Old 04-01-2013, 02:46 AM   #7801
IB1
IB1's Avatar
Oddometer: 1,026
Originally Posted by NLS View Post
More videos...
(ok this guy has a weird sense of what a video is)
What do you expect from the dutch?
IB1 is offline   Reply With Quote
Old 04-01-2013, 02:48 AM   #7802
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,103
Originally Posted by twinrider View Post
A friend has a similar guard on his GSA's headlight. He's complained that it blocks a considerable amount of light, enough to cast that same pattern on the road at night.
I have the TT guard on my Tiger 800. Although it does project a shadow on to the ground, I dont think it blocks enough light to be a problem. Admittedly, the Tiger does use twin headlights though.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 04-01-2013, 03:16 AM   #7803
tau
Oddometer: 15
Originally Posted by GSMarc View Post
Weight mesured : 247.2 kg ready to go. (545 lbs)
Back to the R1150GS weight
http://www.moto-station.com/moto-sta...ive.php?id=737
Perhaps, some weight could be saved in welding quality (see HP2 models)
Though it looks like being welded, it is not!
That "sub frame" represents the panniers fastenings which can easily be replaced / added.
That's depending on the package ordered - with or without them. I had the same felling - meaning that's welded - but Saturday I've spent (only) three hours around it in my dealer's showroom and I've been told the above mentioned.
tau is offline   Reply With Quote
Old 04-01-2013, 03:32 AM   #7804
Japanviking
Oddometer: 95
But it doesn't change the fact that the welds look like they have been done by a 6year old
I guess the Touratech engine guards are a good match judging from the pics on their website....
BMW S1000RR -12
BMW R1200GS -13
Japanviking screwed with this post 04-01-2013 at 03:40 AM
Japanviking is offline   Reply With Quote
Old 04-01-2013, 03:36 AM   #7805
tau
Oddometer: 15
Comparing with the previous model(s), the non ESA present one has non adjustable front shock absorber.
Is there any (special) reason for that? What do you guys, think about it?
Is the new installed Sachs shock absorber more efficient / better then previous Showa / WP?
I can see that still nobody has answered my questions; therefore I'm asking you another one: would you buy it / order it without ESA?
Please explain your reply. Just to be frank with you guys, I'm willing to order it without ESA, as:
- I consider the manual adjustment being more suitable / accurate.
- lower replacement cost
My main problem / concern the case I order it without ESA, is the front suspension which ... can not be adjusted ...!
Old 04-01-2013, 03:39 AM   #7806
tau
Oddometer: 15
Based on my previous - and good - experience with Wunderlich engine guard, I would go on them.
Old 04-01-2013, 03:41 AM   #7807
MaxReving
MaxReving's Avatar
Oddometer: 257
That's depending on the package ordered - with or without them. I had the same felling - meaning that's welded - but Saturday I've spent (only) three hours around it in my dealer's showroom and I've been told the above mentioned. That is not what he is referring to. He is referring to the quality of the weldings.
Hurra for handmade stuff
Ohh my God those weldings don't look nice. They might hold the subframe together but they sure look like someone had a very bad day at the welding factory. Maybe BMW Motorrad has subcontracted the welding but they still have to have some kind of quality control of all the subframes no matter if they made them themselves or if it was made by subcontractors. This for sure does not look like German engineering.
Max :-)
MaxReving is offline   Reply With Quote
Old 04-01-2013, 04:10 AM   #7808
IB1
IB1's Avatar
Oddometer: 1,026
Found the first made in Taiwan sticker ... On some of the wiring leading to the headlight.
Old 04-01-2013, 04:31 AM   #7809
Nick 187
Oddometer: 204
Low Suspension?
Currently I'm riding a 2010 R12 GS with a low factory low suspension. The older bikes with low suspension were not available with ESA. As I understand it there is a factory low suspension option however does anyone know if the riding modes and ESA is available on the 2013 low suspension model?
Nick
Nick 187 is offline   Reply With Quote
Old 04-01-2013, 04:36 AM   #7810
MaxReving
MaxReving's Avatar
Oddometer: 257
Touratech vs. Holan weldings
Touratech
Touratech
Touratech
And then this one from Holan. Maybe they are not better at welding at Holan but they sure are better at doing an extra effort to make the final result look a lot better than the stuff from Touratech.
Well, you be the judge!
Touratech = German Engineering at its best! Not so much.
Touratech may just have won an award for being best brand from the German magazine "Motorrad" but maybe the big chief Herbert should spend less time posing with awards and more time kicking some ass in the welding department at Touratech.
Max :-)
Old 04-01-2013, 04:37 AM   #7811
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,197
Took you long enough.
At least is from Taiwan specifically (which is still considered quality manufacturing) not China in general.
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 04-01-2013, 04:38 AM   #7812
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,501
I like the Cee Bailey headlight guards. They won't win as many admiring looks outside Starbucks but they give good protection without blocking any light and they pop off in a second for cleaning.
twinrider is offline   Reply With Quote
Old 04-01-2013, 04:50 AM   #7813
UK_Engineer
Oddometer: 67
OK I'll answer I bought a base model without ESA, so the front suspension is non - adjustable. I had the previous base model 2010 twin-cam GS and that had pre-load adjustment on the front suspension. I used to occasionally adjust the front pre-load BUT to be honest it made little difference in practice for 'normal' riding - if you were heavily laden off-road then perhaps it was useful but for 90% of the time it remained two stops up from minimum. I suspect that 99% of riders of the base model never changed the front pre-load so BMW thought why include it on the new model - rear pre-preload and damping is far more important and I used to change this all the time.
I am not yet a fan of ESA or dynamic ESA, if you don't do many miles it is probably a nice thing to have, but once the damping goes off after high mileage it is going to cost a fortune to replace - anyone buying a high mileage second hand bike beware, I would say that it would detract from the re-sale value of the bike.
UK_Engineer is offline   Reply With Quote
Old 04-01-2013, 05:02 AM   #7814
MaxReving
MaxReving's Avatar
Oddometer: 257
The BMW headlight guard for the 2013 1200GS LC:
Rubber mounts for easy removal.
Max :-)
Old 04-01-2013, 05:29 AM   #7815
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,566
I agree! While ESA is nice and it works when new, one has to wonder how long before they need to be rebuilt. Seems like I remember there were BMW ESA type suspension in the past that WAS NOT REBUILDABLE!
Think about it. Shocks on ANY motor vehicle are moving a great deal, all of the time the machine is rolling. Truly those moving parts take a BEATING more so than internal engine parts. The internal parts are lubricated by the same oil. Unlike an Engine, shock oil is seldom if ever changed ( these days...not yesteryear) As parts wear...and they WILL, the internal lubricant will become more contaminated. The more contaminated, the faster the wear. Granted it will take time, maybe years. It is not a matter of if, but WHEN! I would prefer a good set of - - - - - ( pick your flavor) ( me...wilburs or Ohlins cause that is what I know.
OTOH, most folks don't keep bikes long enough to worry about this. They seem to gravitate to buying the latest and greatest. It is all good either way.
One thing, the ESA is a great tool for allowing the ride to be premium at all times. Maybe in some ways a great set of Ohlins or Wilburs etc, would be a bit of a compromise when compared to ESA. However when one compares STOCK to Wilbers or Ohlins ... you think you are riding an entirely different M/C
Racegun is offline   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
