Old 03-28-2013, 06:29 PM   #7636
maximo de la maximus
Abracadabra Holmes
maximo de la maximus's Avatar
Oddometer: 56
Originally Posted by NLS View Post
Good report!
A few things:
a) Can you elaborate? Clutches do have a "sweet spot" AFAIK, even wet clutches. Here you cannot modulate as much as you wanted and pin-point where the gear goes in? Yes. I'm sure this clutch also has a sweet spot- I just have to develop a feel for it. For example- standing and doing slow speed full lock turns was second nature on my 06. I think it will be on this model as well but I need to get used to the much smoother reference points both in the clutch but also throttle and brake. The advantages are already clear in other riding situations: quicker/smoother shifts, amazing "blips" to up revs and lighten the front, not to mention a lot easier on the hand. My comments were in reference to the difference rather than anything negative. It's an improvement.
c) Is this said as a good or a bad thing? The new clutch is supposed to slip so that you don't get the effect of engine breaking to a dangerous point. [COLOR="rgb(0, 191, 255)"] It's a good thing! I have another bike with a slipper. Downshifting a couple gears, dumping the clutch and feeling the bike squat as you start to corner is joy. I always had trouble adjusting between the 06 and would frequently start chirping into a bumpy corner- no joy. Haven't tested its limits but it's also very different (from 06) and very welcome. Can't wait to try it on warm tires, clean road, dynamic mode, hard suspension... etc. [/COLOR]
h) New mappings (as per manual) activate with zero gas and pulled clutch (including while moving). Pretty intuitive I'd say.
Yes- that's right. In reading about it before hand I had imagined having to "unload" the engine to a point where it was awkward. After testing it you're right- very intuitive. On a few very quick shifts (almost cluchless) it didn't engage the cued up mode but I was impressed on how easy it was to use.
Some more miles today. The more I get used to it the better it gets.
Also- for me anyways neutral is easier than on the previous. It's much smoother than the engine noise would indicate. Had to buy a new pair of gloves as the grips melted mine... OK-just kidding. Easier to get up on the center stand but really, who cares- the bike's ride delivers. Enjoy it for that! Looking forward to what the other tire options are though.
Warm weekend ahead.... Oooouuwwww.
MdlM
maximo de la maximus is offline   Reply With Quote
Old 03-28-2013, 06:42 PM   #7637
Abracadabra Holmes
Oddometer: 56
yes- different
Originally Posted by bemiiten View Post
Can't quite decipher this. Is the new clutch easily modulated like the dry clutch? The tractor like power and perfect clutch action are the hallmark of what makes the GS so adept hooking up and negotiating technical terrain. Hope they didn't screw this up.
I tried to answer this just before but you bring up the tractor!- which I agree is key to the bike. I also think that feel and familiarity are key to that type of control. In my very brief experience I was able to do the same type of maneuvers I've learned to do on my older model but it took a lot more concentration. With that said It's already getting easier and that's just an indication of my learning curve... and I'll be the first to point out that it's probably the "archer not the arrow". Tractoring (is that a word?) on my 06 felt kind of gritty on all three controls- the new ones are so smooth (maybe a different sound feedback as well) it just takes a bit of schooling.
FWIW- getting some wheel spin is just flat out easier!
MdlM
Old 03-28-2013, 06:58 PM   #7638
Dude69
Usurper of Gov'ts
Dude69's Avatar
Oddometer: 1,409
Saturday...
1 hour of demo riding schedule... Vroom Vroom!!!
"I've never had a bike ask me if I'm going to be inside riding my wife all day"
1999 BMW R1200C & 2007 BMW R1200S
Past loves: 2008 R1200GSA/2001 R1200CLC & Phoenix /2005 F650GS/2002 R6/1973 R50/5 Toaster
IBA #32752
Dude69 is offline   Reply With Quote
Old 03-28-2013, 08:21 PM   #7639
Japanviking
Oddometer: 94
Picking up my bike tonight. Since I live only 5 min from the dealer I could not resist taking a peek at the bike this morning as it was being prepped
Time sure moves slow today...
BMW S1000RR -12
BMW R1200GS -13
Japanviking is offline   Reply With Quote
Old 03-28-2013, 08:43 PM   #7640
fess
Oddometer: 57
Originally Posted by Montauk View Post
Since we are on the topic of heated grips being not warm on the LC GS. I may add, that on my 2004 R1200C, the left side heated grip is quite less warmer than my right side. Although my bikes heated grips have nothing to do with LC GS, but it does create a question as to how BMW routes supplied heat to them.
Has anyone noticed any difference in warmth between the left & right grips? Are they at the same level?
Typically the left grip needs to be hotter than the right one as it is on the metal handlebar which conducts heat from it. The right one sits on the throttle tube which insulates it.
2015 BMW R1200GSA
2014 KTM Super Duke 1290
fess is offline   Reply With Quote
Old 03-28-2013, 09:57 PM   #7641
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,549
Yes, the clutch is easily modulated. And I suspect you can slip it without worry, too. The bike has MORE low end grunt than my '05. It has more high end grunt, too. The throttle response is something else. If you don't have a smooth throttle hand you will hate the bike. The first time I blipped the throttle to down shift on a test ride I got about a 5K RPM increase instead of the 500 I intended.
That said, by the end of the test ride (about an hour) the throttle and I were old friends. Only down side is that it is HARD to keep the bike at 25 in 25 MPH zones!
Biggest dislikes are the speedo and the shift lever. The speedo jams from 0-60 MPH in 90 degrees of arc, then uses 180 degrees of arc to show 60-150. The shift lever was hard to get to without angling my toe in toward the centerline of the bike. If I tried to slide my entire foot inboard my boot would hit the ball on the end of the side stand deployment tang.
Since that was the most annoying thing I found and I'm sure I'll get used to it I ordered one. Assuming BMW accepts my order (I did not order one of the standard packages) the bike will be built in a couple of months. That gives me plenty of time to de-farkle the current GS.
marchyman is offline   Reply With Quote
Old 03-28-2013, 09:59 PM   #7642
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,549
And regarding the heated grips.... it wasn't very cold here today but I tried them out. They were plenty warm with my winter gloves when the ambient was about 52 F. As I said, not very cold. The test ride bike did not have hand guards, though. I imagine with guards they'll be fine for most of my riding.
Old 03-28-2013, 10:32 PM   #7643
oz97tj
oz97tj's Avatar
Oddometer: 821
I picked my bike up today around 3pm. Thw dealer said the Pro plugs came in this morning. Mine had the software update done too. All new bikes from here on out shiuld be good.
A few observations regarding posts mades.
Heated grips. When I demoed a bike last week, it was at the highest 35 degrees and the bike had no hand guards. Compared to my 07 GS that I rode to the dealer high was noticably less hot as others noted. However today riding the new bike home in 48 degree weather and with hand guards even low was too hot where I never hsd this issue with my old GS in similar temps. So looks like low is warmer and higher is cooler. Go figure. This is all with summer gloves.
Risers. I removed a set of Rox risersnfrom my 07 that was traded in. Im planning on mounting them on the new one. Ill report how it works out..
Throttle response. On the relatively smooth pavement I never noticed a twitchy throttle. Its certainly more abrupt but im putting that on the fsct the throttle is so light. I hit a few dirt roads coming home and on the bumpy stuff I did feel what one could call a twitchy throttle though. Every bump was enough to make the bike surge a slight bit. I was in ROAD mode. I switched to ENDURO and the issue completely went away. Clearly BMW knows how sensitive the throttle can be and worked out the bugs. For those without ride modes though you may be screwed.
Overall, I still feel like I did when I demoed the bike last week. Far more flickable, power that is instant, sounds way better, looks better, etc.
Anyway, a few driveway pics...
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is offline   Reply With Quote
Old 03-28-2013, 10:34 PM   #7644
268
268's Avatar
Oddometer: 168
Originally Posted by kindofblue View Post
Do I look like a happy camper or what?
Congrats
Eager to hear about the differences with the explorer
268 is offline   Reply With Quote
Old 03-28-2013, 11:35 PM   #7645
Montauk
Oddometer: 280
Originally Posted by oz97tj View Post
I picked my bike up today ...
Congrats. Now you need to change your signature line by removing "on order ..."
Montauk is offline   Reply With Quote
Old 03-28-2013, 11:38 PM   #7646
Montauk
Oddometer: 280
You sure look mighty happy to me doc. Congrats.
Old 03-28-2013, 11:43 PM   #7647
Montauk
Oddometer: 280
Halogen lights on US bikes o ar
Based on the pics seen so far of US owners, the headlights have been halogen. Has any US buyers received LC GS with LED lights?
Old 03-28-2013, 11:44 PM   #7648
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
...and LED turn signals?
tallguy-09 is offline   Reply With Quote
Old 03-28-2013, 11:48 PM   #7649
Montauk
Oddometer: 280
White with spoke wheels
I have seen few pics, and I am beginning to like 2 different color schemes for myself.
1. White with spoke
2. Thunder Grey with cast
It would be less stressful for me now, I just choose the wheel type and color is automatically selected.
Old 03-28-2013, 11:51 PM   #7650
oz97tj
oz97tj's Avatar
Oddometer: 821
I was orginally planning on waiying for the LED but none were brought in in the first batch and the wait could still be another month or two. It wasnt worth it to me to wait.
LEDs will likely start showing up next month sometime.
No LED turnsignals come on the US bikes. Only the big ugly ones.
Times are GMT -7.   It's 06:38 AM.
