Old 10-04-2012, 07:52 AM   #2761
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,576
Originally Posted by TuonoBiker View Post
I know you've been able to buy the single 7 inch round LED from Harley as an upgrade to the current Touring bike lineup. .
Led passing lamps as well...
twinrider is offline   Reply With Quote
Old 10-04-2012, 08:03 AM   #2762
JNRobert
Breaking Wind
JNRobert's Avatar
Oddometer: 8,431
Originally Posted by slipknot View Post
The pattern is now increased sophistication and technology, forever leaving behind all simple monikers. Bubble head- One can label the bike and the rider with one label. It rolls off the lips like the exhaust note. I'm going to practice stuttering for added effect. BBBBBBBubbbbble. Hypnotic and hip.
what it sounds is ugly and about tenth grade.
Crusader of Slack
JNRobert is offline   Reply With Quote
Old 10-04-2012, 08:05 AM   #2763
JNRobert
Breaking Wind
JNRobert's Avatar
Oddometer: 8,431
Originally Posted by Voluhzia View Post
Two radiators and only one on the right has a fan
So what, that's not unusual. Can you not clearly see the water flow in the illustration
Crusader of Slack
Old 10-04-2012, 08:05 AM   #2764
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,144
Do we know BMW's internal name, number, or other designator for this new engine? That might help to suggest a name we use.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 10-04-2012, 08:10 AM   #2765
SourKraut
Oddometer: 6,262
"Project Subaru"
SourKraut is offline   Reply With Quote
Old 10-04-2012, 08:23 AM   #2766
kvr929rr
kvr929rr's Avatar
Oddometer: 165
Honda did that on their SuperHawk and VFR800 in the late 90's. I wouldn't anticipate much of a problem with it.
kvr929rr is offline   Reply With Quote
Old 10-04-2012, 08:37 AM   #2767
genka
SUV hater
genka's Avatar
Oddometer: 941
Originally Posted by dmac57 View Post
Originally Posted by jfslater98 View Post
.. WHERE THE FUCK IS THE HIGH BEAM!?!?!!!"
On the right side bar.
WHERE??
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is offline   Reply With Quote
Old 10-04-2012, 08:38 AM   #2768
GB
Mod Squad
GB's Avatar
Oddometer: 53,466
The high beam is on the left cluster, at the front, you pull it in with your index finger to flash or push it out to keep it on. It's not visible in the picture, as it faces the front of the bike.
GB screwed with this post 10-04-2012 at 08:44 AM
Old 10-04-2012, 08:50 AM   #2769
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Not sure if I like that, at least I'd like to see the switch.
tallguy-09 is offline   Reply With Quote
Old 10-04-2012, 08:50 AM   #2770
DannyZRC
Oddometer: 808
Originally Posted by Midnullarbor View Post
Beemerlover (#2750) makes a very good point.
The gearbox/transmission is remarkably over-complex. Power from the crankshaft must go through four pairs of gears before reaching the shaft in the swingarm. (Versus only two pairs, in the current & past boxers ~ certainly one of the reasons contributing to the current fuel efficiency superiority over the transverse-crankshaft "big shafties" like the S10 and the Explorer.)
The extra friction must worsen fuel consumption a bit ~ probably more noticeable at lower throttle openings.
Maybe the slightly higher compression ratio will counteract that, to some extent.
Still, you can see that the engineers were aiming at compactness of design, and were okay with some compromises in order to achieve it. (In the face of an un-compact cylinder layout which had to persist.)
Transmission efficiency aside . . . it all looks very impressive.
The S10 afaik has been reporting better economy than the boxers, despite having to turn the power twice AND using a hypoid rear end.
So while it may be true that there are more meshes in the new tranny than the old one, this factor doesn't necessarily guarantee increased fuel consumption. Factors that suggest better economy : no separate chain drive for balance shaft, gear driven rather than belt driven alternator, water cooling.
DannyZRC is offline   Reply With Quote
Old 10-04-2012, 09:01 AM   #2771
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 1,558
Originally Posted by Marki_GSA View Post
No Italian manufacturer tests anything to do with electricity, ever. The are famous for producing really bad wiring and electronics.
The electronic suspension on the 2010-2012 Duc is by Ohlins. For 2013, both BMW and Ducati have gone with Sachs to get their "semi-active" technology.
And FWIW, the Sachs system does NOT have electronic pre-load, which was the source of the troubles with the Ohlins units (with the Ohlins, the pre-load servo fails, not the damping bits).
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad
Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-04-2012, 09:10 AM   #2772
Sock Monkey
Corporate slave
Oddometer: 1,558
Originally Posted by sidewinderx View Post
my ms1200 made me do very bad things.....
i will miss my little red italian mistress.
+100
-sm
aka NoVector
Old 10-04-2012, 09:18 AM   #2773
Sock Monkey
Corporate slave
Oddometer: 1,558
Originally Posted by ka5ysy View Post
Except the rider now... Looks like the water radiator is on the right side with a fan system, and the oil cooler is on the left. Lots of heat dumping on the riders legs. Yikes !
That is going to make heat management an issue in the evolution of the RT. Glad I bought the Camhead version.
I thought the same thing, but look closely at the pics and you'll see plastic ducting that forces the hot air coming through the rads out away from the rider.
-SM
aka NoVector
Old 10-04-2012, 09:19 AM   #2774
Boxer-lust
Oddometer: 528
After looking at the pictures and let it all sink in I must say I like the looks of the new GS as the new engine is as good of a design for a motorcycle engine as it gets !
The 2 cylinder boxer was always a perfect motorcycle engine for everything but roadracing purposes with it's balance,low center of gravity,no crankshaft gyro to affect handling in a negative way,ease of maintenance and unique ability to protect bike and rider in case of mishap.
Now they made the intake runners straighter to get more power and put the clutch where it doesn't cause expensive bills anymore if it needs to be replaced.
No alternator belt anymore that can break or needs to be replaced.
As for accessability it sits under a cover that should beeasy to access after the tank is taken off.
As for the valve adjustment it looks like the cams have to come off because the followers don't slide to the side anymore like in the camheads.But even this should be easy as no timing chain has to come of with the gears driving the cams.
Should be a great engine powering a 135hp/nm R1200RS in the near future...
My guess is that a water-boxer R1200RT and R1200GS-ADV are next for 2014 out in autumn of 2013...
Boxer-lust is offline   Reply With Quote
Old 10-04-2012, 09:34 AM   #2775
(none)
poser
(none)'s Avatar
Oddometer: 2,492
Originally Posted by SourKraut View Post
Except there is no water in the heads. It is a waterboxer.
Sure there is. look at the diagram, water flows around the valves
As mentioned, Honda did this with the VFR, RC51 and superhawk. They had limited success (i've owned 2 VFRs), mainly due to them orienting the radiators sideways and the way the fan pulled air (causing no airflow to the radiator when moving while the fan was on).
BMW had a similar setup on the K1200RS/GT, although they had 2 small fans (1 on each radiator). I think some of the KTMs run a similar setup to this (2 rads, 1 fan) and some people upgrade to a second fan.
Current:
2001 R1150GS
1981 CB650 Custom
2011 Golf TDI - New tow rig
(none) is online now   Reply With Quote
Times are GMT -7.   It's 06:17 PM.
