Old 12-19-2012, 12:02 PM   #4066
Darkjedip
Designated Thread Killer
Darkjedip's Avatar
Oddometer: 81
I'm pricing unveiled at 11395 pounds for base model, that's about $18500 USD. Owch.
DL-650AK8
1977 Bonneville T140V Project
Aspiring Moto-journalist needs feedback:
http://nowheelieshere.blogspot.com/
Darkjedip is offline   Reply With Quote
Old 12-19-2012, 12:11 PM   #4067
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 6,663
Are they accepting orders yet?
A little wear and tear is expected.
little foot is offline   Reply With Quote
Old 12-19-2012, 12:19 PM   #4068
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I"m not sure what you just said, but if you are trying to derive a US price from the UK you can't translate from other countries to get a US price. Try it for the previous GS and see. Fact is in most countries, the new GS is being sold for same price as the old GS. I think that is the best metric you can go by at this point.
EJ_92606 screwed with this post 12-19-2012 at 09:14 PM
EJ_92606 is offline   Reply With Quote
Old 12-19-2012, 01:52 PM   #4069
LaurelPerryOnLand
Oddometer: 3,481
ONE WORLD...ONE R1200GS contest....
You absolutely SURE you'd want to purchase one after MOTORRAD's stupidity.
Not a single rider outside of the EU was selected. 5 possible winners.
http://advrider.com/forums/showthread.php?t=849739
LaurelPerryOnLand is offline   Reply With Quote
Old 12-19-2012, 08:04 PM   #4070
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,611
doesn't have the slightest impact on how i view the new water cooled GS nor the BMW corporation.
looking forward to test riding it next spring.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 12-19-2012, 11:35 PM   #4071
GSMarc
GSMarc's Avatar
Oddometer: 1,107
Does somebody knows the "dry weight" of the new GS ?
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 12-20-2012, 12:35 AM   #4072
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
The press release shows 524 pounds ready to ride (wet). Not sure of dry weight.
Old 12-20-2012, 12:43 AM   #4073
Montauk
Oddometer: 280
I know BMW posts the dry weight, however, I have always questioned what's the purpose of dry weight, for comparison. Comparison to what? You can't ride a bike with dry weight. To me, personally I look for all fluids along with gasoline (petrol) filled and ready to ride.
I suppose it will come handy if other manufacturers only post dry weight.
Montauk is offline   Reply With Quote
Old 12-20-2012, 12:44 AM   #4074
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I agree and there is no formal definition of 'dry'. I hear some manufacturers exclude the battery on dry weight for example.
Old 12-20-2012, 01:04 AM   #4075
GSMarc
GSMarc's Avatar
Oddometer: 1,107
I can understand your arguments.
But, if you want to buy a R1200GS or a R1200GSA, the wet weight doesn't give you a clear weight gap because the tank is larger on the ADV and perhaps some parts are also heavier.
It is also supposed that BMW weights his bikes in the same way and this implies the dry weight has some meaning (in same brand).
My question was : dry weight WC to be compared to R1200GS DOHC 203 kg (447 lbs) keeping in mind that the WC has an ABS in standard equipment.
By the way, what is the weight of the WC ABS ?
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-20-2012, 01:17 AM   #4076
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Gas weighs about 7 lbs/gallon, so very easy to do the math on the tank size/weight of gas between the GS and GSA. The GSA is a GS with bigger tank and some extra equipment, so not sure what you are getting at by wanting to know the weight of a GSA without the extra gas and equipment....its going to equal a GS.
Old 12-20-2012, 01:50 AM   #4077
GSMarc
GSMarc's Avatar
Oddometer: 1,107
you are right, the dry weight will show how much "dead weight" there is between the 2 models out of the box.
The strange thing is that dry weight is given for all models but not for the new GS.
For me, the weight is one of the main variable for a bike, specially if you want to go in various environments.
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-20-2012, 01:59 AM   #4078
Montauk
Oddometer: 280
As an engineer, when actual data is not available, you try to approximate as close as possible and leave some room for error. In this case I would find the difference in weight of current model 2012 GS/GSA using "dry", and do the same for "wet". Now you have 2 weights. Add 1-2 lbs for ABS (chime in guys if I am wrong in my ABS approximation). We are assuming that GSA gas tank will remain same as current. In the new, they might shave off 1-2 lbs using stronger and lighter plastics. This will cancel with weight added due to ABS. To approximate the wet weight of a new GSA, add the wet difference to new 2013 GS model. So there you have it. Similarly you could approximate dry weight backwards.
Old 12-20-2012, 02:14 AM   #4079
Montauk
Oddometer: 280
Yes, but it becomes fixed variable, you can't decrease it but will only increase due to farkling etc. No matter which environment you go on the globe, it will remain static. Am I missing something here? Perhaps you are trying to figure out something that we don't know
Old 12-20-2012, 02:19 AM   #4080
GSMarc
GSMarc's Avatar
Oddometer: 1,107
main variable for making your choice to buy or not...
Why do you believe I have only HP2...
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Times are GMT -7.   It's 04:21 PM.
