Old 03-27-2013, 09:39 PM   #7561
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Originally Posted by Oldpeg View Post
The alternator output has been downgraded from 720 W. to 580 W. because they didn't need double-spark anymore, and they added a decompressor of some sort at start-up. But I guess it was still a bit weak, so they limited the heated grips power requirements. It's a shame and a letdown. I don't even know if my electric liner will work okay via Canbus.
I'd say that it is speculation that the new alternator configuration has anything to do with the heated grips max. temperature. How much power do both pre-2013 draw on the highest setting?
Could also have to do with legal requirements; some riders without gloves might get their hands roasted and BMW therefore limits the temperature? Who knows...
tallguy-09 is offline   Reply With Quote
Old 03-28-2013, 01:18 AM   #7562
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,173
Fatter grips?
Thinner power lines?
Good thing that in Greece this is more minor than minor.
(erm scratch that, if you actually travel with this bike)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 03-28-2013, 01:25 AM   #7563
schisi
schisi's Avatar
Oddometer: 52
I like this forum.
I have something new or maybe not, probably not. How about these heated grips? The Germans think they are not getting that hot anymore (burning hot as in the past), true/false?
I didn't really feel a difference... maybe it's only because March is much colder this year in Europe.
schisi is offline   Reply With Quote
Old 03-28-2013, 01:29 AM   #7564
Bundu
Bundu's Avatar
Oddometer: 696
Originally Posted by RichBMW View Post
Here in the UK, BMW will supply the alarm fob for 20.
I can see the benefits of auto activation, but as I only ride at weekends, I'm going to have to remember to turn off auto activation every Sunday night, as I don't want a flat battery the following weekend. Or can the alarm be left on for weeks if I don't ride, without flattening the battery?
I'm quite sure the alarm will consume virtually no power when active, as it does not have a receiver
Bundu is offline   Reply With Quote
Old 03-28-2013, 01:34 AM   #7565
NLS
NLS's Avatar
Oddometer: 3,173
Originally Posted by maximo de la maximus View Post
Good report!
A few things:
a) Can you elaborate? Clutches do have a "sweet spot" AFAIK, even wet clutches. Here you cannot modulate as much as you wanted and pin-point where the gear goes in?
c) Is this said as a good or a bad thing? The new clutch is supposed to slip so that you don't get the effect of engine breaking to a dangerous point.
h) New mappings (as per manual) activate with zero gas and pulled clutch (including while moving). Pretty intuitive I'd say.
NLS
My Blog
Old 03-28-2013, 01:37 AM   #7566
NLS
NLS's Avatar
Oddometer: 3,173
Not true.
The sensors are still there (both move sensors and receiver for optional remote).
In "old" GS, alarm deactivates by itself (!) after a few days (don't remember how many) to not kill the battery. I actually found this weird when I read it in the (old) manual. Don't know if it was like that in future revisions and/or current model.
NLS
My Blog
Old 03-28-2013, 01:55 AM   #7567
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
In Greece, on Road 20 in Pantalofos, two years ago. I was very happy I had heated grips.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 03-28-2013, 02:19 AM   #7568
NLS
NLS's Avatar
Oddometer: 3,173
[TaSK]
That shaked me a bit. This weekend are the birthdays of me, my son PLUS a kid party of a friend. But next weekend I will definitely go for a trip. F*ck it's been too long.
Thanks.
NLS
My Blog
Old 03-28-2013, 02:24 AM   #7569
MaxReving
MaxReving's Avatar
Oddometer: 257
I dont like to question your comment. I guess that you by "alarm fob" mean a key fob or remote. Am I right? I have been told that it is not possible to remote control the new alarm system. My dealer told me that they have received updated information from BMW Motorrad just two days ago, that states that it is not possible to remote control the alarm. The user manual that comes with the alarm system does however have an illustration of a key fob on the front page.
What is right and wrong in all this?
Max :-)
MaxReving is offline   Reply With Quote
Old 03-28-2013, 02:48 AM   #7570
mrjon
Oddometer: 120
The new GS has the same 580W alternator as the K16GT has. That bike hase a 5 stage control for the heated grips controlled through the menu system and on the higher settings it's very warm, much warmer than the GS's.
The switchgear and grips are also identical, I think the grips can be improved with a simple software upgrade.The grips aren't actually powered all the time but are modulated by software and also take air temperature into account.
Future..on order-BMW GSA LC,
Present..BMW R1200GS LC, K1200R-SPORT, R1200S,HP4
Past.. BMW R1150GSA,R1200GSA,R1200GS,R1200RT,K1600GT
mrjon is offline   Reply With Quote
Old 03-28-2013, 03:19 AM   #7571
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,087
It is the same with Triumph. I recently had the grips on my Tiger replaced under warranty. The old ones would get so hot that within 5 minutes, you needed to turn them to low setting. The new ones can be left on high constantly and still arent hot enough.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 03-28-2013, 03:33 AM   #7572
paulW
Oddometer: 143
Good point, well made. I am sure you are correct on the pulse width modulation to control power output (same as LED lights) and a simple software upgrade. Let's nag the life out of dealers until we get what we want
paulW is offline   Reply With Quote
Old 03-28-2013, 04:40 AM   #7573
Deans BMW
Granpa Hoon
Oddometer: 3,466
Re the apparent "Slipping Clutch".
The new GS's have a slipper clutch, or "Anti Hopping" as it is called in Europe.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 03-28-2013, 05:00 AM   #7574
airhawk1
Asspad Tycoon
airhawk1's Avatar
Oddometer: 25
I like this forum.
I rode for about 45 minutes yesterday with my grips on high on the new GS. This is something that I never did on my R12R. I would get them warmed up on high, then I would have to go to low because they got too hot. This hasn't happened yet on the new GS.
Steve Peyton
Ass Pad Tycoon
R1200GS LC
Road King Custom
airhawk1 is offline   Reply With Quote
Old 03-28-2013, 05:11 AM   #7575
NLS
NLS's Avatar
Oddometer: 3,173
So it is pretty much common observation that the heated grips suck on new GS. :)
I really hope this can be fixed using software (I am not so sure).
I wonder how they missed this when Germany is a cold country...
More and more things seem to have slipped. Someone inform this guy:
http://www.autoevolution.com/
...as he absolutely loves to bash GS (behind an "objectivity" curtain).
I can already see his next blog entry: "LC GS failures pile up! Frostbite from messed up heated grips! 6th recall soon? (he seems to add recalls in doubles) Will they do it right this time or burn the fingers of their customers?"
NLS
My Blog
Times are GMT -7.   It's 12:09 PM.
