12-13-2012, 11:42 PM
#4006 | |
Rider
Oddometer: 1,392
12-14-2012, 02:12 AM
#4007 | |
Oddometer: 490
Current Bikes: 2012 Yamaha Tenere, 2010 Vespa 300 Super scooter ( hers), 2011 Blur 220i (his) |
12-14-2012, 03:47 AM
#4008 |
Oddometer: 197
The current boxers don't require a sync on the idle circuit (idle servo) its only the mechanical cable part that you can adjust part throttle. I don't know if the new drive by wire uses a separate idle, main servo or if it's just one but however they do it now on the idle could be used on the new system.
12-14-2012, 05:12 AM
#4009 | |
Oddometer: 4,547
Rod |
12-14-2012, 05:14 AM
#4010 | |
Oddometer: 4,547
Rod |
12-14-2012, 07:19 AM
#4011 |
Oddometer: 3,458
That reminds me of my Tiger 800: I hook up the laptop with diagnostic software and it tells me exactly how the TBs are out of sync, so it knows exactly what's wrong. It's NOT ride by wire though and and it doesn't have a computer controlled mechanism to adjust - so I have to manually adjust them. Would have been so much nicer to get ride by wire and have them automatically adjust via build in mechanism.
12-14-2012, 08:26 AM
#4012 |
Oddometer: 82
prices in Germany
New GS retail price in Germany (19% VAT included) has been quoted by a dealer to an inmate in another bmw forum as follows:
Base price with ABS €14,100 (plus delivery) Comfort pack €650 Aktiv pack €890 Touring pack €1,490 Dynamic pack €2,100 I'm impressed. They did not go over the top. |
12-14-2012, 10:11 AM
#4013 |
Oddometer: 5
In Holland €16950. €400 less then the 2012 GS
12-14-2012, 10:17 AM
#4014 | |
Rider
Oddometer: 1,392
12-14-2012, 10:46 AM
#4015 | |
Talks to cats
Oddometer: 5,305
![]() It wouldn't surprise me if the LC bikes are the same, less any off idle throttle cable adjustments. |
12-14-2012, 11:56 AM
#4016 | |
Rider
Oddometer: 1,392
12-14-2012, 01:12 PM
#4017 |
Oddometer: 197
I was using the current none udjustable idle sync as an example of how they currently know where the valves should be. I. E they can do it now so they can do it for the whole setup on the new engines. I already stated you can and need to adjust the off idle on the current models because it's mechanical.
12-14-2012, 02:15 PM
#4018 |
Oddometer: 260
Dynamic ESA with Low Suspension question
I am trying to track back to my question to BMW Rep from NJ for him to recommend me to go with Standard GS with low seat option. I had shown my 30" inseam limitation and need for a lowered suspension to him. With Standard, I barely got the bike off the stand and was tippie towing.
Someone here mentioned that Dynamic ESA is not available with Low suspension for the WC. I searched google and could not find the answer. I wanted to confirm this. Called my local dealer, he said with current model ESA is not available with low suspension, but he could not confirm same holds true for the new water cooled GS. Does anyone have any answer, or have talked to the BMW rep and gotten any answer whether Dynamic ESA is available with Low Suspension. .... I wish I was 6 foot tall, and then I wouldn't have had these problems. |
12-14-2012, 03:26 PM
#4019 | |
"Cool" Aid!
Oddometer: 41,497
It looks like it, but it depends on the diameter of the swingarm. I am guessing yes. Jim
12-14-2012, 04:22 PM
#4020 | |
gunna b adventuring
Oddometer: 4,837
Have you had the opportunity to mount the h2ohead? I found the seat and seating position much more accommodating to those of us that were short changed in the leg department. And the overall ergos fit me much better than my '05 even with the changes that I made to it. You may find that the bike may not need to be lowered.Oh, and about your question, I have no idea about a lower ESA version.
. I ride faster than I should but slower than I wish. I know there is risk, but I balance it against skill and luck and that act is a big part of why I ride motorcycles and why I bother with a trip like this. - Neduro "When injustice becomes law, resistance becomes duty." - Thomas Jefferson |
