Old 06-23-2011, 02:11 PM   #301
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,148
Originally Posted by JimVonBaden View Post
IF we see this any time soon, we will likely call it a WasserBoxer. That seems to be the prevailing feel I get.
Jim
That's what Porsche called their flat six when they went to water-cooled heads.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 06-23-2011, 03:16 PM   #302
Murkidi
R1100GS adict
Murkidi's Avatar
Oddometer: 229
+1
I like it !!!! but first I have to own a hexhead an then a camhead to reach the wethead!!!!!
Originally Posted by johnjen View Post
I like em short, simple, and to the point.
WetHead
JJ
Murkidi is offline   Reply With Quote
Old 06-23-2011, 05:59 PM   #303
JStancampiano
PhotoJoe
JStancampiano's Avatar
Oddometer: 399
That looks like a wet clutch in there.
Joe
Originally Posted by Jan from Finland View Post
Here is a link: http://www.motorradonline.de/de/moto...1250-lc/365973
Mostly speculation and an iterview of Hendrik von Kuenheim, Director of BMW Motorrad, who tries to play it down by saying "I can assure you, we will stick to the air cooled boxer for years." and " The boxer, as it is designed today, can meet the future limits for exhaust and noise. It doesn't force us to water cooling.".
Photo: By BMW via Motorrad
2007 R1200GS ADV, 1978 R100T, 2009 FJR
JStancampiano is offline   Reply With Quote
Old 06-24-2011, 05:03 AM   #304
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,596
Joe
To me, the interesting thing is that engine power output is not routed through the center of the clutch, leaving the clutch on a different plane. If this means that clutches can be serviced without removing the back half of the motorcycle, it would be a HUGE improvement.
Old 06-24-2011, 05:32 AM   #305
gelandestrasse
Fidem Scit
gelandestrasse's Avatar
Oddometer: 20,255
It looks like the crank runs right through the center of the clutch.
"The trouble with quotes on the Internet is that you can never know if they are genuine."
- Abraham Lincoln
gelandestrasse is offline   Reply With Quote
Old 06-24-2011, 07:01 AM   #306
Jan from Finland
Registered
Oddometer: 567
I guess you are talking about the transmission output shaft, not the engine output.
Asymmetry could also lessen engine roll when you blip the throttle.
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 06-24-2011, 07:04 AM   #307
pavement pounder
Dirt is the spice of life
pavement pounder's Avatar
Oddometer: 744
why is there a chain driven and gear driven cam at the same time. Am I missing something? Where's the water pump
The road to paradise is UN-paved!
go for it! Life's too short to think twice!
Charlie B. (The other Boorman)
Trans-Lab 2010 - James Bay 2011 - Shenandoah to Deal's Gap 2011
pavement pounder is offline   Reply With Quote
Old 06-24-2011, 07:14 AM   #308
Jan from Finland
Registered
Oddometer: 567
To make it narrower?
Could be an electric one, like they use in BMW cars.
Old 06-24-2011, 07:19 AM   #309
Kawidad
Kawidad's Avatar
Oddometer: 4,965
Gear driven dual cam shafts off of a chain driven crank gear is a very common engineering solution to cam drives methods. It is on many different modern motorcycles. It works well.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 06-24-2011, 08:22 AM   #310
kvr929rr
kvr929rr's Avatar
Oddometer: 182
The K-bikes have their cam drives like that and the electric water pump makes the most sense from a packaging viewpoint. It would also reduce power drain on the crank. With a multiplate clutch being on the crankshaft like that I would think the trans would be located vertically on the side, not underneath. Vely intelesting.
kvr929rr is offline   Reply With Quote
Old 06-24-2011, 08:41 AM   #311
ragtoplvr
Oddometer: 6,504
I expect they raised the cylinders a bit more for more corner clearance. Then you have room for the transmission. Shared oil for engine and transmission lets you use the sump space for some gears. Just think of all the oil threads now.
Rod
ragtoplvr is offline   Reply With Quote
Old 06-24-2011, 08:44 AM   #312
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 6,764
Where is the prebuy form please??
A little wear and tear is expected.
little foot is offline   Reply With Quote
Old 06-24-2011, 08:54 AM   #313
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,771
Rod
Jim
Old 06-24-2011, 09:03 AM   #314
kvr929rr
kvr929rr's Avatar
Oddometer: 182
The trans looks too far back to share the oil storage space. The output shaft just looks too low to me to be able to keep the drive angles and ground clearance that are on the current bike without raising the cylinders too much. The CoG is already pretty high. I like the idea of the multiplate, wet clutch but the current system has its' advantages too. I wonder if they considered putting the clutch on the front of the motor with a short shaft over or under the crank to the trans? Just a thought.
Old 06-24-2011, 09:24 AM   #315
Robear
Quack Kills
Robear's Avatar
Oddometer: 161
Thinking the same thing Little Foot.
Must save money, must save money, must save money...............
"This river don't go to Aintry. You done taken a wrong turn."
Robear is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
