Old 10-03-2012, 11:23 AM   #2671
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 1,553
Heat being dumped onto the riders legs?
So, with no little "wings" to redirect the air coming through the radiators, won't there be a bunch of hot air getting dumped right onto the rider's legs?
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad
Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-03-2012, 11:27 AM   #2672
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,389
Originally Posted by Dykkeren View Post
The top-case can be used (i think), but since the exhaust have changed side, the sideboxes not.
Hope so, but looks like the top case mounts directly on the factory rack now with no mounting plate, so I'm guessing the old case may not fit.
EJ_92606 is offline   Reply With Quote
Old 10-03-2012, 11:29 AM   #2673
Marki_GSA
Oddometer: 197
Originally Posted by grpweld View Post
Has anyone noticed if the 13 is a single plug head?
& how did they manage to get the overall engine width narrower?
Yes it's single plug, smaller crank and bearings but probably mostly down to there being less stuff under the valve covers.
Marki_GSA is online now   Reply With Quote
Old 10-03-2012, 11:30 AM   #2674
Sock Monkey
Corporate slave
Oddometer: 1,553
At-home valve adjusts????
Will this require draining the coolant? I can't tell from the pics (thanks for those RL! VERY helpful! ) if the coolant path passes into the valve cover or not.
-SM
aka NoVector
Old 10-03-2012, 11:30 AM   #2675
yellowbirdrs
yellowbirdrs's Avatar
Oddometer: 960
-SM
look closer where the air inlets are
yellowbirdrs is offline   Reply With Quote
Old 10-03-2012, 11:41 AM   #2676
ragtoplvr
Oddometer: 4,543
No coolant path in the valve covers, so draining will not be requir3ed to check adjust valves.
Bad thing is when water pump leaks, coolant goes in the oil.
Notice how one head is driven directly from crankshaft but the other is driven from the balance shaft. Less accurate cam timing on one cylinder than the other.
Over all, looks very good, but not perfect.
Rod
ragtoplvr is online now   Reply With Quote
Old 10-03-2012, 11:42 AM   #2677
RL Lemke
RL Lemke's Avatar
Oddometer: 1,417
-SM
Zoom in on this one. The head gasket retains the coolant. Valve adjustment is separate.
RL Lemke
Dallas, Texas
RL Lemke is offline   Reply With Quote
Old 10-03-2012, 11:49 AM   #2678
GSMarc
GSMarc's Avatar
Oddometer: 720
Originally Posted by EJ_92606 View Post
The BMW USA website shows a 9 pound (not kg) difference in wet weight between the waterhead and camhead...there was a previous post on this with the actual numbers.
BMW Motorrad Germany : Ready to ride
Leergewicht fahrfertig, vollgetankt 1) 238 kg
  • 1) Gemäß Richtlinie 93/93/EWG mit allen Betriebsmitteln, betankt mit mindest. 90% des nutzbaren Tankvolumens
R1200GS DOHC Ready to ride BMW Belgium
Poids à vide en ordre de marche, réservoir plein 1)229 kg
So, 9 kg = 19,84 lbs
I would prefer 9 lbs than 9 kg but.....
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
GSMarc is offline   Reply With Quote
Old 10-03-2012, 12:17 PM   #2679
Sock Monkey
Corporate slave
Oddometer: 1,553
Ah....OK. It's more obvious in this pic.
There's a piece of plastic behind the radiator that redirects the air to the sides vs. allowing it to come straight back.
-SM
aka NoVector
Old 10-03-2012, 12:26 PM   #2680
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,389
Per the BMW USA website comparing new GS to previous model (4kg difference = 9 pounds):
Old 10-03-2012, 12:31 PM   #2681
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,130
Originally Posted by Marki_GSA View Post
It works for me assuming the alternator is reliable. Looks like it is permenant magnet so no brushes to wear out. It will have a separate external diode pack so the only thing left to break are bearings if there are any and they could be oil fed from the box. Clutch on the other hand is a consumable part so will at some point need replaced which is a real pain on the current bike.
What I haven't seen anywhere is the starter motor. The only stuff I have seen mentioning it is the blurb about how the exhaust valves have auto decompressors making the engine easier to start so a smaller starter is needed. It will be there somewhere just I haven't spotted it.
Look at any shot of the right side of the bike. The starter motor is black and is easily seen just aft and below the rear-most valve cover bolt head.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 10-03-2012, 12:36 PM   #2682
flyrodder
the rose goes in front
flyrodder's Avatar
Oddometer: 2,632
Wow. Dramatically different than I thought it would be.
Wet clutch in the FRONT of the engine? Gear driven alternator in the rear?
stuff goes here
flyrodder is offline   Reply With Quote
Old 10-03-2012, 12:41 PM   #2683
dmac57
dmac57's Avatar
Oddometer: 2,061
Send a message via AIM to dmac57
Originally Posted by FlyingFinn View Post
And I really don't give a rats ass how the bike looks,
Mikko
Sure you do. We ALL do. That's why nobody but JVB bought an ST.
"Everybody's got to believe in something.
I believe I'll have another beer."
- W. C. Fields
dmac57 is offline   Reply With Quote
Old 10-03-2012, 12:45 PM   #2684
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,609
Send a message via AIM to Some Dude
Except the title should be "2014 R1200GS ....."
2013's are already in production with the 2012 build spec's and it'll be May '13 before these hit the USA shores is my bet, which means 2014 model year designation.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 10-03-2012, 12:47 PM   #2685
radon222
1150GS-ADV
radon222's Avatar
Oddometer: 322
Send a message via AIM to radon222 Send a message via Yahoo to radon222
Awww come on... JVB's ST has a good excuse for its ummm looks... it was totaled when he bought it
'05 R1150GS Adv
'12 R1200RT (Wifey's bike)
radon222 is offline   Reply With Quote
Times are GMT -7.   It's 03:49 AM.
