disc brake, floating brake discs, diameter 305 mm, 4-piston radial calipers
Brake, rear Single disc brake, diameter 276 mm, double-piston floating caliper
ABS BMW Motorrad Integral ABS (part-integral), can be switched off
Dimensions / weights
Length 2.210 mm
Width (incl. mirrors) 953 mm
Height (excl. mirrors) 1.450 mm
Seat height, unladen weight 850 / 870 mm (low seat* 820 / 840 mm, lowered suspension* 790 / 810 mm) *OE
Inner leg curve, unladen weight 1870 / 1910 mm (low seat* 1820/1860 mm, lowered suspension* 1770 / 1810 mm) *OE
Unladen weight, road ready, fully fuelled 1) 238 kg
Dry weight
Permitted total weight 450 kg
Payload (with standard equipment) 212 kg
Usable tank volume 20 l
Reserve approx. 4 l
Technical data relate to the unladen weight (DIN)
1) According to Directive 93/93/EEC with all fluids, fuelled to at least 90% of usable fuel tank
Dorsicano is offline   Reply With Quote
Old 10-02-2012, 03:22 AM   #2359
Dorsicano OP
Oddometer: 88
I too will wait for the Adventure
Old 10-02-2012, 03:24 AM   #2360
Dorsicano OP
Oddometer: 88
official video
you'll have to agree, those BMW marketing geeks are the best
http://www.youtube.com/watch?feature...&v=w147KctYONg
Old 10-02-2012, 03:30 AM   #2361
Moronic
Moronic's Avatar
Oddometer: 1,671
The new bike is live on BMW's International website, which is struggling ...
Dorsicano, thanks for posting the specs.
Old 10-02-2012, 03:38 AM   #2362
Stub deToe
Stub deToe
Stub deToe's Avatar
Oddometer: 165
Just chatted with Chris Pfeiffer at the show, he has been riding it a fair bit, the best feature he says is the narrowness of the bike and the TBs being moved on top out of the way gives lots of room for the legs to move around. Moving the shaft to the left side has also eliminated any residual driveline pull to one side for some reason. LED lights are an option. Weighs about the same as the current GS.
The less you know about motorcycles... the more you'll like Harleys!
'13 1200GS LC
'74 R90S x2
'74 R75/6 since new
Stub deToe is offline   Reply With Quote
Old 10-02-2012, 03:53 AM   #2363
LillaMan
n00b is okay by me.
LillaMan's Avatar
Oddometer: 36
And the new bike...
Don't fear your ignorance - live it, embrace it, write about it.
An American copywriter in Sweden
LillaMan is offline   Reply With Quote
Old 10-02-2012, 04:22 AM   #2364
luca9277
luca9277's Avatar
Oddometer: 251
if the text comes up in italian select English on the top right hand side of the page... much nicer reading ;)
Old 10-02-2012, 04:30 AM   #2365
Stkmkt1
Stkmkt1's Avatar
Oddometer: 257
Here's a good question. Has the new GS been designed to run on ethanol-laced fuel. Since Germany is now beginning to endorced such foolishness, I would expect the Germans to build a bike that can handle at least 10% ratio.
2013 BMW 700GS, 2009 BMW 1200GS Adventure,
2009 Vstar 950, 2009 Honda Rebel,
2000 Goldwing SE, 1977 CB750A,
Needs: new garage (in planning) Need more room for more bikes.
Stkmkt1 is offline   Reply With Quote
Old 10-02-2012, 04:31 AM   #2366
Moronic
Moronic's Avatar
Oddometer: 1,671
The engine ...
Nice tech piece of the new engine design here at moto.it - Google translate does a good job.
Tidbits:
- the water cooling adds 2.7kg (about 6 lbs)
- it contributes only 35 per cent of the overall cooling (up from 22 per cent for the oil cooling)
- compression up half a point
- each cylinder cast with its vertically split crankcase half
- crankshaft is stiffer
- crankpins are closer together
- hence cylinders offset less
- vertical intake path facilitates equal-length intake ducts, which helps with throttle sync
- valve overlap is reduced, as Ducati has done on the Multistrada (cf the 1198), which should mean more low-rev grunt.
- intake and exhaust valves get their own camshafts (rather than half and half as before)
- which opens the way for variable valve timing on THE NEXT GS
(Thanks to inmate luca9277 for posting the link in another thread.)
Old 10-02-2012, 04:43 AM   #2367
Dirt Diver
Dirty Adventurer
Dirt Diver's Avatar
Oddometer: 1,060
The list of accesories is interesting
Here
12 R1200GS Triple Black - Fulfilling my every need!
09 F800GS - Sold
07 GSA Sold and missed.
01 VFR800 Sold and missed.
Adventurers like it dirty!
Dirt Diver is offline   Reply With Quote
Old 10-02-2012, 05:05 AM   #2368
shizzle
Oddometer: 12
Apparently no info on pricing yet, wonder how that will turn out. The Configurator still seems to be the old GS, if I'm not mistaken.
Looks quite decent imo.
shizzle is offline   Reply With Quote
Old 10-02-2012, 05:08 AM   #2369
Visian
Look out!
Visian's Avatar
Oddometer: 1,675
Got some pics going up now...
'67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
Visian screwed with this post 10-02-2012 at 05:15 AM
Visian is offline   Reply With Quote
Old 10-02-2012, 05:10 AM   #2370
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,580
Wish I hadn't read that......
No spoked wheels? Seems like an even more road oriented bike now with its target sight set on the Multi and/or Tiger.
So far I like what I see....wish it had Ohlins though
2014 Ducati MTS1200S | 2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Times are GMT -7.   It's 08:10 AM.
