11-27-2012, 02:40 AM
#3796 | |
Oddometer: 1,114
The latest Stelvio comes in two versions in Europe, one with spoked wheels (NTX) and one with cast (8V), and they had both on the launch: "Swapping between the two and riding through mountain roads it's the 1200 8V version that I wanted to stay on. It's the keener of the two bikes and much easier to throw around. Admittedly it's not carrying an extra 22kg of extras around with it but it's the wheels that make the biggest difference. "Although the 1200 8V's alloy wheels and the NTX's spoked wheels weigh the same amount, the NTX's carry most of their weight on the rim and this inertia makes a big difference when it comes to cornering. It's not that the NTX is bad at turning on its side, it's just the 1200 8V just feels so much better." (Quotes from 2012 Stelvio piece at visordown.) Can't say whether the same applies to the GS wheels, but it may well do.
Sorting out the S4Rs Ohlins shock: click here. |
11-27-2012, 02:43 AM
#3797 | |
Oddometer: 506
2013 BMW R1200GS LC TE 2010 BMW HP2 MEGAMOTO |
11-27-2012, 03:32 AM
#3798 |
Resident Raggamuffin
Oddometer: 1,699
So, is the journo saying that the Stelvio's cast and spoke wheels weigh the same but that the lighter of the two motorcycles (8v) is the easier to maneuver/flick around? No surprise if so. Or is he talking about the construction of each wheel and how the weight is distributed amongst them (hub, spokes, rim versus one cast piece)?
2012 Ducati 1199 Panigale 2012 Ducati MTS1200St Ti 2003 Aprilia Tuono Racing 2012 Vespa 300 Super past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well. oalvarez screwed with this post 11-27-2012 at 03:37 AM |
11-27-2012, 05:07 AM
#3799 | |
Oddometer: 1,114
He is acknowledging the NTX carries more weight, but attributes most of the steering difference to the wheel construction, with the cast wheels carrying a lower proportion of their mass at the perimeter. So, the gyroscope effect was less pronounced on the cast wheel, he believed. This made for lighter steering, which he greatly preferred on twisting tarmac prevalent at the launch.
11-27-2012, 05:15 AM
#3800 | |
Whew! Good on ya for being a good sport!
"Everybody's got to believe in something. I believe I'll have another beer." - W. C. Fields |
11-27-2012, 10:12 AM
#3801 |
Rider
Oddometer: 1,392
And the Stelvio licenses the spoked wheel patent from BMW, so the construction is similar. Another factor to consider aside from rotating mass is stiffness...the spoked wheels are stronger offroad because they have some flex...which I would think would be a negative for paved twisties.
11-27-2012, 10:17 AM
#3802 |
Oddometer: 260
11-27-2012, 10:18 AM
#3803 | |
Oddometer: 506
11-27-2012, 11:18 AM
#3804 |
Oddometer: 260
I wish this spoke vs cast rim issue was just as simple as picking colours.
I was going to do some physics calculations at higher accuracy (not involving the effects of tire and flexing of it at higher speeds along with the effects of gravity due to vertical alignment), but I decided for later if time permits. Here's what I think: Assuming total weight to be the same for either rim, the geometry of weight distribution are quite different. Spoke rims will weight higher at the ends, because of total weight minus the small weight of sum of spokes. While the Cast rim will have weight distributed across the wheel due to weight of cast spokes. Hence, I suspect the centripetal acceleration to be different, while the centrifugal force may remain somewhat the same (it could also change). Due to increased centripetal acceleration for a spoke rim at a given constant speed, the effects of turning on a curve would be pronounced as we increase the angle of lean. This effect translates to a feel and handling of a bike on a paved curve. Scientifically, it would be there, however, once you start riding your own bike, you get accustomed to its handling, and you make adjustments to it without even knowing. This is what I call your "style" of riding. We ride bikes that we own, unlike journo's who tests them against another. So, IMHO, I think get the wheel you want, spoke is great because it has tendency to flex if you were to go off-roading or unexpectedly go over big bumps, it will be far more forgiving. It also means about $500 more as an option! |
11-27-2012, 11:58 AM
#3805 | |
Rider
Oddometer: 1,392
11-27-2012, 12:52 PM
#3806 | |
Sure, why not?
Oddometer: 16,136
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
11-27-2012, 01:37 PM
#3807 | |
Oddometer: 506
![]() That was funny! I liked the summary that Montauk gave though, I knew the was a more scientific explanation
11-27-2012, 01:57 PM
#3808 |
Oddometer: 323
Just saw this, knew about it but hadn't seen this clip before! I just really love the sound of the wet head :)
http://www.youtube.com/watch?v=76HUC...em-subs_digest
09 R1200gs |
11-27-2012, 02:30 PM
#3809 |
iExplorer
Who wrote their script director? I like what Charlie says at the end... NOW, you can conquer the world...
Nova Scotia on Explorer Voluhzia screwed with this post 11-27-2012 at 04:03 PM |
11-27-2012, 03:00 PM
#3810 | |
Sure, why not?
Oddometer: 16,136
