Old 10-06-2012, 10:06 AM   #2926
stubmw
some what aloof
stubmw's Avatar
Oddometer: 2,444
Well maybe it's just me, but any design where you need a fan to cool the head light seems kind of ridiculous. More so on a MC that has adventure pretensions.
stubmw is offline   Reply With Quote
Old 10-06-2012, 10:09 AM   #2927
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Embrace the future! Anything is better than the frequent halogen bulb outages and broken spring clips, right? LEDs handle vibration very well...I have one on my mt bike.
EJ_92606 is offline   Reply With Quote
Old 10-06-2012, 10:24 AM   #2928
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
34W lo-beam and hi-beam LED?
tallguy-09 is offline   Reply With Quote
Old 10-06-2012, 10:26 AM   #2929
NoobIAm
Far, far from the Garden.
NoobIAm's Avatar
Oddometer: 2,554
As stated somewhere earlier, the fan does more than cool… it is used to dehumidify and deice the lens by blowing the heat from the chips against it.
NoobIAm is offline   Reply With Quote
Old 10-06-2012, 10:27 AM   #2930
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by NoobIAm View Post
Technically, you are correct… however, they show several options under that tab… Akrapovic silencer, another windscreen, various footpegs, etc. So my point remains… they have introduced an element of confusion (at this point in time), by not calling out the headlight options. But, it wouldn't be marketing without such, now would it…
Those are accessories, not options, just as they've always been and are on any other BMW model. You buy them from the parts department.
Old 10-06-2012, 10:31 AM   #2931
NoobIAm
NoobIAm's Avatar
Oddometer: 2,554
Most probably achieved by the design of the reflector. Two separate, but equal LED's… one concentrated for Hi and the other spread out for Lo.
Old 10-06-2012, 10:35 AM   #2932
Ua the Destroyer
Ua the Destroyer's Avatar
Oddometer: 243
I thought low beam headlights on all US motorcycles were required to be on at all times. Wouldn't that make the integrated u shaped ring pointless in the states if the low beam light in the housing was always illuminated? The u shaped light is not a a low beam headlight, it's just a daytime marker correct? That might explain the halogen light with non-integrated led daytime running light, it's a way of meeting us regulations, but giving us some led technology.
Ua the Destroyer screwed with this post 10-06-2012 at 10:42 AM
Ua the Destroyer is offline   Reply With Quote
Old 10-06-2012, 10:36 AM   #2933
NoobIAm
NoobIAm's Avatar
Oddometer: 2,554
Well…. I would submit that any "accessory" requiring that BMW install it, could rightly be classed as an option… especially where it replaces a stock item. But you say tomato, I say tahmahto…
Old 10-06-2012, 10:40 AM   #2934
ragtoplvr
Oddometer: 6,522
A HID capsule and halogen capsule really don't care much how hot they run. Electronics components do. So all that will happen if your halogen capsule operates at 250C air is more light, an led would fail right away. Also, keeping the LED cooler will really extend its life, if you keep it at 100F over 150 F the life is much longer. Good reason to use the fan.
Rod
ragtoplvr is online now   Reply With Quote
Old 10-06-2012, 11:18 AM   #2935
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
So we have 2 different DRL's. One nice U-shaped and the other large module below the high beam. Both aren't considered lo-beams, right?
Old 10-06-2012, 11:26 AM   #2936
sbrownn
SlowMo
Oddometer: 457
Just guessed
28K how did you come up with that?
I don't know. There are at least 5 add on packages and I figured they would cost about $1500 apiece. I'm sure I am wrong but the fact remains that a lot of the stuff that comes standard on the Multi will be added to the base price of the BMW. Don't get me wrong I would much prefer the BMW but I'm not sure I want to bend over that far.
sbrownn is offline   Reply With Quote
Old 10-06-2012, 11:28 AM   #2937
stubmw
some what aloof
stubmw's Avatar
Oddometer: 2,444
If we now require cooling/dehumidifying fans on our motorcycle headlights the future seems complex.
I guess as long as it's reliable as an anvil it won't matter.
Old 10-06-2012, 11:37 AM   #2938
ragtoplvr
Oddometer: 6,522
From the humidity standpoint there is a big difference between putting 55 watts of heat inside the enclosure, to putting about 7 to 10 of the led watts inside and the rest in the heat sinks outside.
I will state that a relay and $12.00 halogen capsule is inexpensive and does a fine job of lighting the road. This difficult to impossible to repair module hopefully will be as reliable as an anvil. I also stand a good chance of changing said Halogen capsule on the road, and it is small enough to carry a spare. I suspect this is not the case for this module.
Beware solutions for problems that do not exist
Rod
ragtoplvr screwed with this post 10-07-2012 at 09:47 AM Reason: fix unclear
Old 10-06-2012, 11:53 AM   #2939
Ua the Destroyer
Oddometer: 243
Not positive, but that's probably how the us regulations will play out. The US always seems to be behind the times on vehicle illumination. Almost all the german vehicles I've owned have had a different type of headlight than it's european counterpart.
Old 10-06-2012, 11:54 AM   #2940
Josephvman
I'm the Decider
Josephvman's Avatar
Oddometer: 3,470
I can't imagine what this bike will cost to maintain and fix when it's ten years old. The freaking headlight has it's own cooling fan!
I wonder if the water pump has it's own water pump? I'm guessing a broken headlight is north of $2k.
Wow looks like the LED headlight assembly needs an electric motor and fan to cool it....... engineering if so.
'11 Ducati Multistrada 1200S Sport "Stormtrooper II"
'09 BMW HP2 Sport
'98 Ducati 900SS Final Edition "The old whore"
'93 Ducati 900SS "Slightly older whore"
"Gentlemen. You can't fight in here. This is the War Room!"
Josephvman is offline   Reply With Quote
Times are GMT -7.   It's 07:16 AM.
